Home » Archived » BIRT » Unable to run org.eclipse.birt.chart.examples.api.viewer.SwtChartViewerSelector
Unable to run org.eclipse.birt.chart.examples.api.viewer.SwtChartViewerSelector [message #103613] Tue, 03 January 2006 11:57 Go to next message
Originally posted by: Marco.xxxxxxxxx.com
I am using eclipse 3.1.1, birt 1.0.1, emf 2.1.1, gef 3.1.1 and have
downloaded
birt-sample-plugins-1_0_1.zip but I cannot get its
"SwtChartViewerSelector" to run. I get:
Jan 3, 2006 4:38:36 PM
org.eclipse.birt.core.framework.server.ServerPlatform <init>
WARNING: No plugins in BIRT_HOME:
/c:/Eclipse/3.1.1/eclipse/plugins/org.eclipse.birt.core_1.0. 1/, make sure
this directory is correct!
Jan 3, 2006 4:38:36 PM org.eclipse.birt.chart.log.impl.JavaUtilLoggerImpl
log
SEVERE: Exception
org.eclipse.birt.chart.exception.ChartException: Unable to locate any
entries for lookup=dv.SWT; element=(name:device) in any plugin.xml file in
all of the available plugins
org.eclipse.birt.chart.util.PluginSettings.getPluginXmlObjec t(PluginSettings.java:675)
org.eclipse.birt.chart.util.PluginSettings.getDevice(PluginS ettings.java:338)
org.eclipse.birt.chart.examples.api.viewer.SwtChartViewerSel ector. <init>(SwtChartViewerSelector.java:153)
org.eclipse.birt.chart.examples.api.viewer.SwtChartViewerSel ector.main(SwtChartViewerSelector.java:76)
java.lang.UnsatisfiedLinkError: no swt-win32-3139 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:125)
org.eclipse.birt.chart.examples.api.viewer.SwtChartViewerSel ector.main(SwtChartViewerSelector.java:80)
Can anybody help?
Marco
Re: Unable to run org.eclipse.birt.chart.examples.api.viewer.SwtChartViewerSelector [message #103667 is a reply to message #103613] Tue, 03 January 2006 13:42 Go to previous messageGo to next message
Hi Marco,
You need to start the application with -DSTANDALONE. This will load the
original chart plugins, including the SWT renderer.
If you extend some chart plugins you can set -DBIRT_HOME=dir_name instead,
where dir_name\plugins\ contains the chart plugins and your extension
plugins.
David
"Marco" <Marco@xxxxxxxxx.com> wrote in message
news:c1471f7f29b991a8eae6dda686bb1157$1@www.eclipse.org...
> Hello,
> downloaded
> log
> SEVERE: Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Can anybody help?
> Thanks
> Marco
Re: Unable to run org.eclipse.birt.chart.examples.api.viewer.SwtChartViewerSelector [message #103811 is a reply to message #103667] Wed, 04 January 2006 04:19 Go to previous message
Originally posted by: Marco.xxxxx.com
Thanks David. It works fine now.
Marco
Previous Topic:Help: supplying connection to BIRT
Next Topic:Hyperlink question
Current Time: Thu Nov 20 14:28:18 EST 2025
Powered by FUDForum. Page generated in 0.03992 seconds
