Home » Modeling » GMF (Graphical Modeling Framework) » XSD for Diagram output file
XSD for Diagram output file [message #112709] Sun, 18 March 2007 23:24 Go to next message
Originally posted by: evaandoli.dodo.com.au
Is it possible to get an XSD for the XML "Data" file that a finish GMF
diagram editor produces ?
I can I could do it by hand, but seems odd as the editor must know how to
create the data file.
Thanks in advance for any assistance,
Stu
Re: XSD for Diagram output file [message #112959 is a reply to message #112709] Mon, 19 March 2007 22:37 Go to previous messageGo to next message
Richard Gronback is currently offline Richard GronbackFriend
If you need an XSD for your domain model, you can create one from your EMF
genmodel (right-click the *.genmodel file and select Export Model...).
- Rich
On 3/18/07 7:24 PM, in article etkhnc$4q9$1@utils.eclipse.org, "Stu"
<evaandoli@dodo.com.au> wrote:
> Stu
Re: XSD for Diagram output file [message #112989 is a reply to message #112709] Tue, 20 March 2007 01:37 Go to previous message
You can also set a .genmodel property to create it during the generate
(thanks for the other method as well).
It is under:-
Top level .genmodel property >> mode >> generate schema (true/false)
"Stu" <evaandoli@dodo.com.au> wrote in message
news:etkhnc$4q9$1@utils.eclipse.org...
> Stu
Previous Topic:how to limit the number of incoming references?
Next Topic:org.eclipse.gmf.ecore.editor plug-in example
Current Time: Thu Dec 26 13:46:15 GMT 2024
Powered by FUDForum. Page generated in 0.04117 seconds
