Home » Archived » BIRT » The filter are wrong
The filter are wrong [message #109646] Mon, 16 January 2006 08:58 Go to next message
Originally posted by: web-xy.163.com
Hi All,
When I define the filter, appears the following mistake, asked is what
reason? thanks.
$no-rb$ has the BIRT exception: To Javascript expression evaluation when
makes a mistake. Script engine wrong: ReferenceError: "params" is not
defined.
Foot source: Filter, line: 0, text:
Params [ "niandai_in" ]. The examination next exception by understands more
information.
To Javascript expression evaluation when makes a mistake. Script engine
wrong: ReferenceError: "params" is not defined.
Thanks!
Re: The filter are wrong [message #110664 is a reply to message #109646] Wed, 18 January 2006 01:24 Go to previous messageGo to next message
up,
thanks
"jzealot" <web-xy@163.com> д
Re: The filter are wrong [message #110734 is a reply to message #109646] Wed, 18 January 2006 02:02 Go to previous message
Gary Xue is currently offline Gary XueFriend
It sounds like you might have defined a filter in the data set that uses a
report parameter. This is not a recommended practice - you will get an error
like this when you preview the data set in the Data Set Editor. Such a
filter should be define on the table/list that uses the data set.
If this is not what caused your error please attache a copy of your report
design so we can take a look.
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"jzealot" <web-xy@163.com> wrote in message
news:dqfnab$tun$1@utils.eclipse.org...
> Hi All,
> reason? thanks.
> defined.
more
> information.
> Thanks!
Previous Topic:xquery
Next Topic:Use like in oracle
Current Time: Wed Jan 15 11:14:22 GMT 2025
Powered by FUDForum. Page generated in 0.03833 seconds
