Setting break point on code in header file [message #109121] |
Mon, 05 July 2004 22:50 |
Much of my source code is in C++ header files.
I can step into this code but there are no line numbers
and I appear to be unable to set a break point on
any line in a ".h" file.
Can someone point me the right way?
Jim
Re: Setting break point on code in header file [message #109313 is a reply to message #109223] |
Tue, 06 July 2004 18:18 |
I think you identified the problem.
The header files are part of the project only in the sense
that I have an include directory is the C++ properties.
I see I could import them into the project but I think that
makes a copy - not good because these headers are in all my projects.
How do I tell the project that these headers are part of the project?
Thanks for the quick answer to the original query.
Jim
Mikhail Khodjaiants wrote:
> Is the header file a part of your project?
> <user@domain.invalid> wrote in message
> news:40E9DB53.1010301@domain.invalid...
>>Jim
Re: Setting break point on code in header file [message #109461 is a reply to message #109313] |
Tue, 06 July 2004 21:26 |
Originally posted by: mikhailk.qnx.com
The problem is that CDT doesn't support breakpoints in the files that are
not in the workspace. I hope this problem will be solved for the next
release.
You can create a special project for your headers and reference it from
other projects.
news:40EAECD9.1010703@domain.invalid...
> Jim
> >>Jim
Re: Setting break point on code in header file [message #110239 is a reply to message #109313] |
Sun, 11 July 2004 05:42 |
I just wanted to let everyone know that I built a dummy project
containing only my header files. I have turned off automatic
build so this project never gets built.
In my real project, I reference the dummy project.
Now the header files get line numbers like my C++ source
and I can set breakpoints on it.
I think it's quite a nice solution.
Thanks to Mikhail Khodjaiants for suggesting this solution
and to all the others who have helped me get up and running.
Jim Brown
Jim.brown@smartarrays.com
> Jim
>>> Jim
Re: Setting break point on code in header file [message #116444 is a reply to message #109461] |
Fri, 20 August 2004 13:25 |
Originally posted by: lsiefert.senate.michigan.gov
Wow. Cool. Thanks. Never thought of that.
This is just the piece I need to make CDT usable as is for real work and
not just playing/testing. Shows the value of reading through the old
posts in a newsgroup.
Now if I could only get mingw to compile my CodeBase library files...
(Not a CDT or Eclipse problem, building from supplied build files with
my edits for mingw, but keep getting memory error at runtime.)
- Leo
> release.
> other projects.
FUDForum. Page generated in 2.43968 seconds
