constrain a node to be the only root in a graph [message #836] |
Thu, 18 January 2007 18:35 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Conor Missing name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=conorgaff%40hotmail.com) Messages: 159 Registered: July 2009 |
I'm very new to OCL and have a few questions, the final one being the one
in the Subject line.
Are there any really good tutorials on OCL? I've had a look at this one
which is alright but are there any someone can recommend?
http://www.sciences.univ-nantes.fr/lina/atl/atldemo/oclturor ial/
What is the purpose of <>, is it not equal to? (java would be !=)
I'm specifically looking at GMF, I presume all OCL situations will
translate to from EMF to GMF?
To write a validation to check that diagram is not empty would it be
something like diagram.self -> isEmpty()
I don't really understand the purpose of 'self', could someone give me a
brief explination?
And finally, how would I write an OCL statement to check in a diagram that
only one node, lets call it A, has no parents (links moving directed away
from it), ie is the root node.
Thanks very much for your help.
Gaff
Re: constrain a node to be the only root in a graph [message #924 is a reply to message #836] |
Fri, 19 January 2007 21:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi, Gaff,
See some replies, in-line.
HTH,
Christian
Gaff wrote:
None better that I know of. There is the original Warmer & Kleppe book,
which should do pretty well as OCL 2.0 isn't *so* much different from OCL
1.x.
Exactly. Like Basic.
Yes. The usage of OCL in the GMF project is on EMF models.
More like
self.children->isEmpty()
where "self" represents the diagram (the constraint being defined in the
context of the Diagram class).
> brief explination?
Self is very much like 'this' in Java. It represents the element being
constrained by your OCL constraint, on which that constraint is applied at
run-time. It is called the "context variable" and its type is the "context
classifier" in which context the constraint is parsed. Typically the
context is declared in text via, e.g.,:
package notation context Diagram
inv myConstraint: ... your constraint here ...
endpackage
or by the placement of the constraint in the model (e.g., owned by the
Diagram class).
Perhaps something like:
self->closure(children)->one( child : View |
child.targetEdges->isEmpty() )
For simplicity, I am here using the "closure" iterator that our OCL
implementation defines as an addition to the language. This follows the
closure of the View::children association, which is (transitively) all of
the descendent views of the diagram (which is the "self" object).
The "one" iterator is defined by the OCL specification to query whether
there is exactly one element in the source collection:
for which the body expression:
is true.
> Gaff
FUDForum. Page generated in 0.03734 seconds
