Are separate plugin directories possible ? [message #107785] |
Thu, 06 October 2005 15:47 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: brian.compston.xxx.xxx
I would like to keep 'extra' plugins in a separate directory from the
plugins shipped with Eclipse. Is this possible ? and if it is what do I
need to do to achieve it ?
I'm sure I came across a reference somewhere on how to do this, I just
can't find it again !!
Brian Compston
Re: Are separate plugin directories possible ? [message #107985 is a reply to message #107785] |
Fri, 07 October 2005 17:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yes, it is possible.
The easiest way is to do Help > Software Updates > Manage Configuration
and from that dialog create a new "Extension Location" into which you
can install plugins (when using the Update Manager to install plugins
one of the steps allows you to choose the location - make sure to select
your new Extension Location instead of the default base Eclipse install
directory).
It is possible to do manually but I don't remember the details.
HTH,
Eric
FUDForum. Page generated in 0.08896 seconds
