Home » Archived » Test and Performance Tools Platform (TPTP) » Problem with standard mode execution in different contexts
Re: Problem with standard mode execution in different contexts [message #109725 is a reply to message #109573] |
Tue, 21 August 2007 10:56 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
------=_NextPart_000_0083_01C7E3C8.D36A6C80
Content-Type: text/plain;
charset="iso-8859-1"
Hi Matthias,
Are you clearing the existing workspace or using a new workspace =
when running in a new context? Also, what string are you specifying in =
the Eclipse Location text field:
http://www.eclipse.org/tptp/test/documents/userguides/auto-g ui-images-4-4=
-0/overview-page-4-4-0.png
Paul
"Matthias Wiskow" <matthias.wiskow@windriver.com> wrote in message =
news:fac5eo$7ct$1@build.eclipse.org...
I have problems in executing a simple AGR test suite.
Environment:
- Eclipse 3.3
- TPTP 4.4.0.2 AllinOne + correspondent AGR and Agent Controller
- JRE 1.5 Update 11
- Windows XP SP2
I folllowed the AGR tutorial and created a small test suite with 4 =
test cases (create Java project, add a class, edit the class, delete the =
project).
Running the test suite in standard mode with "Use current workbench as =
context" works fine, both with IAC and external AC.
But I don't manage to run the test when specifying a different Eclipse =
3.3 installation (by equinox launcher plug-in) or using the deployment =
method described in chapter 2.2.1.
Symptom: SUT is started, but nothing else happens.
I also tried it with the SUT having AGR and TPTP platform integrated =
as well as with different target platform settings in the plug-in =
development preferences.
Did I miss or misunderstand something?
I attached a zip with two Agent Controller logs: one of a successful =
session and one of a failed session.
Any help is highly appreciated.
Matthias
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16481" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Hi Matthias,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> Are you clearing the =
existing=20
workspace or using a new workspace when running in a new context? =
Also,=20
what string are you specifying in the Eclipse Location text =
field:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2><A=20
href=3D" http://www.eclipse.org/tptp/test/documents/userguides/auto-g ui-im=
ages-4-4-0/overview-page-4-4-0.png">http://www.eclipse.org/tptp/test/docu=
ments/userguides/auto-gui-images-4-4-0/overview-page-4-4-0.p ng </A></FONT>=
</DIV>
<DIV><FONT face=3DArial size=3D2>Paul</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Matthias Wiskow" <<A=20
href=3D"mailto:matthias.wiskow@windriver.com">matthias.wiskow@windriver.c=
om</A>>=20
wrote in message <A=20
href=3D"news:fac5eo$7ct$1@build.eclipse.org">news:fac5eo$7ct$1@build.ecli=
pse.org</A>...</DIV>Hi,<BR>I=20
have problems in executing a simple AGR test =
suite.<BR><BR>Environment:<BR>-=20
Eclipse 3.3<BR>- TPTP 4.4.0.2 AllinOne + correspondent AGR and Agent=20
Controller<BR>- JRE 1.5 Update 11<BR>- Windows XP SP2<BR><BR>I =
folllowed the=20
<A=20
href=3D" http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-=
GUI-4-4-0.html">AGR=20
tutorial</A> and created a small test suite with 4 test cases (create =
Java=20
project, add a class, edit the class, delete the project).<BR>Running =
the test=20
suite in standard mode with "Use current workbench as context" works =
fine,=20
both with IAC and external AC.<BR>But I don't manage to run the test =
when=20
specifying a different Eclipse 3.3 installation (by equinox launcher =
plug-in)=20
or using the deployment method described in chapter =
2.2.1.<BR><BR>Symptom: SUT=20
is started, but nothing else happens.<BR><BR>I also tried it with the =
SUT=20
having AGR and TPTP platform integrated as well as with different =
target=20
platform settings in the plug-in development preferences.<BR><BR>Did I =
miss or=20
misunderstand something?<BR><BR>I attached a zip with two Agent =
Controller=20
logs: one of a successful session and one of a failed =
session.<BR><BR>Any help=20
is highly =
appreciated.<BR><BR>Thanks,<BR>Matthias<BR></BLOCKQUOTE ></BODY></HTML>
------=_NextPart_000_0083_01C7E3C8.D36A6C80--
Re: Problem with standard mode execution in different contexts [message #109732 is a reply to message #109725] |
Tue, 21 August 2007 13:08 |
Matthias Wiskow Messages: 25 Registered: July 2009 |
Junior Member |
Hi Paul,
thanks for your reply.
Please see inserted answers below.
Does the target platform in the plug-in development preference settings
play a role?
Matthias
Paul Slauenwhite wrote:
> Hi Matthias,
I tried both, but it made no difference.
I inserted the absolute path to the equinox launcher plug-in. Since I'm
working on Windows it looks like
D:\eclipse\plugins\org.eclipse.equinox.launcher_1.0.0.v20070 606.jar
> http://www.eclipse.org/tptp/test/documents/userguides/auto-g ui-images-4-4-0/overview-page-4-4-0.png
> Paul
> <mailto:matthias.wiskow@windriver.com>> wrote in message
> Environment:
> - Eclipse 3.3
> - JRE 1.5 Update 11
> - Windows XP SP2
> < http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html>
> and created a small test suite with 4 test cases (create Java
> as context" works fine, both with IAC and external AC.
> Eclipse 3.3 installation (by equinox launcher plug-in) or using the
> deployment method described in chapter 2.2.1.
> Matthias
Re: Problem with standard mode execution in different contexts [message #109881 is a reply to message #109732] |
Thu, 23 August 2007 13:56 |
Junior Member |
problem solved :-)
It was most probably all my bad :-(
After adding TPTP AllinOne + AGR via extension location to my SUT
everything works fine now.
I have been looking around for information of how to set up the SUT for
AGR test execution, but didn't find any documentation.
Did I miss some doc out there?
Perhaps it would be great to add correspondent remarks to the AGR
tutorial. It describes the deployment setup in detail, but leaves the
beginner alone in finding out how to setup the test candidate.
Anyway, thanks for your help!
Matthias
Matthias Wiskow wrote:
> Hi Paul,
> play a role?
> Matthias
>> Hi Matthias,
>> Paul
>> Environment:
>> - Eclipse 3.3
>> - JRE 1.5 Update 11
>> - Windows XP SP2
>> Thanks,
>> Matthias
Re: Problem with standard mode execution in different contexts [message #110202 is a reply to message #109732] |
Mon, 27 August 2007 11:17 |
Hi Matthias,
The classpath variable ECLIPSE_HOME is used to by default for this AGR
property. The ECLIPSE_HOME variable is populated by the target platform.
Paul
news:faeo5v$o0n$1@build.eclipse.org...
> Hi Paul,
> play a role?
> Matthias
>> Hi Matthias,
>> Are you clearing the existing workspace or using a new workspace when
>> Paul
>> Environment:
>> - Eclipse 3.3
>> - JRE 1.5 Update 11
>> - Windows XP SP2
>> Thanks,
>> Matthias
Re: Problem with standard mode execution in different contexts [message #110215 is a reply to message #109881] |
Mon, 27 August 2007 11:20 |
Hi Matthias,
Correct, you will need the same dependencies and levels in the target
context.
There is no documentation on configuration the SUT. I have a comment to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196239 regarding your request
to update the AGR documentation. You can add yourself to the CC list.
Paul
news:fak3nj$u6t$1@build.eclipse.org...
> problem solved :-)
> Matthias
>> Hi Paul,
>> play a role?
>> Matthias
>>> Hi Matthias,
>>> Paul
>>> Hi,
>>> Environment:
>>> - Eclipse 3.3
>>> - JRE 1.5 Update 11
>>> - Windows XP SP2
>>> Thanks,
>>> Matthias
Current Time: Sat Oct 19 14:22:20 GMT 2024
Powered by FUDForum. Page generated in 0.03747 seconds
