Re: [ANN] SWT Designer FormLayout Preview Pics [message #109037 is a reply to message #108872] |
Wed, 22 October 2003 18:01 |
Originally posted by: rgallen.comcast.net
Eric Clayberg wrote:
> We are close to releasing an update to SWT Designer that contains very nice
> support for FormLayout. Before releasing the update, we wanted to get
> feedback and suggestions from the group. The most exciting aspect of the
> FormLayout capability is the support for dynamic snap points at the window
> margins, at the edges of possible target widgets, and to user-defined
> percentage points within the window.
> You can access the "FormLayout Preview" pics from the SWT Designer home
> page, http://www.swt-designer.com, or directly from
> here...http://www.instantiations.com/swt-designer/shots/form layout.html. We
> hope to get a flash demo in place soon that will show this off.
As an existing owner of Designer, my only comment is when can I download
the update ? :-)
Re: [ANN] SWT Designer FormLayout Preview Pics [message #109237 is a reply to message #109102] |
Thu, 23 October 2003 03:49 |
> "Rennie Allen" <rgallen@comcast.net> wrote in message
> news:bn6gm4$is4$1@eclipse.org...
> > the update ? :-)
> Hopefully, soon. The new FormLayout support represents an enormous amount of
> engineering work, so we want to make sure to get it just right. How did the
> pics look? Any suggestion, comments or requirements for the FormLayout
> support?
It looks great; but it is hard to give much more in the way of comments
without actually getting my mitts on it.
Take your time and get it right, from what I have seen so far your first
crack at it should be pretty good.
Re: [ANN] SWT Designer FormLayout Preview Pics [message #110017 is a reply to message #109404] |
Fri, 24 October 2003 06:33 |
Originally posted by: nomail.nomail.com
> > not what I've used to. A lot of inplace scrollable frames makes it hard
to
> > read. Especially left-bottom "News" frame is very very hard to read as I
> can
> > only see 5 lines and then must scroll the inplace frame. I hope other
> > websites don't follow such layout schema.
> The website was set up to emulate the Eclipse look and feel. Lots of folks
> tell us they like it, but I agree that the News frame is too small. I will
> try and fix that.
Caption emulating Eclipse indeed looks good, but inplace frames sux I you
ask me. Its very hard to scroll up and down reading the long pages.
I suggest you still keep "Eclipse caption bar" bitmap, but get rid of the
inframes. Make a regular page and just use html-table to seperate column
textregions. Then its easy to scroll page even in low resolution comps.
FUDForum. Page generated in 0.04174 seconds
