Home » Eclipse Projects » Equinox » Getting a bundles jar location
Getting a bundles jar location [message #108609] |
Wed, 23 April 2008 12:12  |
Originally posted by: Boyan.Yurukov.softwareag.com
How can I get the absolute location of a bundle's jar file? I need to build
a FileInputStream out of it. I tried with :
bundle.getResource(bundle.getLocation())
but it doesn't return anything back. bundle.getLocation() returns something
like :
update@plugins/org.eclipse.ui_3.3.1.M20070910-0800b.jar
which seems to be an identifier. I don't know where to use it.
Boyan.
Re: Getting a bundles jar location [message #108736 is a reply to message #108721] |
Thu, 24 April 2008 02:07   |
The correct way, should be:
FileLocator.resolve(bundle.getEntry("/"))
bundle.getLocation() returns unique string, identifying the bundle in
the framework. Before R4, the bundles didn't have symbolic names and
versions, the location was used for identifying a particular bundle.
The location of the bundle is usually an URL to the original bundle
contents, but the framework doesn't make an assumption about this. So,
the update.configurator is marking each bundle it is responsible for by
installing it with location starting with update@. The framework core
also does something like that by marking the bundles from osgi.bundles
property with initial@
BR,
Danail
Karsten Panier wrote:
> Boyan Yurukov wrote:
>> Hello,
>> build a FileInputStream out of it. I tried with :
>> something like :
>> Thanks,
>> Boyan.
> I had similar problem. I need a InputStream on a Ressource in my Bundle.
> It works with:
> FileLocator.resolve(bundle().getEntry("relativePath"))
> If you use:
> FileLocator.resolve(bundle.getResource(bundle.getLocation()) )
> it should work.
> Hope that helps.
> Karsten
Re: Getting a bundles jar location [message #109129 is a reply to message #108736] |
Tue, 06 May 2008 08:23   |
Thanks for the help. There is however a problem with FileLocator.resolve:
with some configs it returns URLs like this one:
jar:file:D:\eclipse\plugins\org.eclipse.ui_3.3.1.M20070910-0 800b.jar!/
Then I pass that one to a FileInputStream, I get an error. I don't think
that a simple cutting of the jar: part will work in the general case. I also
tried
FileLocator.openStream(bundle, new Path("\"),null)
but I also get an exception.
I would appreciate any other ideas?
Boyan.
"Danail Nachev" <d.nachev@prosyst.bg> wrote in message
news:fup82i$buh$1@build.eclipse.org...
> BR,
> Danail
>>> Hello,
>>> something like :
>>> Thanks,
>>> Boyan.
>> It works with:
>> If you use:
>> it should work.
>> Hope that helps.
>> Karsten
Re: Getting a bundles jar location [message #109140 is a reply to message #109129] |
Tue, 06 May 2008 08:47   |
Another thing that might work in the general case:
Platform.getInstallLocation().getURL().toString()+bundle.get Location().substring(7)
It does work on my computer. If bundle.getLocation() always starts with
update@ there should be no problem.
Boyan.
"Boyan Yurukov" <Boyan.Yurukov@softwareag.com> wrote in message
news:fvpikf$37e$1@build.eclipse.org...
> also tried
> Boyan.
>> BR,
>> Danail
>>>> Hello,
>>>> something like :
>>>> Thanks,
>>>> Boyan.
>>> Hi,
>>> It works with:
>>> If you use:
>>> it should work.
>>> Hope that helps.
>>> Karsten
Re: Getting a bundles jar location [message #109153 is a reply to message #109140] |
Tue, 06 May 2008 09:02   |
Using the code I suggested, will give an URL which points to the root of
the bundle. In case a bundle is .jar file, it will be jar: URL, pointing
to the root of the jar file (as you already know:). In case of directory
bundle, it will point to the directory containing the bundle. So, if you
get jar: URL, you need to extract the file: URL inside.
What question arise? why do you need to get the location of the bundle
and use FileInputStream on it? Are you sure there isn't a better
solution for your problem?
BR,
Danail
> Boyan.
>> also tried
>> Boyan.
>>> BR,
>>> Danail
>>>>> Hello,
>>>>> something like :
>>>>> Thanks,
>>>>> Boyan.
>>>> Hi,
>>>> It works with:
>>>> If you use:
>>>> it should work.
>>>> Hope that helps.
>>>> Karsten
Re: Getting a bundles jar location [message #109164 is a reply to message #109153] |
Tue, 06 May 2008 09:32   |
I am writing a wizard that should take a plugin and all its required
plugins, pack them in a stream, send them through http and install them in
another eclipse. With BundleContext.installBundle I can install from a
stream on the target eclipse, so the only thing I need is to be able to get
all the bundles I need as streams on the source eclipse. Basically the task
can be narrowed down to getting a jar or folder of a plugin as an
inputstream.
I did the thing you said and extracted the location of a jar (file:...), but
then I found that I can't read it. File.canRead returns false, so I can't
create and inputstream. I guess the same will happen with a plugin installed
in a folder.
Another method I though of is reading all the files in a bundle, packing
them as a jar in a temp folder and streaming that though http. Haven't tried
it yet though.
Boyan.
news:fvpkt4$qbm$1@build.eclipse.org...
> BR,
> Danail
>> Boyan.
>>> also tried
>>> Boyan.
>>>> BR,
>>>> Danail
>>>>>> Hello,
>>>>>> something like :
>>>>>> Thanks,
>>>>>> Boyan.
>>>>> Hi,
>>>>> Bundle.
>>>>> It works with:
>>>>> If you use:
>>>>> it should work.
>>>>> Hope that helps.
>>>>> Karsten
Re: Getting a bundles jar location [message #109178 is a reply to message #109164] |
Tue, 06 May 2008 11:52   |
This is strange. If you extract the correct path, then File.canRead
should return true (how Eclipse itself reads this path). So, check that
the path you use for creating the File object is correct. If you have
trouble, can you post the:
- the result from FileLocator.resolve()
- the parameters to new File() or new FileInputStream()
Regarding the folders -> you'll need to detect and most probably need to
pack them before forwarding obviously:)
> inputstream.
> in a folder.
> it yet though.
> Boyan.
>> BR,
>> Danail
>>> Boyan.
>>>> also tried
>>>> Boyan.
>>>>> BR,
>>>>> Danail
>>>>>>> Hello,
>>>>>>> something like :
>>>>>>> Thanks,
>>>>>>> Boyan.
>>>>>> Hi,
>>>>>> Bundle.
>>>>>> It works with:
>>>>>> If you use:
>>>>>> it should work.
>>>>>> Hope that helps.
>>>>>> Karsten
Re: Getting a bundles jar location [message #109546 is a reply to message #109178] |
Tue, 13 May 2008 08:48  |
Oh my mistake - I parsed the address wrongly. It works fine. Thanks a lot
for the help.
Boyan.
news:fvpusk$gq9$1@build.eclipse.org...
>> in
>> get
>> task
>> inputstream.
>> but
>> installed
>> in a folder.
>> tried
>> it yet though.
>> Boyan.
>>> BR,
>>> Danail
>>>> Boyan.
>>>>> think
>>>>> I
>>>>> also tried
>>>>> Boyan.
>>>>>> So,
>>>>>> by
>>>>>> osgi.bundles
>>>>>> BR,
>>>>>> Danail
>>>>>>>> Hello,
>>>>>>>> to
>>>>>>>> something like :
>>>>>>>> Thanks,
>>>>>>>> Boyan.
>>>>>>> Hi,
>>>>>>> Bundle.
>>>>>>> It works with:
>>>>>>> If you use:
>>>>>>> it should work.
>>>>>>> Hope that helps.
>>>>>>> Karsten
Current Time: Tue Apr 29 02:16:58 EDT 2025
Powered by FUDForum. Page generated in 0.09679 seconds
