Home » Language IDEs » C / C++ IDE (CDT) » Adding variable to standard makefile
Adding variable to standard makefile [message #108525] Thu, 01 July 2004 16:26 Go to next message
Originally posted by: Juan.Abreu.spirentcom.com
Hello All,
I'm using the recent 3.0.0 Eclipse release with CDT 2.0M9. How can I
get/use ${project_name} in a standard Makefile? Is there a way to get the
build configuration into the Makefile (e.g. "Debug" or "Release")? Thanks
in advance.
Juan
Re: Adding variable to standard makefile [message #110339 is a reply to message #108525] Mon, 12 July 2004 08:33 Go to previous messageGo to next message
Hello once again,
Perhaps I need to add more detail ... I am actually building my C++ projects
with scons. I am calling scons from a makefile and could use information
such as project name and configuration to tune my build scripts.
Does anyone know the answer to my question? If it is an incredibly stupid
question and is inappropriate for this groups discussion please let me know
of a more appropriate place to post. Any feedback would be nice.
Juan
"Juan C. Abreu" <Juan.Abreu@spirentcom.com> wrote in message
news:cc1rvt$9if$1@eclipse.org...
> Hello All,
> in advance.
> Cheers,
> Juan
Re: Adding variable to standard makefile [message #110352 is a reply to message #110339] Mon, 12 July 2004 08:49 Go to previous messageGo to next message
Well, as you stated, you write the Makefile yourself.
Why not use the following approach:
TARGET = mytarget.exe
all: # Build release version
@echo "Building the Release"
$(MAKE) "C_DEBUG=" $(TARGET)
debug: # Build Debug version
$(TARGET): $(TARGET_OBJS)
$(CXX) -o $@ $^ $(LDFLAGS)
%.o: %.cpp
$(CXX) $(CXXFLAGS) -o $@ -c $<
# add file dependencies here or include autogenerated
Juan C. Abreu wrote:
> Hello once again,
> Juan
>>Hello All,
>>in advance.
>>Cheers,
>>Juan
Re: Adding variable to standard makefile [message #110616 is a reply to message #110352] Wed, 14 July 2004 08:23 Go to previous message
Thank you for the feedback. Via CDT in Eclipse you can choose to build
configurations such as "Release" or "Debug". The difference is usually
optimization and debug level. Since I am indeed writing my own makefile and
trying to keep it common for all build configurations, I need to be able to
pick up the current selection from the CDT environment. For example, if I
select my project properties and then select the "Release" configuration,
I'd like to be able to pick this information up in my makefile. Eclipse or
CDT handle building per configuration by having a unique makefile per build
configuration directory. I'd like to have one common makefile and
dynamically choose which configuration to build based on the present build
configuration chosen in CDT.
I hope this makes some sense. Thanks for your help.
Juan
"kesselhaus" <kesselhaus@gmx.net> wrote in message
news:ccu1b3$shq$1@eclipse.org...
> %.o: %.cpp
> > Hello once again,
projects
information
stupid
know
> > Juan
> >>Hello All,
the
> >>in advance.
> >>Cheers,
> >>Juan
Previous Topic:Cannot check out C files from CVS in new C-project
Next Topic:How to log debugger output
Current Time: Fri Sep 19 02:43:21 EDT 2025
Powered by FUDForum. Page generated in 0.04605 seconds
