eclipse 3 and CDT on RedHat 7.3?? [message #113324] |
Fri, 30 July 2004 23:28 |
Originally posted by: noyoucannothavemyemail.foomanchoo.com
I have downloaded the motif and GTK versions..but so far...I have found both
to be unstable.
the GTK version does give me warning at start that 2.0.6 is required, but
RH7.3 only has 2.0.2
I attempted to upgrade that..but that would require upgrading the png
library..which is essentually fources a massive upgrade...of many
apps/gnome/etc..
so..using motif I see no warning at start..but I get this crash pretty much
constantly..
is there a Requirements listing somewhere on using eclipse/CDT on linux?
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x40031087
Function=__pthread_mutex_lock+0x17
Library=/lib/i686/libpthread.so.0
Current Java thread:
at org.eclipse.swt.internal.motif.OS.XtSetValues(Native Method)
at org.eclipse.swt.widgets.MenuItem.setText(MenuItem.java:854)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionIte
m.java:1162)
org.eclipse.jface.action.ActionContributionItem$1.propertyCh ange(ActionContr
ibutionItem.java:488)
org.eclipse.ui.internal.commands.ws.CommandCallback$1.comman dChanged(Command
Callback.java:91)
org.eclipse.ui.internal.commands.Command.fireCommandChanged( Command.java:143
org.eclipse.ui.internal.commands.MutableCommandManager.notif yCommands(Mutabl
eCommandManager.java:389)
org.eclipse.ui.internal.commands.MutableCommandManager.setAc tiveContextIds(M
utableCommandManager.java:580)
org.eclipse.ui.internal.commands.ws.WorkbenchCommandSupport. setActiveContext
Ids(WorkbenchCommandSupport.java:631)
org.eclipse.ui.internal.Workbench$2.contextManagerChanged(Wo rkbench.java:181
2)
org.eclipse.ui.internal.contexts.AbstractContextManager.fire ContextManagerCh
anged(AbstractContextManager.java:46)
org.eclipse.ui.internal.contexts.ProxyContextManager$1.conte xtManagerChanged
(ProxyContextManager.java:41)
org.eclipse.ui.internal.contexts.MutableContextManager.setEn abledContextIds(
MutableContextManager.java:262)
org.eclipse.ui.internal.contexts.ws.WorkbenchContextSupport. processEnabledSu
bmissions(WorkbenchContextSupport.java:611)
bmissions(WorkbenchContextSupport.java:497)
org.eclipse.ui.internal.contexts.ws.WorkbenchContextSupport. removeEnabledSub
missions(WorkbenchContextSupport.java:711)
org.eclipse.ui.internal.contexts.ws.WorkbenchContextSupport. checkWindowType(
WorkbenchContextSupport.java:398)
org.eclipse.ui.internal.contexts.ws.WorkbenchContextSupport. access$0(Workben
chContextSupport.java:381)
org.eclipse.ui.internal.contexts.ws.WorkbenchContextSupport$ 1.handleEvent(Wo
rkbenchContextSupport.java:207)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:838 )
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:730)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:752)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:735)
at org.eclipse.swt.widgets.Shell.XFocusChange(Shell.java:1538)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:907)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3478 )
at org.eclipse.swt.internal.motif.OS.XtDispatchEvent(Native Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2640)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
org.eclipse.cdt.internal.ui.dialogs.cpaths.CPathOutputEntryP age.openOutputCo
ntainerDialog(CPathOutputEntryPage.java:485)
org.eclipse.cdt.internal.ui.dialogs.cpaths.CPathOutputEntryP age.outputPageCu
stomButtonPressed(CPathOutputEntryPage.java:232)
org.eclipse.cdt.internal.ui.dialogs.cpaths.CPathOutputEntryP age$OutputContai
nerAdapter.customButtonPressed(CPathOutputEntryPage.java:151 )
org.eclipse.cdt.internal.ui.wizards.dialogfields.TreeListDia logField.buttonP
ressed(TreeListDialogField.java:172)
org.eclipse.cdt.internal.ui.wizards.dialogfields.TreeListDia logField.doButto
nSelected(TreeListDialogField.java:396)
org.eclipse.cdt.internal.ui.wizards.dialogfields.TreeListDia logField.access$
2(TreeListDialogField.java:392)
org.eclipse.cdt.internal.ui.wizards.dialogfields.TreeListDia logField$2.widge
tSelected(TreeListDialogField.java:359)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:731)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2938)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2642)
org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDial ogAction.java:17
7)
org.eclipse.ui.internal.ide.actions.ProjectPropertyDialogAct ion.run(ProjectP
ropertyDialogAction.java:69)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:915)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:866)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContribu
tionItem.java:785)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:05 1010865
/usr/java/j2sdk1.4.2_04/bin/java
0804e000-0804f000 rw-p 00005000 03:05 1010865
40000000-40013000 r-xp 00000000 03:01 17933 /lib/ld-2.2.5.so
40013000-40014000 rw-p 00013000 03:01 17933 /lib/ld-2.2.5.so
40014000-4001c000 r-xp 00000000 03:05 750326
/usr/java/j2sdk1.4.2_04/jre/lib/i386/native_threads/libhpi.s o
4001c000-4001d000 rw-p 00007000 03:05 750326
4001d000-40026000 r-xp 00000000 03:01 15113 /lib/libnss_files-2.2.5.so
40026000-40027000 rw-p 00009000 03:01 15113 /lib/libnss_files-2.2.5.so
40027000-4002a000 r--s 00000000 03:05 1156857
/usr/java/j2sdk1.4.2_04/jre/lib/ext/dnsns.jar
4002a000-40037000 r-xp 00000000 03:01 45228 /lib/i686/libpthread-0.9.so
40037000-4003e000 rw-p 0000d000 03:01 45228 /lib/i686/libpthread-0.9.so
4003f000-40041000 r-xp 00000000 03:01 15093 /lib/libdl-2.2.5.so
40041000-40042000 rw-p 00001000 03:01 15093 /lib/libdl-2.2.5.so
40042000-4043d000 r-xp 00000000 03:05 98629
/usr/java/j2sdk1.4.2_04/jre/lib/i386/client/libjvm.so
4043d000-40458000 rw-p 003fa000 03:05 98629
4046b000-4047d000 r-xp 00000000 03:01 15097 /lib/libnsl-2.2.5.so
4047d000-4047e000 rw-p 00012000 03:01 15097 /lib/libnsl-2.2.5.so
40480000-404a1000 r-xp 00000000 03:01 45226 /lib/i686/libm-2.2.5.so
404a1000-404a2000 rw-p 00020000 03:01 45226 /lib/i686/libm-2.2.5.so
404a2000-404a6000 rw-s 00000000 03:01 48452 /tmp/hsperfdata_danh/13214
404a6000-404b6000 r-xp 00000000 03:05 98654
/usr/java/j2sdk1.4.2_04/jre/lib/i386/libverify.so
404b6000-404b8000 rw-p 0000f000 03:05 98654
404b8000-404c1000 r-xp 00000000 03:01 15118 /lib/libnss_nis-2.2.5.so
404c1000-404c2000 rw-p 00008000 03:01 15118 /lib/libnss_nis-2.2.5.so
404c2000-404e2000 r-xp 00000000 03:05 98640
/usr/java/j2sdk1.4.2_04/jre/lib/i386/libjava.so
404e2000-404e4000 rw-p 0001f000 03:05 98640
404e4000-404f8000 r-xp 00000000 03:05 98655
/usr/java/j2sdk1.4.2_04/jre/lib/i386/libzip.so
404f8000-404fb000 rw-p 00013000 03:05 98655
404fb000-41e9b000 r--s 00000000 03:05 147886
/usr/java/j2sdk1.4.2_04/jre/lib/rt.jar
41ee5000-41efb000 r--s 00000000 03:05 147885
/usr/java/j2sdk1.4.2_04/jre/lib/sunrsasign.jar
41efb000-41fd6000 r--s 00000000 03:05 147884
/usr/java/j2sdk1.4.2_04/jre/lib/jsse.jar
41fd6000-41fe7000 r--s 00000000 03:05 147876
/usr/java/j2sdk1.4.2_04/jre/lib/jce.jar
41fe7000-41fed000 r--s 00000000 03:05 553984
/usr/lib/gconv/gconv-modules.cache
41fed000-41ffa000 r--s 00000000 03:05 1156858
/usr/java/j2sdk1.4.2_04/jre/lib/ext/ldapsec.jar
41ffa000-41fff000 r--s 00000000 03:05 864494
/usr/local/bin/eclipse/startup.jar
41fff000-42000000 r--s 00000000 03:05 131108
/usr/local/bin/eclipse/plugins/org.eclipse.ui.workbench.comp atibility_3.0.0/
compatibility.jar
42000000-4212c000 r-xp 00000000 03:01 48053 /lib/i686/libc-2.2.5.so
4212c000-42131000 rw-p 0012c000 03:01 48053 /lib/i686/libc-2.2.5.so
42135000-4268e000 r--s 00000000 03:05 147877
/usr/java/j2sdk1.4.2_04/jre/lib/charsets.jar
44736000-4473e000 r--s 00000000 03:05 864283
/usr/local/bin/eclipse/plugins/org.eclipse.osgi_3.0.0/consol e.jar
4473e000-4473f000 r--s 00000000 03:05 945837
/usr/local/bin/eclipse/plugins/org.eclipse.swt.motif_3.0.0/w s/motif/swt-gtk.
jar
4473f000-44740000 r--s 00000000 03:05 1042784
/usr/local/bin/eclipse/plugins/org.eclipse.ui_3.0.0/ui.jar
589fc000-58a27000 r--p 00000000 03:05 1304193
/usr/lib/locale/en_US.iso885915/LC_CTYPE
58c2b000-58ce7000 r--s 00000000 03:05 1156861
/usr/java/j2sdk1.4.2_04/jre/lib/ext/localedata.jar
58ce7000-58d03000 r--s 00000000 03:05 1156860
/usr/java/j2sdk1.4.2_04/jre/lib/ext/sunjce_provider.jar
58d84000-58dbc000 r--s 00000000 03:05 864282
/usr/local/bin/eclipse/plugins/org.eclipse.osgi_3.0.0/core.j ar
58dbc000-58dc8000 r--s 00000000 03:05 864281
/usr/local/bin/eclipse/plugins/org.eclipse.osgi_3.0.0/osgi.j ar
58dc8000-58dde000 r--s 00000000 03:05 864285
/usr/local/bin/eclipse/plugins/org.eclipse.osgi_3.0.0/resolv er.jar
58dde000-58df4000 r--s 00000000 03:05 864286
/usr/local/bin/eclipse/plugins/org.eclipse.osgi_3.0.0/defaul tAdaptor.jar
58df4000-58e13000 r--s 00000000 03:05 864284
/usr/local/bin/eclipse/plugins/org.eclipse.osgi_3.0.0/eclips eAdaptor.jar
58f15000-58f6c000 r--s 00000000 03:05 864310
/usr/local/bin/eclipse/plugins/org.eclipse.core.runtime_3.0. 0/runtime.jar
58f6c000-58f7c000 r-xp 00000000 03:05 98651
/usr/java/j2sdk1.4.2_04/jre/lib/i386/libnet.so
58f7c000-58f7d000 rw-p 0000f000 03:05 98651
58f7d000-58f83000 r-xp 00000000 03:05 98652
/usr/java/j2sdk1.4.2_04/jre/lib/i386/libnio.so
58f83000-58f84000 rw-p 00005000 03:05 98652
58f84000-58f99000 r--s 00000000 03:05 196500
/usr/local/bin/eclipse/plugins/org.eclipse.core.runtime.comp atibility_3.0.0/
compatibility.jar
58f99000-58fad000 r--s 00000000 03:05 1010847
/usr/local/bin/eclipse/plugins/org.eclipse.update.configurat or_3.0.0/configu
rator.jar
58fad000-590fb000 r--s 00000000 03:05 1287809
/usr/local/bin/eclipse/plugins/org.eclipse.ui.ide_3.0.0/ide. jar
590fb000-5932e000 r--s 00000000 03:05 1287798
/usr/local/bin/eclipse/plugins/org.eclipse.ui.workbench_3.0. 0/workbench.jar
5932e000-593ac000 r--s 00000000 03:05 799056
/usr/local/bin/eclipse/plugins/org.eclipse.jface_3.0.0/jface .jar
593ac000-593bf000 r--s 00000000 03:05 945838
/usr/local/bin/eclipse/plugins/org.eclipse.swt.motif_3.0.0/w s/motif/swt-mozi
lla.jar
593bf000-594bc000 r--s 00000000 03:05 945839
/usr/local/bin/eclipse/plugins/org.eclipse.swt.motif_3.0.0/w s/motif/swt.jar
594bc000-59502000 r-xp 00000000 03:05 1042822
/usr/local/bin/eclipse/plugins/org.eclipse.swt.motif_3.0.0/o s/linux/x86/libs
wt-motif-3062.so
59502000-59505000 rw-p 00046000 03:05 1042822
wt-motif-3062.so
59505000-59507000 r-xp 00000000 03:05 180590
/usr/X11R6/lib/X11/locale/common/xlcDef.so.2
59507000-59508000 rw-p 00001000 03:05 180590
59508000-59509000 r--p 00000000 03:05 1059925
/usr/lib/locale/en_US.iso885915/LC_IDENTIFICATION
59509000-5950a000 r--p 00000000 03:05 1059926
/usr/lib/locale/en_US.iso885915/LC_MEASUREMENT
5950a000-5950b000 r--p 00000000 03:05 1059930
/usr/lib/locale/en_US.iso885915/LC_TELEPHONE
5950b000-5950c000 r--p 00000000 03:05 1059924
/usr/lib/locale/en_US.iso885915/LC_ADDRESS
5950c000-5950d000 r--p 00000000 03:05 1059928
/usr/lib/locale/en_US.iso885915/LC_NAME
5950d000-5950e000 r--p 00000000 03:05 1059929
/usr/lib/locale/en_US.iso885915/LC_PAPER
5950e000-5950f000 r--p 00000000 03:05 1075011
/usr/lib/locale/en_US.iso885915/LC_MESSAGES/SYS_LC_MESSAGES
5950f000-59510000 r--p 00000000 03:05 1059927
/usr/lib/locale/en_US.iso885915/LC_MONETARY
59510000-59516000 r--p 00000000 03:05 1108739
/usr/lib/locale/en_US.iso885915/LC_COLLATE
59516000-59517000 r--p 00000000 03:05 1059931
/usr/lib/locale/en_US.iso885915/LC_TIME
59517000-59518000 r--p 00000000 03:05 538682
/usr/lib/locale/en_US.iso885915/LC_NUMERIC
59518000-59519000 r-xp 00000000 03:05 1369150
/usr/local/bin/eclipse/plugins/org.eclipse.core.resources.li nux_3.0.0/os/lin
ux/x86/libcore_2_1_0b.so
59519000-5951a000 rw-p 00001000 03:05 1369150
5951a000-5951b000 r--s 00000000 03:05 1320641
/usr/local/bin/eclipse/plugins/org.eclipse.cdt.core.linux_2. 0.0/cdt_linux.ja
r
5951b000-5969f000 r-xp 00000000 03:05 864498
/usr/local/bin/eclipse/libXm.so.2
5969f000-596b2000 rw-p 00183000 03:05 864498
596b3000-59785000 r-xp 00000000 03:05 212005
/usr/X11R6/lib/libX11.so.6.2
59785000-59788000 rw-p 000d1000 03:05 212005
59788000-59794000 r-xp 00000000 03:05 212013
/usr/X11R6/lib/libXext.so.6.4
59794000-59795000 rw-p 0000c000 03:05 212013
59795000-597dd000 r-xp 00000000 03:05 212033 /usr/X11R6/lib/libXt.so.6.0
597dd000-597e1000 rw-p 00047000 03:05 212033 /usr/X11R6/lib/libXt.so.6.0
597e1000-597e7000 r-xp 00000000 03:05 212025 /usr/X11R6/lib/libXp.so.6.2
597e7000-597e8000 rw-p 00006000 03:05 212025 /usr/X11R6/lib/libXp.so.6.2
597e8000-597ec000 r-xp 00000000 03:05 212035
/usr/X11R6/lib/libXtst.so.6.1
597ec000-597ed000 rw-p 00004000 03:05 212035
597ed000-597f4000 r-xp 00000000 03:05 212003 /usr/X11R6/lib/libSM.so.6.0
597f4000-597f5000 rw-p 00007000 03:05 212003 /usr/X11R6/lib/libSM.so.6.0
597f5000-59809000 r-xp 00000000 03:05 211999
/usr/X11R6/lib/libICE.so.6.3
59809000-5980a000 rw-p 00013000 03:05 211999
5980c000-59827000 r-xp 00000000 03:05 179178
/usr/X11R6/lib/X11/locale/common/ximcp.so.2
59827000-59829000 rw-p 0001a000 03:05 179178
59829000-5982b000 r-xp 00000000 03:05 553936
/usr/lib/gconv/ISO8859-15.so
5982b000-5982c000 rw-p 00001000 03:05 553936
5982c000-59835000 r-xp 00000000 03:05 179301
/usr/X11R6/lib/X11/locale/common/xomGeneric.so.2
59835000-59836000 rw-p 00008000 03:05 179301
59836000-598d4000 r--s 00000000 03:05 1010803
/usr/local/bin/eclipse/plugins/org.eclipse.core.resources_3. 0.0/resources.ja
r
598d4000-59900000 r--s 00000000 03:05 799355
/usr/local/bin/eclipse/plugins/org.eclipse.team.core_3.0.0/t eam.jar
59981000-59991000 r--s 00000000 03:05 1320326
/usr/local/bin/eclipse/plugins/org.eclipse.help_3.0.0/help.j ar
59a93000-59c27000 r--s 00000000 03:05 278205
/usr/local/bin/eclipse/plugins/org.eclipse.cdt.ui_2.0.0/cdtu i.jar
59c27000-59c84000 r--s 00000000 03:05 1304283
/usr/local/bin/eclipse/plugins/org.eclipse.ui.workbench.text editor_3.0.0/tex
teditor.jar
59c84000-59cae000 r--s 00000000 03:05 1271520
/usr/local/bin/eclipse/plugins/org.eclipse.text_3.0.0/text.j ar
59cae000-59d45000 r--s 00000000 03:05 961927
/usr/local/bin/eclipse/plugins/org.eclipse.jface.text_3.0.0/ jfacetext.jar
59d45000-59e20000 r--s 00000000 03:05 1011148
/usr/local/bin/eclipse/plugins/org.eclipse.cdt.core_2.0.0/cd tcore.jar
59e20000-59ec9000 r--s 00000000 03:05 1011149
/usr/local/bin/eclipse/plugins/org.eclipse.cdt.core_2.0.0/cd tparser.jar
59fcb000-59fd9000 r--s 00000000 03:05 734013
/usr/local/bin/eclipse/plugins/org.eclipse.ui.views_3.0.0/vi ews.jar
59fd9000-5a017000 r--s 00000000 03:05 1010842
/usr/local/bin/eclipse/plugins/org.eclipse.ui.editors_3.0.0/ editors.jar
5a017000-5a023000 r--s 00000000 03:05 1287793
/usr/local/bin/eclipse/plugins/org.eclipse.core.filebuffers_ 3.0.0/filebuffer
s.jar
5a023000-5a083000 r--s 00000000 03:05 310338
/usr/local/bin/eclipse/plugins/org.eclipse.search_3.0.0/sear ch.jar
5a083000-5a0b8000 r--s 00000000 03:05 1043097
/usr/local/bin/eclipse/plugins/org.eclipse.cdt.make.core_2.0 .0/cdtmakecore.j
ar
5a0b8000-5a0c6000 r--s 00000000 03:05 1385497
/usr/local/bin/eclipse/plugins/org.eclipse.ui.console_3.0.0/ console.jar
5a0c6000-5a1a6000 r--s 00000000 03:05 978308
/usr/local/bin/eclipse/plugins/org.eclipse.debug.ui_3.0.0/dt ui.jar
5a1a6000-5a1de000 r--s 00000000 03:05 978383
/usr/local/bin/eclipse/plugins/org.eclipse.debug.core_3.0.0/ dtcore.jar
5a1de000-5a1eb000 r--s 00000000 03:05 1287803
/usr/local/bin/eclipse/plugins/org.eclipse.core.expressions_ 3.0.0/expression
s.jar
5a1eb000-5a205000 r--s 00000000 03:05 538503
/usr/local/bin/eclipse/plugins/org.eclipse.ui.externaltools_ 3.0.0/externalto
ols.jar
5a307000-5a30d000 r--s 00000000 03:05 864271
/usr/local/bin/eclipse/plugins/org.eclipse.update.scheduler_ 3.0.0/scheduler.
jar
5a30d000-5a34b000 r--s 00000000 03:05 1157187
/usr/local/bin/eclipse/plugins/org.eclipse.cdt.make.ui_2.0.0 /cdtmakeui.jar
5a34b000-5a36a000 r--s 00000000 03:05 505696
/usr/local/bin/eclipse/plugins/org.eclipse.cdt.managedbuilde r.ui_2.0.0/mgdbu
ildui.jar
5a36a000-5a387000 r--s 00000000 03:05 310556
/usr/local/bin/eclipse/plugins/org.eclipse.cdt.managedbuilde r.core_2.0.0/mng
buildcore.jar
Heap at VM Abort:
Heap
def new generation total 640K, used 215K [0x44740000, 0x447f0000,
0x45af0000)
eden space 576K, 33% used [0x44740000, 0x4476ffc8, 0x447d0000)
from space 64K, 36% used [0x447e0000, 0x447e5e10, 0x447f0000)
to space 64K, 0% used [0x447d0000, 0x447d0000, 0x447e0000)
tenured generation total 8164K, used 7066K [0x45af0000, 0x462e9000,
0x54740000)
the space 8164K, 86% used [0x45af0000, 0x461d6960, 0x461d6a00,
0x462e9000)
compacting perm gen total 14592K, used 14391K [0x54740000, 0x55580000,
0x58740000)
the space 14592K, 98% used [0x54740000, 0x5554df90, 0x5554e000,
0x55580000)
Local Time = Fri Jul 30 16:21:08 2004
Elapsed Time = 86
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode)
FUDForum. Page generated in 0.03682 seconds
