| Escape to go to default tool [message #104650] |
Wed, 12 November 2003 10:30  |
When you select a tool from the palette, there is no way to go back to the
default tool (selection tool) unless explicitly selecting it. Should there
be support for the Esc key in tools to go back to the default tool?
Maged
| Re: Escape to go to default tool [message #104701 is a reply to message #104692] |
Wed, 12 November 2003 12:53   |
You could map a key->action in the palette's keyhandler.
Or, create a ResetToolAction and add it to the keybinding service, so that
ESC is received regardless of focus. But, this would interfere with
celleditors, which need to receive ESC
"Maged Elaasar" <melaasar@ca.ibm.com> wrote in message
news:botrep$qpk$1@eclipse.org...
> Can't it be supported also if the palette viewer has a focus, since the
> normal use case would be to select a tool, hover on the graphical viewer
and
> then pressing Esc to cancel. Currently, the user has to use the "tab" key
to
> give focus first to the graphical viewer before Esc works. What do you
> think?
> "Randy Hudson" <none@us.ibm.com> wrote in message
> news:botqp3$pub$1@eclipse.org...
> > Escape works for me, provided that the graphical viewer has keyboard
> focus.
> > news:botjjq$ghb$1@eclipse.org...
> > > Hello,
> the
> there
> > > Maged
| Re: Escape to go to default tool [message #104723 is a reply to message #104701] |
Wed, 12 November 2003 14:47   |
The first solution seems more reasonable (i.e: let the palette key handler
do it).
Shouldn't that be done in the default PaletteKeyHandler in GEF?
news:botrvv$rgp$1@eclipse.org...
> and
key
> to
> > think?
> > focus.
> > > > Hello,
to
> > the
> > there
> > > > Maged
| Re: Escape to go to default tool [message #104733 is a reply to message #104723] |
Wed, 12 November 2003 16:58  |
Sure, why not? Open a bugzilla. For 2.1.x you'll have to add it yourself.
news:bou2lm$3jp$1@eclipse.org...
> do it).
that
the
viewer
> > and
> key
> > to
> > > think?
> > > focus.
> > > > > Hello,
back
> to
> > > the
Should
> > > there
tool?
> > > > > Maged
FUDForum. Page generated in 0.35049 seconds
