Home » Archived » Visual Editor (VE) » Update Window1 from Window2
Update Window1 from Window2 [message #105831] Thu, 08 September 2005 10:26 Go to next message
Originally posted by: bp.maximuss.dk
Hi NG
I have a little problem. I have an application where i have a main window
(win1) and a pop-up window (win2). My problem is that when i open win2 and
do some stuff in it and hit the "ok" button, i need to have a List and a
Tabel that i need to update with the new data that will be saved in my
database when the "ok" button in win2 is pressed (win2 is then closed)
If somebody have a little gui that i can look after or a good explanation
on how to do it, i will preciate it very much
Greetings from Denmark
MaxiCom
v/Bjarne Pedersen
Re: Update Window1 from Window2 [message #105948 is a reply to message #105831] Thu, 08 September 2005 16:59 Go to previous message
Originally posted by: eldzino.gmail.com
hi Bjarne,
make a class instance storing all the information that you wanna store
in the DB and fill it in win2.. after hitting OK button in modal dialog
pane, you can access the filled instance in win1 by some method like
getReturnedInstance and in win1 write to DB...
good luck
Bjarne wrote:
> Hi NG
> MaxiCom
> v/Bjarne Pedersen
Re: Update Window1 from Window2 [message #610718 is a reply to message #105831] Thu, 08 September 2005 16:59 Go to previous message
hi Bjarne,
good luck
Bjarne wrote:
> Hi NG
> MaxiCom
> v/Bjarne Pedersen
Previous Topic:Changing active TabItem in VE
Next Topic:VEP install problem? Or did I miss something stupid?
Current Time: Sun Nov 02 16:42:08 EST 2025
Powered by FUDForum. Page generated in 0.62180 seconds
