Home » Eclipse Projects » Remote Application Platform (RAP) » Optimization/Performance
Optimization/Performance [message #102998] |
Sat, 23 August 2008 00:13 |
Walter Mising name Messages: 128 Registered: July 2009 |
Dear RAP Team,
Keep up the good work.
While looking for ways of optimizing my site, I came across
http://www.websiteoptimization.com/services/analyze/ which had given
pointers on what could be improved.
Here is the result for ( www.propertymapz.com/index.html )
Analysis and Recommendations
TOTAL_HTML - Congratulations, the total number of HTML files on this page
(including the main HTML file) is 1 which most browsers can multithread.
Minimizing HTTP requests is key for web site optimization.
TOTAL_OBJECTS - Congratulations, the total objects on this page (including
the HTML) is 2 which most browsers can multithread. Minimizing HTTP requests
TOTAL_CSS - Congratulations, the total number of external CSS files on this
page is 1 . Because external CSS files must be in the HEAD of your HTML
document, they must load first before any BODY content displays. Although
they are cached, CSS files slow down the initial display of your page.
TOTAL_SIZE - Warning! The total size of this page is 184088 bytes, which
will load in 37.09 seconds on a 56Kbps modem. Consider reducing total page
size to less than 30K to achieve sub eight second response times on 56K
connections. Pages over 100K exceed most attention thresholds at 56Kbps,
even with feedback. Consider contacting us about our optimization services.
HTML_SIZE - Warning! The total size of this HTML page is 184087 bytes, which
is over 100K! Consider optimizing your HTML and eliminating unnecessary
content and features.
CSS_SIZE - Congratulations, the total size of your external CSS is 1 bytes,
which is less than 4080 bytes. This will fit into three higher-speed TCP-IP
packets.
MULTIM_SIZE - Congratulations, the total size of all your external
multimedia files is 0 bytes, which is less than 4K.
---------End---------------
Only problem reported by the analyzer is that the HTML generated is 184K and
suggests that it be kept under 100K.
1. While looking into the html generated by RAP framework, I had observed
that there are multiple Copyright messages which is about 7K.
2. Another option to look at is to be more modular in excluding some of the
widget implementations
Eg.
My website does not use CTabFolder, Tree etc. If there is a way to
specify ( thru some configuration ) to exclude
org.eclipse.swt.custom.CTabFolder and other related classes such as
CTabItem, the size of the HTML will come down a bit.
3. Consider compressing JS variables and strip down the comments using
some configuration.
The ultimate objective of any web site is its Richness and Speed.
While speed might not be of a concern in some of the developed countries,
most 3rd wold countries are yet to have powerful infrastructure.
Approx Download Times as reported by the weboptimization.com is as follows
Connection Rate Download Time
14.4K 143.08 seconds
28.8K 71.74 seconds
33.6K 61.55 seconds
56K 37.09 seconds
ISDN 128K 11.64 seconds
T1 1.44Mbps 1.38 seconds
I started to probe on the performance only after I had got some feedback
about performance.
I hope RAP team will address this issue going forward.
Best Regards,
Walter G. Prabhakar.
Re: Optimization/Performance [message #103349 is a reply to message #102998] |
Fri, 29 August 2008 06:25 |
Originally posted by: fappel.innoopract.com
Hi Walter,
thank you for your input on startup performance. I've filed a bug
regarding this problem, see:
245633: Improve session startup performance
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245633
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Walter Prabhakar [mailto:kwchess@gmail.com]
Bereitgestellt: Samstag, 23. August 2008 02:14
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Optimization/Performance
Betreff: Optimization/Performance
Dear RAP Team,
page
(including
requests
this
Although
page
services.
which
bytes,
TCP-IP
packets.
and
observed
the
Eg.
using
some configuration.
countries,
follows
28.8K 71.74 seconds
33.6K 61.55 seconds
56K 37.09 seconds
about performance.
Best Regards,
Current Time: Fri Sep 27 23:07:55 GMT 2024
Powered by FUDForum. Page generated in 0.04106 seconds
