new editor feature [message #113946] |
Wed, 04 August 2004 18:28 |
Originally posted by: eclipse.squirrely.net
hi all,
there was this editor feature i always wanted for coding but never saw anywhere.
what do you guys think of this:
when typing in code and hitting return at the end i'd like
the editor to scroll the new line *up* thereby leaving the
cursor at exactly the same spot on the screen as it was before
see that way i can type lots of code and the cursor always remains in the middle
of the screen unlike the current case where after a short while the cursor is at the
bottom of the screen and i have to look way down and also don't see what follows.
if i'd want to implement that .. where in eclipse cdt code would i have to look ?
also, do i have something setup incorrectly in cdt or is it normal that it does not
close /* comments automatically (like the java perspective does)
and when typing return after a */ the cursor is under the * which is one character
too far to the right.
the other little cdt editor bug seems to be that it does not do the autoindent correctly
after if(..) and for(..) and so on
where would i need to look in the code to fix these little issues ?
any hints would be much appreciated as i don't want to sift through the code for hours
just trying to find the right spots
thanks
take care
frank
FUDForum. Page generated in 0.02524 seconds
