Home » Eclipse Projects » GEF » The wizard dialog opened by doubled click was unabled responsed to the mouse event , but could respo
The wizard dialog opened by doubled click was unabled responsed to the mouse event , but could respo [message #110803] Thu, 08 January 2004 04:06 Go to next message
Originally posted by: lizhih.cn.ibm.com
Hi all,
I open a wizard dialog when the user double click a edit part on the
graphical editor , the controls on the wizard dialog such as textbox ,
buttons or combo , could not listen the mouse event , but they could listen
the key press event .
This was happened on the linux redhat 7.3 WSAD IE 5.0 , the mouse event
could be listened on the W2K or windows XP .
Does anyone have met this question before ?
I hope I'm lucky to get a response , thank you in advance.
Re: The wizard dialog opened by doubled click was unabled responsed to the mouse event , but could r [message #110829 is a reply to message #110803] Thu, 08 January 2004 11:58 Go to previous messageGo to next message
I have not seen this problem before. Is it possible that two dialogs are
being opened? One on top of the other? Are you using a MODAL dialog?
If you solve the problem, let us know. IF you don't, try providing code
that will reproduce the example. For example, Take the Logic Example, and
modify one of its editparts to open a dialog similar to the one you are
opening.
"hellen" <lizhih@cn.ibm.com> wrote in message
news:btj6f3$rt1$1@eclipse.org...
> Hi all,
listen
Re: The wizard dialog opened by doubled click was unabled responsed to the mouse event , but could r [message #110894 is a reply to message #110829] Thu, 08 January 2004 15:14 Go to previous messageGo to next message
Originally posted by: gaslade.yahoo.com
I've seen this problem before. I think we displayed the wizard using
Display.AsyncExec() to get round it.
Guy
Re: The wizard dialog opened by doubled click was unabled responsed to the mouse event , but could r [message #110903 is a reply to message #110894] Thu, 08 January 2004 16:09 Go to previous messageGo to next message
Any idea what the problem is? Is it because the mouse is down when the
dialog opens?
There needs to be an SWT bugzilla opened for this issue. AsyncExec is
always a risky workaround because the user could press Delete and delete the
editpart before your Runnable is dispatched. (Or press Undo, or close the
editor, or ....)
"Guy Slade" <gaslade@yahoo.com> wrote in message
news:btkdl3$fek$1@eclipse.org...
> Guy
Re: The wizard dialog opened by doubled click was unabled responsed to the mouse event , but could r [message #110914 is a reply to message #110903] Thu, 08 January 2004 16:09 Go to previous message
So in your Runnable, calling editpart.isActive() would be a good idea.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:btkgrp$jjo$1@eclipse.org...
> dialog opens?
the
> editor, or ....)
> > Guy
Previous Topic:Locking a selectable edit part
Next Topic:Bendpoints get scaled
Current Time: Fri Oct 31 04:57:10 EDT 2025
Powered by FUDForum. Page generated in 0.05796 seconds
