AssertionFailedException when pressing refresh in browser [message #109958] |
Tue, 21 October 2008 08:27 |
Originally posted by: erdal.karaca.airbus.com
I have a simple rap app with a custom perspective and the rap.ui.workbench
enabled.
When pressing 'Refresh' the following error occurs:
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:86)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:74)
org.eclipse.jface.resource.StringConverter.asString(StringCo nverter.java:798)
org.eclipse.jface.preference.PreferenceConverter.setDefault( PreferenceConverter.java:418)
org.eclipse.ui.internal.themes.ThemeElementHelper.installCol or(ThemeElementHelper.java:288)
org.eclipse.ui.internal.themes.ThemeElementHelper.populateRe gistry(ThemeElementHelper.java:163)
at org.eclipse.ui.internal.themes.Theme.<init>(Theme.java:76)
org.eclipse.ui.internal.themes.WorkbenchThemeManager.getThem e(WorkbenchThemeManager.java:294)
org.eclipse.ui.internal.themes.WorkbenchThemeManager.getThem e(WorkbenchThemeManager.java:314)
org.eclipse.ui.internal.themes.WorkbenchThemeManager.doSetCu rrentTheme(WorkbenchThemeManager.java:218)
org.eclipse.ui.internal.themes.WorkbenchThemeManager.setCurr entTheme(WorkbenchThemeManager.java:343)
org.eclipse.ui.internal.themes.WorkbenchThemeManager.getCurr entTheme(WorkbenchThemeManager.java:256)
org.eclipse.ui.internal.themes.WorkbenchThemeManager.getInst ance(WorkbenchThemeManager.java:67)
at org.eclipse.ui.internal.Workbench.getThemeManager(Workbench. java:3135)
org.eclipse.ui.internal.Workbench$29.runWithException(Workbe nch.java:1421)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:135)
at org.eclipse.swt.widgets.Display$2.run(Display.java:649)
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 423)
org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:647)
org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.initializeFonts(Workbench. java:1415)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1295)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:425)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:408)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
Re: AssertionFailedException when pressing refresh in browser [message #110075 is a reply to message #109958] |
Tue, 21 October 2008 16:47 |
Originally posted by: fappel.innoopract.com
didn't see this before. But somehow I can imagine that deleting the
runtime workspace could help. The runtime workspace of each RAP app
started by the launcher is located e.g. in MS Windows under your eclipse
installation directory. This is still somewhat of a weekness of the
laucher, since workspaces are shared across launch configurations. And
this leads sometimes to strange behavior in particular if saveAndRestore
is activated.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Erdal Karaca [mailto:erdal.karaca@airbus.com]
Bereitgestellt: Dienstag, 21. Oktober 2008 10:27
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: AssertionFailedException when pressing refresh in browser
Betreff: AssertionFailedException when pressing refresh in browser
rap.ui.workbench
enabled.
:798)
nverter.java:418)
entHelper.java:288)
1)
ading.java:32)
anager.java:135)
adWithFakeContext(UICallBackServiceHandler.java:423)
lBack.java:44)
eading.java:110)
288)
08)
Re: AssertionFailedException when pressing refresh in browser [message #110188 is a reply to message #110075] |
Wed, 22 October 2008 09:03 |
The first time the application is started it works.
If I rerun (press Refresh in browser) or start a new session (load app by
another browser instance) the app fails.
Wokrbench advisor is not set to save and restore settings.
In the launcher config I have set to clear config area before launching...
I will try to provide more specific details once available...
Frank Appel wrote:
> is activated.
> Ciao
> Frank
Re: AssertionFailedException when pressing refresh in browser [message #110382 is a reply to message #110188] |
Thu, 23 October 2008 13:41 |
just to clarify: the workspace is not cleared if you set the 'clear
config area before launching' flag. Unfortunately there's no automatic
workspace clear option for the RAP launcher yet.
Ciao
Frank
Bereitgestellt: Mittwoch, 22. Oktober 2008 11:03
Betreff: Re: AssertionFailedException when pressing refresh in browser
by
launching...
Frank Appel wrote:
eclipse
saveAndRestore
> is activated.
> Ciao
> Frank
FUDForum. Page generated in 0.03419 seconds
