Home » Modeling » GMF (Graphical Modeling Framework) » Meaning of Ecore
Meaning of Ecore [message #105733] Wed, 21 February 2007 05:20 Go to next message
Originally posted by: imrannawaz.softtrans.net
Hi ,
Please explain me what is the use of .ecore file Or the functionality of
Ecore in GMF
Imran
Re: Meaning of Ecore [message #105768 is a reply to message #105733] Wed, 21 February 2007 07:05 Go to previous message
--------------060204030905060502030809
Imran,
Ecore, much like XML Schema and UML, is used to define the structure
(abstract syntax) of a model. So you'd use it to define what types of
things you will be editing, i.e., your domain model, and using EMF, you
would use that description to generate a Java realization of that model.
On top of this basis, GMF defines models, using also Ecore, for
representing information about how your domain model will ultimately be
mapped on to the graphical editing surface. Models, models everywhere
and they are all defined with Ecore. Probably it's worth while to read
this introduction:
http://dev.eclipse.org/viewcvs/indextools.cgi/org.eclipse.em f/doc/org.eclipse.emf.doc/references/overview/EMF.html
imran wrote:
> Hi ,
> Ecore in GMF
> Thanks
> Imran
<html>
<head>
</head>
Imran,<br>
<br>
(abstract syntax) of a model.&nbsp; So you'd use it to define what types of
model. &nbsp; On top of this basis, GMF defines models, using also Ecore,
for representing information about how your domain model will
ultimately be mapped on to the graphical editing surface.&nbsp; Models,
models everywhere and they are all defined with Ecore.&nbsp; Probably it's
worth while to read this introduction:<br>
<blockquote>&nbsp;<a
href=" http://dev.eclipse.org/viewcvs/indextools.cgi/org.eclipse.em f/doc/org.eclipse.emf.doc/references/overview/EMF.html"> http://dev.eclipse.org/viewcvs/indextools.cgi/org.eclipse.em f/doc/org.eclipse.emf.doc/references/overview/EMF.html</a><br>
</blockquote>
<br>
imran wrote:
<blockquote cite="miderh6d0$c5u$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi ,
Ecore in GMF
Imran
</pre>
</blockquote>
<br>
</body>
</html>
--------------060204030905060502030809--
Previous Topic:RowLayout
Next Topic:bending a polyline
Current Time: Tue Apr 29 02:46:13 EDT 2025
Powered by FUDForum. Page generated in 0.27795 seconds
