Home » Eclipse Projects » Equinox » Equinox Application Model Demo
Equinox Application Model Demo [message #109217] Wed, 07 May 2008 20:27 Go to next message
I am trying to develop an RCP application which is a front end that allows
launching other RCP apps. In other words some thing very similar to what
is described on http://wiki.eclipse.org/Equinox_Application_Model_Demo.
I have checked out the projects mentioned at the above URL and looked at
the code and have no problem running the demo code. The part that I have a
question on is whether it is possible to use the App Selector to launch an
RCP app as opposed to a SWT app.
I wrote a simple RCP app and added the
org.eclipse.core.runtime.applications extension to it and it is getting
picked up by App Selector. But the RCP application does not start due to
the following error:
org.eclipse.swt.SWTError: Not implemented [multiple displays]
This error is caused by PlatformUI.createDisplay() line in the plugin's
Application.start() method. Is there any way to create a new workbench and
display even though App Selector already has an active workbench and
display. I also tried closing the App Selector's workbench prior to
launching the new RCP app but that did not work either.
Any advice is greatly appreciated,
- Saeid
Re: Equinox Application Model Demo [message #109233 is a reply to message #109217] Thu, 08 May 2008 02:14 Go to previous messageGo to next message
Just a wild guess but from the error message I think you are creating a
display everytime you start an application and SWT doesn't support
multiple displays in one JVM. I think you could check with
Display#getCurrent() and only if it returns null create a new one.
Tom
Saeid Zoonemat Kemani schrieb:
> Hello,
> allows launching other RCP apps. In other words some thing very similar
> to what is described on
> a question on is whether it is possible to use the App Selector to
> launch an RCP app as opposed to a SWT app.
> and display even though App Selector already has an active workbench and
> - Saeid
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Equinox Application Model Demo [message #109286 is a reply to message #109233] Thu, 08 May 2008 13:28 Go to previous messageGo to next message
Thank you for the response but that does not work either.
Display.getCurrent() returns null but it still complains about multiple
displays.
Display.getDefault() does return a display ID but then an exception is
raised at the line:
int returnCode = PlatformUI.createAndRunWorkbench(display, new
ApplicationWorkbenchAdvisor());
The exception is:
java.lang.IllegalStateException: Workbench already exists and cannot be
created again.
Trying to close the workbench already opened using
PlatformUI.getWorkbench().cloe(), throws an illegal thread access
exception.
The question remains whether there is any way to launch a new workbench
from an existing one. It seems that there has to be a way to do this since
one can use the link "Launch an Eclipse application" from the overview tab
of the plugin.xml on the IDE itself.
I tried looking at the eclipse source code to see how that is done but I
could not find any thing immediately useful. It seems to refer to the
extension point org.eclipse.pde.ui.launchShortcuts. I need to look some
more to see if there is an API that can be used.
Another option may be to rewrite the App Selector to be a SWT app and not
an RCP app. That way, there should not be any existing workbenches to
complain about.
Any ideas or advice will be welcomed. Thanks,
- Saeid
Tom Schindl wrote:
> Tom
>> Hello,
>> - Saeid
Re: Equinox Application Model Demo [message #109299 is a reply to message #109286] Thu, 08 May 2008 13:33 Go to previous messageGo to next message
Ok. Yes this is a problem you can't run more than one workbench in one
OSGi/JVM-Env that's why e.g. the RAP people are patching all those libs.
When you click on the launch tab an extra process is spawned! Launching
multiple workbench instance is certainly a topic for E4 (The problem is
that the platform code uses Singletons and static variables all over the
place and so only one instance is possible :-(.
Tom
> displays.
> raised at the line:
> The exception is:
> created again.
> exception.
> since one can use the link "Launch an Eclipse application" from the
> overview tab of the plugin.xml on the IDE itself.
> not an RCP app. That way, there should not be any existing workbenches
> to complain about.
> - Saeid
> Tom Schindl wrote:
>> a display everytime you start an application and SWT doesn't support
>> Tom
>>> Hello,
>>> similar to what is described on
>>> at the code and have no problem running the demo code. The part that
>>> I have a question on is whether it is possible to use the App
>>> Selector to launch an RCP app as opposed to a SWT app.
>>> getting picked up by App Selector. But the RCP application does not
>>> start due to the following error:
>>> plugin's Application.start() method. Is there any way to create a new
>>> workbench and display even though App Selector already has an active
>>> workbench and display. I also tried closing the App Selector's
>>> workbench prior to launching the new RCP app but that did not work
>>> either.
>>> - Saeid
Re: Equinox Application Model Demo [message #109324 is a reply to message #109299] Thu, 08 May 2008 14:55 Go to previous message
Hello Again,
I was afraid of this... Unfortunately I cannot wait till E4 but spawning a
new process should not be a problem. I have looked around and have not
been able to find a good reference/tutorial except this one which is a
little old:
http://www.eclipse.org/articles/Article-Launch-Framework/lau nch.html
Any recommendations on a good reference. Thank you,
- Saeid
> Tom
Previous Topic:Activator to Servlet
Next Topic:incorrect URL from thread.getContextClassLoader().getResource()
Current Time: Tue Nov 04 06:09:36 EST 2025
Powered by FUDForum. Page generated in 0.06096 seconds
