Re: XSDPrototypicalSchema and classpath [message #9619 is a reply to message #9474] |
Fri, 24 January 2003 12:30 |
--------------0D4238572DE60F0835D31306
Content-Type: text/plain; charset=us-ascii
Andy,
There have been some changes in EMF. If you look in the latest version of
XSDPrototypicalSchema you'll see that it's now expressed as:
XSDPlugin.INSTANCE.getString...
Andy Yang wrote:
> Hi All,
> I'm trying to run the sample code that came with the article "Analyze
> Schemas with the XML Schema Infoset Model" by Shane Curcuru.
> I've downloaded the xsd and emf distributions from eclipse.org and set
> them up as external jar files from WSAD 5. I've put the following jars
> in my build path:
> org.eclipse.emf.common_1.0.1\runtime\common.jar
> org.eclipse.emf.ecore_1.0.1\runtime\ecore.jar
> org.eclipse.xsd_1.0.1\runtime\xsd.jar
> but I'm getting the following compile error:
> The method getString(java.lang.String) from the type
> org.eclipse.emf.common.EMFPlugin is not static
> on the following statement:
> XSDPlugin.getString
> ("_UI_DiagnosticFileLineColumn_message",
> new Object []
> localizedSeverity,
> xsdDiagnostic./*{@link XSDDiagnostic#getLocationURI
> */getLocationURI/*}*/(),
> new Integer(xsdDiagnostic./*{@link
> XSDDiagnostic#getLine */getLine/*}*/()),
> XSDDiagnostic#getColumn */getColumn/*}*/())
> in XSDPrototypicalSchema.java
> Should I be using an earlier release of emf?
> Andy
Ed Merks
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Andy,
<p>There have been some changes in EMF. If you look in the latest
version of XSDPrototypicalSchema you'll see that it's now expressed as:
<blockquote>XSDPlugin<b>.INSTANCE.</b>getString...</blockquote >
<p><br>Andy Yang wrote:
<blockquote TYPE=CITE>Hi All,
<p>I'm trying to run the sample code that came with the article "Analyze
<br>Schemas with the XML Schema Infoset Model" by Shane Curcuru.
<p>I've downloaded the xsd and emf distributions from eclipse.org and set
<br>them up as external jar files from WSAD 5. I've put the following jars
<br>in my build path:
<p>org.eclipse.emf.common_1.0.1\runtime\common.jar
<br>org.eclipse.emf.ecore_1.0.1\runtime\ecore.jar
<br>org.eclipse.xsd_1.0.1\runtime\xsd.jar
<p>but I'm getting the following compile error:
<p>The method getString(java.lang.String) from the type
<br>org.eclipse.emf.common.EMFPlugin is not static
<p>on the following statement:
<p>XSDPlugin.getString
<br>
<br>
new Object []
<br>
<br>
localizedSeverity,
<br>
<br>*/getLocationURI/*}*/(),
<br>
<br>XSDDiagnostic#getLine */getLine/*}*/()),
<br>
<br>XSDDiagnostic#getColumn */getColumn/*}*/())
<br>
<p>in XSDPrototypicalSchema.java
<p>Should I be using an earlier release of emf?
<p>Thanks,
<br>Andy</blockquote>
<p>--
<br>Ed Merks
<br> </html>
--------------0D4238572DE60F0835D31306--
Re: XSDPrototypicalSchema and classpath [message #564934 is a reply to message #9474] |
Ed Merks Messages: 33224 Registered: July 2009 |
Andy,
Andy Yang wrote:
> Hi All,
> in my build path:
> XSDPlugin.getString
> new Object []
> localizedSeverity,
> Andy
Ed Merks
<html>
Andy,
<br>
<br>
new Object []
<br>
<br>
localizedSeverity,
<br>
<br>
<br>
<br>
<p>Thanks,
<p>--
<br>Ed Merks
<br> </html>
Ed Merks
FUDForum. Page generated in 0.03176 seconds
