[ATL] several Resources in a ResourceSet [message #105706] |
Wed, 27 May 2009 07:02  |
Hi all,
If a resource set (for the source model) contains several resources it
seems like the transformation considers only the first one.
Is there a way that all Resources are processed?
Henrik
Re: [ATL] several Resources in a ResourceSet [message #106360 is a reply to message #106299] |
Tue, 09 June 2009 08:38  |
Here you can find documentation about that concepts:
http://wiki.eclipse.org/ATL/Developer_Guide#Core
The part you want to extend is defined under the following plugin:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.core/?root=Mode ling_Project
And here you can find two implementations of the core concepts (IModel,
ModelFactory and so on):
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.core.emf/?root= Modeling_Project
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.core.ui.vm/?roo t=Modeling_Project
William
Henrik Rentz-Reichert a écrit :
> Andy,
> sure, they take models. But if I use EMF models somewhere a
> EMFModelFactory and a EMFInjector enter the game.
> Does that mean (provided the pre-installed factories behave not the way
> I like) I have to register my own versions?
> And if so, can you point me to an example how this is done?
> Henrik
> Andy Carpenter wrote:
>> Henrik,
>> ATL transformations take one or more models as input, they do not
>> talke a resource set.
>> Andy.
>> "Henrik Rentz-Reichert" <hrr@protos.de> wrote in message
>> news:h0l0e2$gsp$1@build.eclipse.org...
>>> to be more precise I should add that the Resources are not cross-linked
>>> by EMF References
>>> Henrik Rentz-Reichert wrote:
>>>> Hi all,
>>>> Regards,
>>>> Henrik
FUDForum. Page generated in 0.02926 seconds
