Re: Missing Constraint: Require-Bundle: org.eclipse.rap.ui.workbench; bundle-version [message #104645 is a reply to message #104631] |
Thu, 11 September 2008 11:17 |
Stefan Messages: 316 Registered: July 2009 |
it seems as if your bundle com.ifbag.ziris.position.rcp has a dependency
to org.eclipse.ui. The latter and org.eclipse.rap.ui share the same
namespaces so that might be the reason for your problems.
Stefan.
Barthel.Steckemetz@googlemail.com schrieb:
> We wrote a small demo application using RAP.
> It works quite well on two machines but fails to start in eclipse
> on another machine. We copied the workspace, the target platform and
> the eclipse installation. So everything should be exactly the same.
> The logfile in
> ${workspace}/.metadata/.plugins/org.eclipse.pde.core/ZirisWe b
> contain several error messages about bundle version mismatch (see below).
> But we dont use bundle versions in our bundle descriptors like MANIFEST.MF:
> Is there anything else we can do about that ?
> !SESSION 2008-09-11 10:06:36.531
> eclipse.buildId=unknown
> java.version=1.5.0_16
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
> Command-line arguments: -dev
> file:C:/workspaces/Versuch2ZirisOkularWeb/.metadata/.plugins /org.eclipse.pde.core/ZirisWeb/dev.properties
> -os win32 -ws win32 -arch x86 -console
> !ENTRY org.eclipse.rap.ui 4 0 2008-09-11 10:06:37.937
> !MESSAGE !STACK 0
> org.osgi.framework.BundleException: The bundle could not be resolved.
> Reason: Missing Constraint: Require-Bundle:
> org.eclipse.rap.ui.workbench; bundle-version="[1.1.0,2.0.0)"
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
> at
> org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:489)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:321)
> !ENTRY com.ifbag.ziris.position.web 4 0 2008-09-11 10:06:38.000
> !MESSAGE !STACK 0
> Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui;
> bundle-version="0.0.0"
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.rap.ui.views 4 0 2008-09-11 10:06:38.016
> !MESSAGE !STACK 0
> bundle-version="[1.1.0,4.0.0)"
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.rap.demo 4 0 2008-09-11 10:06:38.672
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.rap.ui.workbench 4 0 2008-09-11 10:06:38.688
> !MESSAGE !STACK 0
> org.eclipse.rap.jface.databinding; bundle-version="[1.1.0,2.0.0)"
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.rap.jface.databinding 4 0 2008-09-11 10:06:38.688
> !MESSAGE !STACK 0
> org.eclipse.core.databinding; bundle-version="[1.0.0,2.0.0)"
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.rap.demo.databinding 4 0 2008-09-11 10:06:38.735
> !MESSAGE !STACK 0
> org.eclipse.rap.jface.databinding; bundle-version="0.0.0"
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY com.ifbag.ziris.position 4 0 2008-09-11 10:06:38.781
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY com.ifbag.ziris.position.rcp 4 0 2008-09-11 10:06:38.797
> !MESSAGE !STACK 0
> Reason: Missing Constraint: Require-Bundle: org.eclipse.ui;
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.osgi 4 0 2008-09-11 10:06:38.813
> !MESSAGE Bundle
> initial@reference :file:../../../workspaces/Versuch2ZirisOkularWeb/com.ifbag.z iris.position/
> was not resolved.
> !MESSAGE Bundle
> initial@reference :file:plugins/org.eclipse.rap.demo.databinding_1.1.0.2008061 3-1055.jar/
> was not resolved.
> !MESSAGE Bundle
> initial@reference :file:plugins/org.eclipse.rap.ui.workbench_1.1.0.20080613-10 55.jar/
> was not resolved.
> !MESSAGE Bundle
> initial@reference:file:plugins/org.eclipse.rap.ui_1.1.0.20080613-1055.jar/
> was not resolved.
> !ENTRY org.eclipse.osgi 4 0 2008-09-11 10:06:38.828
> !MESSAGE Bundle
> initial@reference :file:plugins/org.eclipse.rap.jface.databinding_1.1.0.200806 13-1055.jar/
> was not resolved.
> !MESSAGE Bundle
> initial@reference :file:plugins/org.eclipse.rap.ui.views_1.1.0.20080613-1055.j ar/
> was not resolved.
> !MESSAGE Bundle
> initial@reference :file:../../../workspaces/Versuch2ZirisOkularWeb/com.ifbag.z iris.position.rcp/
> was not resolved.
> !MESSAGE Bundle
> initial@reference:file:plugins/org.eclipse.rap.demo_1.1.0.20080613-1055.jar/
> was not resolved.
> !MESSAGE Bundle
> initial@reference :file:../../../workspaces/Versuch2ZirisOkularWeb/com.ifbag.z iris.position.web/
> was not resolved.
FUDForum. Page generated in 0.03922 seconds
