Home » Archived » Memory Analyzer (MAT) » Leak suspect newer end
Leak suspect newer end [message #10125] Wed, 22 April 2009 02:59 Go to next message
I opened a 700MB heap dump and started a Leak Suspect - but after 60
minutes its still run :( Memory jump from 500MB to 1GB and back again :)
Tested on: last stable and last version of mem. an. 64, 32bit 1.6_u13 jdk,
-Xmx2g. From GUI and command line (ParseHeadDump.bat). Using 64b Vista
Buss.
Re: Leak suspect newer end [message #10148 is a reply to message #10125] Thu, 23 April 2009 04:57 Go to previous message
Hi Pavel,
this shouldn't be the case...
Is it possible for you to share the heap dump?
You could send it directly to me (erwin dot margewitsch at sap dot com) in
order to investigate it locally. I will than create a bugzilla entry...
Sorry for any inconvenience,
Erwin
Previous Topic:Inconsistent display of HashMap-keys
Next Topic:New inspector feature: Show SWT widget and whether they're disposed
Current Time: Wed Apr 16 11:38:50 EDT 2025
Powered by FUDForum. Page generated in 0.03465 seconds
