Home » Archived » COSMOS » How and what to check out from CVS?
How and what to check out from CVS? [message #9616] |
Tue, 04 December 2007 12:52 |
Michael Moser Messages: 914 Registered: July 2009 |
I am a bit lost re. the cosmos CVS organization and how to convert
(parts of) it into eclipse projects again.
When I look into the CVS then the content seems to be a load of *nested*
Eclipse projects (some actually doubly nested)!
But - at least to my knowledge - Eclipse doesn't support "nested"
projects - or am I missing something here?
So, if I check out the top-node (org.eclipse.cosmos) I end up with a
strange mess of things. There is ONE big project, that contains
everything but nothing is built in it, because it's .project contains no
"buildSpecs" and no "natures". Then there is a list of maybe 20 projects
which are partly put into my \JavaDevt-folder (where I usually save
things), partly in my .workspace folder (no idea, who/what controls what
ends up where). Most of these projects show build and/or compile errors
because they can't find libraries or references to other projects etc.
The same holds true, if I check out the the next "layer" of nodes (i.e.
only data-collection or data-reporting individually).
Is one really supposed to traverse the CVS and check out all the
leaf-projects individually? There are, I would roughly estimate, about
50 of them, so this would take quite some effort and at least an hour
just to check out the files from CVS. Tell me, that this is NOT what is
expected, please!
So, what is the correct approach to get all or a subset (like
"data-collection") out of the CVS and building in optimal time?
Michael
Re: How and what to check out from CVS? [message #9640 is a reply to message #9616] |
Tue, 04 December 2007 14:50 |
I tried a trick to make eclipse iterate through the entire subtree and
regenerate all projects: I deleted (or rather renamed) all .project
files in higher layers (i.e. in ...cosmos, ...cosmos\data-collection,
....cosmos\resource-modeling, ...cosmos\test\data-collection, and
....cosmos\test\resource-modeling) and this made eclipse show me
ALL "leaf projects" when using "Import existing projects".
While doing so I had to learn, that two project-names "broker-server"
and "domain-server" exist twice, once in data-collection and once under
sandbox and test, resp.. BTW: it would be nice, if all projects would
stick to a common naming convention (org.eclipse.cosmos....) so that
they show up adjacent in the Package-Explorer. There are a few
"run-aways" (broker-server, domain-server, ...)
Other issues are: specific JREs listed as prereq's. E.g. does it REALLY
have to be 1.5.11? Wouldn't any 1.5 JRE do?
Furthermore:
I get 4 errors re. illegal wsdl:
Severity and Description Path Resource Location Creation Time Id
s4s-att-not-allowed: Attribute 'maxOccurs' cannot appear in element
'element'. broker-server/WebContent/WEB-INF/classes/wsdl MyService.wsdl
line 1298 1196779379492 2915
'element'. domain-server/WebContent/WEB-INF/classes/wsdl MyService.wsdl
line 1273 1196775687555 992
'element'. sandbox-broker-server/WebContent/WEB-INF/classes/wsdl
MyService.wsdl line 1297 1196775701320 1923
'element'. sandbox-domain-server/WebContent/WEB-INF/classes/wsdl
MyService.wsdl line 1273 1196775701477 1924
....and another 4 errors re. unsatisfied javax.wsdl constraints:
Unsatisfied constraint: 'Import-Package: javax.wsdl; version="1.6.1"'
org.eclipse.cosmos.dc.mgmt.wsdm/META-INF MANIFEST.MF line 11
1196779555164 3651
Unsatisfied constraint: 'Import-Package: javax.wsdl.factory;
version="1.6.1"' org.eclipse.cosmos.dc.dataManager/META-INF MANIFEST.MF
line 10 1196779536477 3039
version="1.6.1"' org.eclipse.cosmos.rm.sml.mdr/META-INF MANIFEST.MF line
14 1196779545586 3319
Unsatisfied constraint: 'Import-Package: javax.wsdl.xml;
version="1.6.1"' org.eclipse.cosmos.dc.mgmt.wsdm/META-INF MANIFEST.MF
line 12 1196779555164 3652
What javax.wsdl package is needed for this?
and finally, there are a couple of errors re. a missing JSON-Outputter:
IJSONOutputter cannot be resolved to a type
org.eclipse.cosmos.dr.tests/src/org/eclipse/cosmos/dr/drs/se rvice/handler/sml
JSONSMLOutputterTest.java line 124 1196779549383 3328
JSONSMLOutputterTest.java line 124 1196779549383 3329
JSONOutputterReader cannot be resolved to a type
JSONSMLOutputterTest.java line 71 1196779549383 3322
JSONSMLOutputterTest.java line 71 1196779549383 3323
NavigatorOutputter cannot be resolved to a type
JSONSMLOutputterTest.java line 92 1196779549383 3326
JSONSMLOutputterTest.java line 92 1196779549383 3327
Where's that JSON stuff supposed to come from?
Michael
Re: How and what to check out from CVS? [message #9663 is a reply to message #9616] |
Tue, 04 December 2007 15:50 |
No real name Messages: 404 Registered: July 2009 |
Hi Michael,
The CVS is structured based on COSMOS 4 subprojects:
1) data-collection
2) data-reporting
3) management-enablement
4) resource-modeling
The plug-ins under the subprojects are what gets regularly build.
In addition to the 4 root folders listed above, there are a few other
folders that are used for various reasons:
* doc - Used for documentations
* examples - Contains samples that illustrate the usage of the COSMOS
framework
* releng - Contains release engineering resources
* sandbox - Place holder for experimental code that is not yet ready to be
included as part of the build
* tests - Contains testing resources for plug-ins that belong to each
subproject
What you need really depends on what you intend to do with COSMOS. I
recommend reviewing the consumer documentations available on COSMOS website:
http://www.eclipse.org/cosmos/home/documents/
Good luck,
Ali Mehregani
"Michael Moser" <mmo@zurich.ibm.com> wrote in message
news:fj3ij1$oen$1@build.eclipse.org...
>I am a bit lost re. the cosmos CVS organization and how to convert (parts
> strange mess of things. There is ONE big project, that contains everything
> but nothing is built in it, because it's .project contains no "buildSpecs"
> and no "natures". Then there is a list of maybe 20 projects which are
> partly put into my \JavaDevt-folder (where I usually save things), partly
> in my .workspace folder (no idea, who/what controls what ends up where).
> Most of these projects show build and/or compile errors because they can't
> leaf-projects individually? There are, I would roughly estimate, about 50
> of them, so this would take quite some effort and at least an hour just to
> check out the files from CVS. Tell me, that this is NOT what is expected,
> please!
> Michael
Re: How and what to check out from CVS? [message #9684 is a reply to message #9640] |
Tue, 04 December 2007 16:26 |
For IBM JREs., any 1.5 version will do. For Sun JREs, we specifically
mention a minimum level of 1.5.0_13 because some components that use SAX
parsing, such as the CMDBf toolkit and the SML-IF validator, fail to
operate correctly on previous Sun 1.5 implementations, due to an
apparent Sun bug. It appears that IBM fixed the bug in Sun source long
before Sun got around to it.
David
Re: How and what to check out from CVS? [message #570775 is a reply to message #9616] |
Furthermore:
1196779555164 3651
Michael
Re: How and what to check out from CVS? [message #570808 is a reply to message #9616] |
Hi Michael,
1) data-collection
2) data-reporting
framework
subproject
Good luck,
Ali Mehregani
> please!
> Michael
Current Time: Sun Oct 06 09:31:58 GMT 2024
Powered by FUDForum. Page generated in 0.05608 seconds
