Home » Language IDEs » Java Development Tools (JDT) » trying to refactor access to an overloaded method
trying to refactor access to an overloaded method [message #110802] Mon, 27 October 2003 06:17 Go to next message
Originally posted by: xxx.esg-gmbh.de
Hi all,
I've an extended JButton with an overloaded setPreferredSize method.
I would like to change this method and its clients.
Using the search facility will give me all clients accessing the base
class
method in JComponent as well.
Is there a way to see only the access to the overloaded method (I'm using
V2.1
for now)?
Thanks in advance
Wolfgang R.
Antwort: trying to refactor access to an overloaded method [message #110961 is a reply to message #110802] Mon, 27 October 2003 11:21 Go to previous message
Ok, I've just found a simple way.
Simply let the JButton derive from Object and after some
thousand errors reported I can look for the callers of my
method now.
Wolfgang R.
Previous Topic:How to implement protected code sections
Next Topic:disabling quick diff in M4
Current Time: Tue Oct 14 07:48:33 EDT 2025
Powered by FUDForum. Page generated in 0.04853 seconds
