Ant View: Error while running the target [message #102040] |
Tue, 07 October 2003 19:48 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: dbshah.hotmail.com
Eclipse 2.1.0 gives an error when I try to run an Ant Target (from any
build.xml) from "ant view" window.
I can run the same target from Dos command prompt or from external tool
window within Eclipse!!
Am I missing any settings or anything else?
Below please see dump from Eclipse Log.
Will appreciate any help.
Thanks.
!ENTRY org.eclipse.ui 4 4 Oct 07, 2003 14:43:33.226
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Oct 07, 2003 14:43:33.226
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntLaunchShor
tcut.findExistingLaunchConfigurations(AntLaunchShortcut.java :252)
tcut.launch(AntLaunchShortcut.java:126)
org.eclipse.ui.externaltools.internal.ant.view.actions.RunTa rgetAction.run(R
unTargetAction.java:61)
unTargetAction.java:51)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:456)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionCont
ributionItem.java:403)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionI
tem.java:397)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(A
ctionContributionItem.java:72)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1838)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1545)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
FUDForum. Page generated in 0.04107 seconds
