[buckminster-dev] headless resolve with new r08988 [message #9365] |
Wed, 12 March 2008 19:46 |
Todd Lee Messages: 44 Registered: July 2009 |
Member |
Thanks again Thomas,
I grabbed the new product package and made my local installation, but I
seem to get PDE errors now that seem to point to cached maps...
C:\autobuild_root>buckminster -L INFO -data C:\autobuild_root\temp resolve
--bomfile C:\autobuild_root\buckminster.bom
http://sam/ide/updates/dev/build.cquery
WARN: Unregognized component type '#plugin' in PDE map file C:\Documents
and Settings\leet\Local Settings\Temp\bucky49405.tmp\ant.map
WARN: Unregognized component type '#base.plugin' in PDE map file
C:\Documents and Settings\leet\Local Settings\Temp\bucky49405.tmp\base.map
WARN: No fetch factory found for id 'HEAD' in PDE map file C:\Documents
and Settings\leet\Local Settings\Temp\bucky49405.tmp\core.map
and Settings\leet\Local Settings\Temp\bucky49405.tmp\equinox-incubator.map
WARN: Unregognized component type '#feature' in PDE map file C:\Documents
and Settings\leet\Local Settings\Temp\bucky49405.tmp\p2.map
and Settings\leet\Local Settings\Temp\bucky49405.tmp\releng.map
and Settings\leet\Local Settings\Temp\bucky49405.tmp\swt.map
ERROR [0003] : Unable to delete:
C:\DOCUME~1\leet\LOCALS~1\Temp\bucky49405.tmp\userassist.map
Here's the info for my local install
C:\autobuild_root>buckminster -L DEBUG listsite
listsite
Features:
org.eclipse.buckminster.core.headless.feature_1.0.0.r08990 (Buckminster -
Core Headless)
org.eclipse.buckminster.cvs.headless.feature_1.0.0.r08989 (Buckminster -
CVS support for headless operation)
org.eclipse.buckminster.maven.feature_1.0.0.r08939 (Buckminster - Maven
support)
org.eclipse.buckminster.pde.headless.feature_1.0.0.r08990 (Buckminster -
PDE support for headless operation)
org.eclipse.buckminster.product_1.0.0.r08988 (Buckminster Product)
Am I missing something or is it an issue with the PDE map resolver/cached
maps?
T
Thomas Hallgren
<thomas@tada.se>
Sent by: To
buckminster-dev-b Buckminster developer discussions
ounces@eclipse.or <buckminster-dev@eclipse.org>
g cc
Subject
03/12/2008 01:06 Re: [buckminster-dev] headless
PM resolve with properties
Please respond to
Buckminster
developer
discussions
<buckminster-dev@
eclipse.org>
Hi Todd,
I'll look into your problems with property settings shortly.
The PDE map provider might have had some problems with the tags in the
map file. That too should be fixed now though.
A new product package and and update site has been published. You'll
fine the latest URL's here:
http://www.eclipse.org/buckminster/downloads.html
Thomas Hallgren
_______________________________________________
buckminster-dev mailing list
https://dev.eclipse.org/mailman/listinfo/buckminster-dev
AMI Semiconductor - "Silicon Solutions for the Real World"
NOTICE:
This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
FUDForum. Page generated in 0.03085 seconds
