Birtviewer failures [message #113919] |
Tue, 24 January 2006 09:38 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jan.tanis.coas.com
I just installed BIRT 2.0 and I discovered some problems I had before
with the BIRT frameset viewer. In FireFox it is showing nothing but a
blank page... and the JavaScript errors offcourse. The same is for IE. I
hope this will be fixed soon as I'm dying to see the new release working
proper. Keep up the good work.
Regards, Jan.
Re: Birtviewer failures [message #115090 is a reply to message #114625] |
Wed, 25 January 2006 06:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jun Zhai wrote:
> What's the firefox version you are using? 1.5 or 1.0. We currently onlu
> support 1.0.
Yes, I do use 1.5.
> Also check whethet you get prototype.js. I can not think of any other
> issue if you see the error on IE.
Yes, that one was missing. Maybe I should upgrade less to avoid such
things;)
Regards, Jan.
FUDForum. Page generated in 0.03387 seconds
