Home » Eclipse Projects » DTP » how to filter out bin tables in oracle 10g
how to filter out bin tables in oracle 10g [message #9626] Fri, 24 March 2006 07:52 Go to next message
Originally posted by: davest.davest.com
using data tools and viewing oracle 10g, is there a way to filter out
BIN$*** tables from data explorer?
thanks,
dt
Re: how to filter out bin tables in oracle 10g [message #9706 is a reply to message #9626] Fri, 24 March 2006 14:09 Go to previous message
dt,
You can specify a table filter that will be applied when the SQL model is
populated. This will prevent the tables from being added to the SQl
model's table list.
There are two ways to specify the filter.
1. You can specify a default filter that will be used for all schema.
This filter is accessible through a property page on the connection
profile representing your database.
2. You can specify a table filter for a particular schema. This filter
can be accessed through a property page on the "Tables" folder contained
within a particular schema.
Note, currently the appropriate notification listeners are not
implemented/hooked up, so you will need to disconnect, then reconnect to
see the effects of the filtering you've applied.
Hope this helps.
Sincerely,
Rob
Re: how to filter out bin tables in oracle 10g [message #571738 is a reply to message #9626] Fri, 24 March 2006 14:09 Go to previous message
dt,
model's table list.
Hope this helps.
Sincerely,
Rob
Previous Topic:Data Binding VS Hibernate/Spring
Next Topic:in extending data source explorer
Current Time: Fri Oct 24 03:14:07 EDT 2025
Powered by FUDForum. Page generated in 0.03694 seconds
