Home » Archived » BIRT » Highlight does not highlight the entire table cell
Highlight does not highlight the entire table cell [message #111062] Wed, 18 January 2006 19:11 Go to next message
Sheldon Lee-Loy is currently offline Sheldon Lee-LoyFriend
Member
I have a report template file that changes the background color of a
cell in a table row to blue. However when I preview the report in
HTML only part of the cell is highlighted. That is, there is white
spaces surrounding the cell. From viewing the generated HTML it seems
taht a <div> tag is used to encase the text shown in the cell. The
div tag contains the background-color style. Shouldn't the <td>
bakground-color style change instead of the <div> tag? This is also a
problem if I don't display any text within a cell. In this case the
cell does not get highlighted at all.
Re: Highlight does not highlight the entire table cell [message #111236 is a reply to message #111062] Wed, 18 January 2006 23:24 Go to previous messageGo to next message
Jun Zhai is currently offline Jun ZhaiFriend
Member
Highlighting is disabled in final release since only exporting data needs
it. Exporting data's behavior is changed to allowing user exploit all
available result set in the report doc.
This highlighting thing needs to be polished.
Re: Highlight does not highlight the entire table cell [message #111861 is a reply to message #111062] Fri, 20 January 2006 01:46 Go to previous message
Wenbin He is currently offline Wenbin HeFriend
Member
This is a bug. Can you please file a bug, so we can track this issue?
thanks,
Wenbin He
BIRT designer project lead
<sleeloy@ca.ibm.com> wrote in message
news:kd4ts1lmhihb9o3oun1mac206lvlr0u2hu@4ax.com...
Previous Topic:scripting report items
Next Topic:Trailing page breaks-revisited...
Current Time: Sat Dec 21 16:11:46 GMT 2024
Powered by FUDForum. Page generated in 0.28901 seconds
