| How can I perform logging from within a HyadesTestCase? [message #9357] |
Tue, 08 March 2005 08:07  |
Originally posted by: jan.nicklisch.entimo.de
Sorry Folks,
if that is a stupid question ... given that there are apparently zillions of
dedicated classes within the Hyades source that seem to adapt various
logging systems (e.g. java14) ...
However, I feel unable to write a test that logs some output to either the
console or a file (sample below) using Log4J.
My intention is that I do not want to rewrite all my existing JUnit test
when migrating to Hyades. Yes, I first need to create JUnit Test Suite
definitions, then generate the test class body, then cut'n'paste my legacy
test code into there (which is kind of enough hazzle, already) ... but then
I would rather not want to be required to further edit those code chunks.
Any help would be greatly appreciated.
Thank you in advance,
Jan Nicklisch
import org.apache.log4j.Logger;
public class SomeTests extends HyadesTestCase {
private static Logger _log = Logger.getLogger(SomeTests.class);
public void c_s1_create() throws Exception {
_log.debug("create");
assertEquals("order columns differ", Arrays.asList(_oc),
_ocs.getCols());
assertEquals("initial order clause is wrong", "",
_ocs.getOrderClause());
| Re: How can I perform logging from within a HyadesTestCase? [message #11320 is a reply to message #9357] |
Mon, 21 March 2005 10:17  |
Hi Jan,
Good news! There is no need to migrate any logging code to fully
leverage Hyades/TPTP. Hyades/TPTP does not provide a logging facility, as
such. We provide Common Base Event and Logging Agent support for three
popular open-source logging facilities - Apache Commons, Apache Log4J and
Java Logging. Common Base Event support is often required for logging
Common Base Events in logging facilities that have proprietary log records
(e.g. java.util.logging.LogRecord). Often, this Common Base Event support
is not required since logging facilities, such as Apache Commons and Log4J,
permit generic (e.g. java.lang.Object) log data. Logging Agent support
entails monitoring loggers or Logging Agents in real-time by configuring a
logging facility to write or output to a special type of outputter, handler,
appender that writes to a Logging Agent. For more information, see File >
New > Examples > Haydes Logging.
For your scenario, I would recommend using your existing Log4J code and
configure Log4J to write to a LoggingAgentAppender by adding the following
the entry to the <log4j:configuration> element in the log4j.xml properties
file:
<!-- LoggingAgentAppender -->
<!-- Outputs events to a Logging Agent using possible filter(s). Layout is
performed implicitly. -->
<appender name="LoggingAgent"
class="org.eclipse.hyades.logging.log4j.LoggingAgentAppender " />
See the above mentioned sample.
Paul
"Jan Nicklisch" <jan.nicklisch@entimo.de> wrote in message
news:d0k83b$kf0$1@www.eclipse.org...
> Sorry Folks,
of
then
> Jan Nicklisch
> _ocs.getCols());
FUDForum. Page generated in 0.03508 seconds
