gla adapter [message #9550] |
Wed, 09 March 2005 15:30 |
Originally posted by: mujtaba.alsaif.brunel.ac.uk
hi,
i was wondering if it was possible to setup wild cards to import in the
log files rather then predefine the logs files?
Mujtaba
Re: gla adapter [message #13428 is a reply to message #11357] |
Fri, 01 April 2005 17:58 |
Originally posted by: nobody.nobody.com
Mujtaba,
That functionality is available starting in Hyades 3.2. You can use regular
expressions in the log file field in the import wizard to specify multiple
files (of the same type) to import.
Here is the note in the Log And Trace documentation:
Note 2: You can import multiple log files at once by specifying a regular
expression in the path field. For example, to import all the logs in the
d:\temp directory, enter d:\temp\.* in the field. Follow the regurlar
expression rules of java.util.regex.Pattern.
The GLA runtime supports regular expressions for the fileName field in the
sensor component configuration.
Dave
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:d1mtd1$ihk$1@news.eclipse.org...
> Hi Mujtaba,
> Unfortunately, this function is not supported. Please open an
> enhancement request:
> http://www.eclipse.org/tptp/ >> Submit Enhancements and Bugs
> Paul
> "mujtaba" <mujtaba.alsaif@brunel.ac.uk> wrote in message
> news:d0n4rg$5em$1@www.eclipse.org...
> > hi,
> > Mujtaba
FUDForum. Page generated in 0.03481 seconds
