Home » Archived » Test and Performance Tools Platform (TPTP) » Profiling with Tomcat 5.x
Profiling with Tomcat 5.x [message #9479] Tue, 08 March 2005 20:25 Go to next message
Originally posted by: webmail.andreaundstefanhoehn.de
Is there any guide how to profile an application within Tomcat?
TIA
Stefan
Re: Profiling with Tomcat 5.x [message #10248 is a reply to message #9479] Sun, 13 March 2005 15:09 Go to previous messageGo to next message
Here's a nifty way of profiling your Tomcat applications:
1) I use the sysdeo plugin to create my tomcat applications:
http://www.sysdeo.com/eclipse/tomcatPlugin.html
2) Once you have successfully downloaded this plugin, go to
Window->Preferences->Tomcat->JVM Setting and add the following
line under "Append to JVM Parameters":
-Xrunpiagent:server=enabled
3) Run your tomcat server using the tool bars that sysdeo provides
4) Attach to the profiling agent by going to Profile(using the toolbar
button) -> Attach-Java Process-> New
Switch the Agent tab, select your agent and click on profile
(Use the filter options to only profile what you need)
Once you have successfully attached to your agent, profiling data will be
collected once you interact with your agent.
"Stefan Hoehn" <webmail@andreaundstefanhoehn.de> wrote in message
news:d0lja3$f80$1@www.eclipse.org...
> TIA
> Stefan
Re: Profiling with Tomcat 5.x [message #10447 is a reply to message #9479] Mon, 14 March 2005 15:50 Go to previous message
Originally posted by: jim.jimvanfleet.com
> TIA
> Stefan
A newbie-friendly (hopefully!) version is at
http://devblog.jimvanfleet.com/archives/000076.html
Jim
Previous Topic:Eclipse oprofile on AMD64
Next Topic:Remote profiling can't find matching source....
Current Time: Thu Feb 27 20:43:44 EST 2025
Powered by FUDForum. Page generated in 0.02672 seconds
