Home » Newcomers » Newcomers » How to exclude code from Code Formatter?
How to exclude code from Code Formatter? [message #103019] Mon, 19 September 2005 10:47 Go to next message
Is it possible to exclude manually beautified code from the
Code Formatter in the Java editor?
Are there any tags or annotations to tell the Code Formatter not
to touch a section of code?
Re: How to exclude code from Code Formatter? [message #109440 is a reply to message #103019] Fri, 14 October 2005 11:20 Go to previous messageGo to next message
Originally posted by: rjsteg.mail.com
Hi Lophiomys,
I'm sure that by now you realize there is no way to prevent code from
being refomatted when you hit Ctrl-Shift-F.
When I saw your question, I realized that I would love this feature. Why
don't you submit an enhancement request into the Eclipse bug database?
How would you tag the code? With Lint like comments - /* BEGIN - NO
FORMAT */. Or with java doc style - /** @stopFormat */ then /**
@beginFormat */.
Sorry,
Randy Stegbauer.
Re: How to exclude code from Code Formatter? [message #109787 is a reply to message #109440] Mon, 17 October 2005 10:56 Go to previous message
Originally posted by: wojtek.a.com
Randy Stegbauer wrote:
> Hi Lophiomys,
> Why don't you submit an enhancement request into the Eclipse bug
> database? How would you tag the code? With Lint like comments - /*
> BEGIN - NO FORMAT */. Or with java doc style - /** @stopFormat */ then
> /** @beginFormat */.
I think it would be best to use the already defined syntax for things like
// TODO
so
// NO FORMAT - BEGIN
// NO FORMAT - END
Previous Topic:half a button is not a button
Next Topic:Line wrap in Eclipse standart editor
Current Time: Wed Jul 02 08:32:01 EDT 2025
Powered by FUDForum. Page generated in 0.32481 seconds
