Exception running validator code [message #109785] |
Fri, 21 October 2005 11:39 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wolfmwolfNOSPAM._ATgmx.de
we are having problems with VE 1.1.0.1 (gef 3.1.0, emf 1.1.0.1).
For some of our files, after opening it in the VE and selecting the
first control in the design view, the source view is emptied and then
only the message 'exception running validator code' is shown.
Maybe someone could have a look at the stack trace below.
To resolve the situation, the file must be closed and opened again.
In fact that means that VE can no longer be used to edit the file.
Any ideas how i can resolve this ?
mike
!ENTRY org.eclipse.core.resources 4 2 2005-10-21 12:42:20.483
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.resources".
!STACK 0
at org.eclipse.gef.tools.AbstractTool.deactivate(AbstractTool.j ava:368)
at org.eclipse.gef.tools.TargetingTool.deactivate(TargetingTool .java:82)
org.eclipse.gef.tools.DragEditPartsTracker.deactivate(DragEd itPartsTracker.java:206)
org.eclipse.gef.tools.SelectionTool.setDragTracker(Selection Tool.java:584)
org.eclipse.gef.tools.SelectionTool.handleFocusLost(Selectio nTool.java:240)
at org.eclipse.gef.tools.AbstractTool.focusLost(AbstractTool.ja va:423)
at org.eclipse.gef.EditDomain.focusLost(EditDomain.java:95)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchFocus Lost(DomainEventDispatcher.java:232)
org.eclipse.draw2d.LightweightSystem$EventHandler.focusLost( LightweightSystem.java:363)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:109)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 1841)
at org.eclipse.swt.widgets.Widget.wmKillFocus(Widget.java:1586)
at org.eclipse.swt.widgets.Control.WM_KILLFOCUS(Control.java:33 56)
at org.eclipse.swt.widgets.Canvas.WM_KILLFOCUS(Canvas.java:241)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3069 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.j ava:183)
at org.eclipse.swt.widgets.Shell.open(Shell.java:816)
at org.eclipse.jface.window.Window.open(Window.java:783)
org.eclipse.jface.dialogs.MessageDialog.openQuestion(Message Dialog.java:368)
org.eclipse.team.internal.ui.DefaultUIFileModificationValida tor$1.run(DefaultUIFileModificationValidator.java:131)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:152)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:28)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:3413)
org.eclipse.team.internal.ui.DefaultUIFileModificationValida tor.validateEdit(DefaultUIFileModificationValidator.java:129 )
org.eclipse.team.internal.core.DefaultFileModificationValida tor.validateEdit(DefaultFileModificationValidator.java:48)
org.eclipse.team.internal.core.FileModificationValidatorMana ger.validateEdit(FileModificationValidatorManager.java:66)
at org.eclipse.core.internal.resources.Workspace$5.run(Workspac e.java:1938)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
org.eclipse.core.internal.resources.Workspace.validateEdit(W orkspace.java:1945)
org.eclipse.core.internal.filebuffers.ResourceFileBuffer.val idateState(ResourceFileBuffer.java:393)
org.eclipse.ui.editors.text.TextFileDocumentProvider$4.execu te(TextFileDocumentProvider.java:999)
org.eclipse.ui.editors.text.TextFileDocumentProvider$Documen tProviderOperation.run(TextFileDocumentProvider.java:126)
org.eclipse.ui.actions.WorkspaceModifyDelegatingOperation.ex ecute(WorkspaceModifyDelegatingOperation.java:68)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:98)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:110)
org.eclipse.ui.internal.editors.text.WorkspaceOperationRunne r.run(WorkspaceOperationRunner.java:73)
org.eclipse.ui.internal.editors.text.WorkspaceOperationRunne r.run(WorkspaceOperationRunner.java:63)
org.eclipse.ui.editors.text.TextFileDocumentProvider.execute Operation(TextFileDocumentProvider.java:441)
org.eclipse.ui.editors.text.TextFileDocumentProvider.validat eState(TextFileDocumentProvider.java:1012)
org.eclipse.ui.texteditor.AbstractTextEditor.validateState(A bstractTextEditor.java:3624)
org.eclipse.ui.texteditor.AbstractTextEditor$18.run(Abstract TextEditor.java:3675)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.texteditor.AbstractTextEditor.validateEditorI nputState(AbstractTextEditor.java:3670)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorModelChangeController.getHoldState(JavaVisualEditorModel ChangeController.java:97)
org.eclipse.ve.internal.cde.core.CDEUtilities.getHoldState(C DEUtilities.java:292)
org.eclipse.ve.internal.cde.core.CDESelectionTool.refreshCur sor(CDESelectionTool.java:61)
org.eclipse.gef.tools.SelectionTool.setDragTracker(Selection Tool.java:586)
org.eclipse.gef.tools.SelectionTool.handleButtonDown(Selecti onTool.java:201)
at org.eclipse.gef.tools.AbstractTool.mouseDown(AbstractTool.ja va:964)
at org.eclipse.gef.tools.SelectionTool.mouseDown(SelectionTool. java:489)
at org.eclipse.gef.EditDomain.mouseDown(EditDomain.java:215)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Pressed(DomainEventDispatcher.java:342)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown( LightweightSystem.java:523)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:133)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: Exception running validator code [message #109921 is a reply to message #109785] |
Tue, 25 October 2005 15:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
You are touching a read-only file. Team is trying to popup a menu to ask
if you want to change it to a read-write file. There is a problem in GEF
that if the focus is stolen from it while a "tracker" is loaded it blows
up. We don't have a fix for it. So see if you can just change it to a
read/write file.
mike wrote:
> mike
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Rich Kulp
Re: Exception running validator code [message #611239 is a reply to message #109785] |
read/write file.
mike wrote:
> mike
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Rich Kulp
FUDForum. Page generated in 0.03086 seconds
