Home » Eclipse Projects » GEF » Draw Table in the editor
Draw Table in the editor [message #107836] Wed, 03 December 2003 03:22 Go to next message
Hello all,
I want to have a table in the gef editor (as an editpart), what is the best
way to do that , taking in account that i want to have a header for the
table , be able to resize the cells , add border to the table,....
what figures can I use , what can be the edit parts to make(cell , row ,..
or what)
Re: Draw Table in the editor [message #107850 is a reply to message #107836] Wed, 03 December 2003 05:06 Go to previous messageGo to next message
Originally posted by: nospam.gmx.net
Hello Shady,
I managed to create a table similar to the one you described.
The components I used are the following: (I suggest, that you implement in
this order)
- the table editpart
- for each cell an own editpart
- for the tablefigure an own layoutmanager, which layouts your cells
(the most complicated part if you use colspan and rowspan)
- for the table-editpart an editpolicy, which creates the handles to
resize the cells (besides the handles to resize the table itself)
- handles consist of the handle-"figure", a locator, which tells the
handle the location where to rest and a resize tracker,
which handles drag and drop (resizing) and gives feedback to the
layoutmanager
- ( for the last two steps,have a look at the ResizableEditpolicy and copy
and adapt to your needs)
enjoy!
Regards, Ingo
"Shady Said" <sh_said@yahoo.com> wrote in message
news:bqk6bk$aeg$1@eclipse.org...
> Hello all,
best
> or what)
> Thanks
Re: Draw Table in the editor [message #107862 is a reply to message #107850] Wed, 03 December 2003 07:43 Go to previous messageGo to next message
What about the columns and rows ? did you need to make a column or row edit
part to hold the cells. The columns and rows may be useful to have separate
edit parts in order to handle things like header of the table and so.
<nospam@gmx.net> wrote in message news:bqkce2$i6l$1@eclipse.org...
> Hello Shady,
> this order)
> layoutmanager
copy
> enjoy!
> Regards, Ingo
> > Hello all,
> best
> > or what)
> > Thanks
Re: Draw Table in the editor [message #107875 is a reply to message #107862] Wed, 03 December 2003 08:57 Go to previous messageGo to next message
Hello Shady,
of course you can place the cells in seperate row or column editparts,
but the disadvantage is that these editparts have to know attributes (size
etc)
of the other editparts. Keep in mind, that a resizing of one cell affects
cells,
which are adjacent to this cell, which would be placed in a different
edipart.
My approach is that you control the layout , which means placement and size
of the cells,
in a central instance or algorithm, the table-layoutmanager. I store width
and height of the
columns and rows in arrays, whose values are applied to the cells by the
layout-algorithm.
Ingo
news:bqklma$tcc$1@eclipse.org...
edit
separate
> > Hello Shady,
in
> > this order)
> > layoutmanager
> copy
> > enjoy!
> > Regards, Ingo
> > > Hello all,
> > best
the
> > > or what)
> > > Thanks
Re: Draw Table in the editor [message #107891 is a reply to message #107862] Wed, 03 December 2003 09:04 Go to previous message
Ahem,
since many people are implementing a table layout,
what about a generic default table implementation (with resizability) as
part of GEF?
Or is this the job of the draw2D guys?
regards, Ingo
edit
separate
> > Hello Shady,
in
> > this order)
> > layoutmanager
> copy
> > enjoy!
> > Regards, Ingo
> > > Hello all,
> > best
the
> > > or what)
> > > Thanks
Previous Topic:Getting stared - PLEASE HELP! HIGHSCHOOL PROJECT!!!
Next Topic:Order of entries in property sheet
Current Time: Tue Oct 14 00:30:45 EDT 2025
Powered by FUDForum. Page generated in 0.03158 seconds
