Java 5.0 for Mac????? [message #104712] |
Mon, 26 September 2005 00:28 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: matthew.kahl.gmail.com
I am taking an introductory to java class and have had trouble compiling
in 5.0. Basically, the scanner class is not recognized and it says that my
Mac OS X Default is Java 1.4.2. I did download from Apple's website the
J2SE 5.0 but am not able to compile still. I am not sure if this was the
incorrect thing to download, I am very new to the java environment. Does
anyone know how I can compile in 5.0?
Re: Java 5.0 for Mac????? [message #104822 is a reply to message #104712] |
Mon, 26 September 2005 12:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <36a7ba6aa49cc329c171c13c6bac6a6a$1@www.eclipse.org>,
matthew.kahl@gmail.com says...
Did you download and install the JRE or the SDK? YOu need an SDK
installed in order to compile java progs.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: Java 5.0 for Mac????? [message #106049 is a reply to message #104822] |
Thu, 29 September 2005 15:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Technically, a 5.0 JRE is all you need to compile Java 5.0 programs in
Eclipse, since Eclipse provides its own Java 5.0 compiler.
Re: Java 5.0 for Mac????? [message #126699 is a reply to message #106049] |
Thu, 29 December 2005 22:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: not_monitored.example.com
"John Arthorne" <john@eclipsefaq.org> wrote in message
news:dhh1rt$3hj$2@news.eclipse.org...
At the time this thread was started, 1.4 was the default even if you had 1.5
installed. With the latest version of the JRE 1.5 is default.
FUDForum. Page generated in 0.08863 seconds
