Mapping model question [message #101882] |
Wed, 07 February 2007 05:57  |
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
--------------000503000909000803000200
Content-Type: text/plain; charset=UTF-8; format=flowed
I posted a question similar to this in another Thread, but I think it´s
a important question regarding the mapping model so it gets its own
thread. The situation is as follows:
I have multiple Node References towards the same EClass. For example I
need several specializations of the element "operand". In the screenshot
you see the 'list' operand. There are several like this that only differ
in their Feature Value Spec. and the selected creation tool, but all
reference the Eclass Operand. The same goes for other EClasses I defined
(e.g. Operators). But I not only get a load of Top Node References
because the the Feature Value Spec I must use to set the name attribute
for the different Operands, I also have defined compartments. Operands
hold Operators for example. Because of the usage of different Top Node
References for essentially the same element, I can not say the
comparment of Top Node Reference Operandxy can hold Operators. Instead I
have to specify a Child Reference for every node reference I allow to be
created directly inside the compartment. On the other hand I can drag
any Operator node inside any compartment of an Operand node at runtime
of the editor. All this buzz is created because I got the requirement
that all special instances of Operators/Operands/whatever should be
selectable from the tool pallete and not by specifying the property
value in question manually via dropdown menu in the core properties
view. Is there another way to get such specializations working without
the usage of Top Node and Child References? They make the model extremly
huge and fault-prone. If you need more info from me feel free to ask.
Thanks in advance
Greetings,
Christian
Content-Type: image/jpeg;
name="node References.JPG"
Content-Disposition: inline;
filename="node References.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAKLAwkDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD00KzLO8dlNLHAcO6soAO0 N3YHoR2qaBLe
eJZI8MrdDk1BDI6reGMgOLpUVioIUukS9wePm5GRkfpdNjcwSv8AZvs8kbYJ 8xwjbuh+4mOm
O2eOp7c8qypztJ7/AOZqocyugFrD/c/U0v2WH+5+prB8WXTv4TSe2+1fvrmy Gy2l8qV1e4iB
RWDLtLKxXO4deorIi1rVLDSzDp9rcyT3OqtZ2treSCe4tFWAyMJN8q7yTHIy 5l+5KhBIwtdK
aaujJqx2v2WH+5+po+yw/wBz9TXKQ+JNZZ9Ne9tobC1klFvPP5IulknM7ReV +6lPkMdoOW8x
VL7S2V+eCPxdqq2+j3MyWbx6xFb3MCJEym2je4to2RiXPmNtueGAQZTO05wA DsvssP8Ac/U0
fZYf7n6mubTX9VuPGkui28dmtvFLLvkkVt4jSO0fgA4LE3Dr2A+U87SrVW8R 68dA0rUIIba4
m1tojaW8Nv8ANbK0LzEMXmVZSFTbnMfc4PC0Add9lh/ufqaPssP9z9TWNFLq mueEyfks9QZm
jkVJgAfLlKuu+Nn8suFIJVmaMscFmXnn11rVbCYaHpGnTPqKyzNdeZdNqCps SBvkaeaIlStx
H3GCGAU53UAdz9lh/ufqaPssP9z9TXN+Er/UtVvtWvZ54RZvLCUtVbzjE7Wt u5CTBtpT5m4C
8kls84rqqAIfssP9z9TR9lh/ufqamopgQ/ZYf7n6mj7LD/c/U1NRQBD9lh/u fqaPssP9z9TU
1FAEP2WH+5+po+yw/wBz9TU1FAEP2WH+5+po+yw/3P1NTUUAQ/ZYf7n6mj7L D/c/U1NRQBD9
lh/ufqaPssP9z9TU1FAEP2WH+5+po+yw/wBz9TU1FAEP2WH+5+po+yw/3P1N TUUAQ/ZYf7n6
mj7LD/c/U1NRQBD9lh/ufqaPssP9z9TU1FAEP2WH+5+po+yw/wBz9TU1FAEP 2WH+5+po+yw/
3P1NTUUAQ/ZYf7n6mj7LD/c/U1NRQBD9lh/ufqaPssP9z9TU1FAEP2WH+5+p o+yw/wBz9TU1
FAEP2WH+5+po+yw/3P1NTUUAQ/ZYf7n6mj7LD/c/U1NRQBD9lh/ufqaPssP9 z9TU1FAEP2WH
+5+po+yw/wBz9TU1FAEP2WH+5+po+yw/3P1NTUUAQ/ZYf7n6mj7LD/c/U1NR QBD9lh/ufqaP
ssP9z9TU1FAEP2WH+5+po+yw/wBz9TU1FAEP2WH+5+po+yw/3P1NTUUAQ/ZY f7n6mj7LD/c/
U1NRQBD9lh/ufqaPssP9z9TU1FAEP2WH+5+po+yw/wBz9TU1FAEP2WH+5+po +yw/3P1NTUUA
Q/ZYf7n6mj7LD/c/U1NRQBD9lh/ufqaPssP9z9TU1FAEP2WH+5+po+yw/wBz 9TU1FAEP2WH+
5+po+yw/3P1NTUUAQ/ZYf7n6mj7LD/c/U1NRQBD9lh/ufqaPssP9z9TU1FAE P2WH+5+po+yw
/wBz9TU1FAEP2WH+5+po+yw/3P1NTUUAQ/ZYf7n6mj7LD/c/U1NRQBD9lh/u fqaPssP9z9TU
1FAEP2WH+5+po+yw/wBz9TU1FAEP2WH+5+po+yw/3P1NTUUAQ/ZYf7n6mj7L D/c/U1NRQBnS
xrHqVoEGBuJ/8datGqNz/wAhSz/3j/6C9XqAMuWxhkZpUjjS4JU+aEG7KkEZ PUjKjjNShdTP
/L5bf+A7f/F1vf2LZek//gTJ/wDFVHDo1oYyWFznew5uZem447jt/wDrPU89 TD0qjvJGkas4
qyZmJZwCzhtZI1lii2bRIoblCCp+oIBB7EZpt3pmn36TJeWNtcLOqpKs0KuJ FUllDZHIBJIB
6Ek1s/2LZek//gTJ/wDFUf2LZek//gTJ/wDFVurJWRm3cwk0XSo7q2uk0yzW 4tYhDbzLAoeG
MAgIhxlVwSMDjk0R6LpUP23y9Ms0+3Z+17YFH2jOc+Zx82dzdc9T61u/2LZe k/8A4Eyf/FVU
vLHToFaMfbDMUJURSzuV9Cdu7HPqOx64ouBm2Oi6VpeP7P0yztMbsfZ4Fjxu 27ugHXYmfXaP
QUxvD+isl4jaPp5W9YPdKbZMTsDuBfj5iCScnPJzWzb6fplzuEYugy4ysk0y MAehwxBxwefY
+lR6lBouj2LXuozyW1qjIjSyXUoVSzBFyd3Ayw5PA6nAppOTslqBRm0zT7jT Rps1jbSWIVUF
s8KmIKuNo2kYwMDAxxgVBJ4f0WXTYtNk0fT3sYm3x2zWyGJG55C4wD8zc47n 1qSbUvDttei0
nj1mJzcLbCR7S+WIyM4RR5pXZgsQA2cHI5rYn0zTLW3luLiSSGCJC8kkl3Iq ooGSSS2AAOc0
rgZv2K1+3/b/ALND9s8ryftHljzPLznZu67c846Zqek0x/DWt+b/AGTqkF/5 OPM+yak0uzOc
Z2ucZwevoa0P7FsvSf8A8CZP/iqLgUKKnms9Gt7y2s5rny7q63fZ4XvXDy7R ltqlstgcnHSp
IdM0y5QvBJJKgdkLJdyMAysVYcN1DAgjsQRRcCpRU9xZaTaT2kM7zpJdymGA faJTvcI0hHB4
+VGPPp64qx/Ytl6T/wDgTJ/8VRcChRSaY/hrW/N/snVIL/yceZ9k1Jpdmc4z tc4zg9fQ1JqU
Gj6TbrNdtdgO4SNIpJ5ZJGwThEQlmOASQAcBSegJouAyir/9i2XpP/4Eyf8A xVH9i2XpP/4E
yf8AxVFwKFFX/wCxbL0n/wDAmT/4qj+xbL0n/wDAmT/4qi4FCir/APYtl6T/ APgTJ/8AFUf2
LZek/wD4Eyf/ABVFwKFFX/7FsvSf/wACZP8A4qj+xbL0n/8AAmT/AOKouBQo q/8A2LZek/8A
4Eyf/FUf2LZek/8A4Eyf/FUXAoUVOllpMmozWCvObqGKOaRPtEvyo5cKc5xy Y3/L3FRyR6BD
qkOly36JqEyb4rRtQYSuvPKpvyR8rcgdj6UXAZRV/wDsWy9J/wDwJk/+Ko/s Wy9J/wDwJk/+
KouBQoq//Ytl6T/+BMn/AMVR/Ytl6T/+BMn/AMVRcChRSRnQZfs2yec/abuW yi/fTfNNF5m9
evGPJk5PB28E5GZLOPQNQuLq3sr9Lme0fZcxw6gztC2SMOA+VOVIwfQ+lFwG UVf/ALFsvSf/
AMCZP/iqP7FsvSf/AMCZP/iqLgUKKv8A9i2XpP8A+BMn/wAVVe/stJ0zTrm/ vHnjtbWJ5pn+
0SnaigljgHJwAelFwIKKv/2LZek//gTJ/wDFUf2LZek//gTJ/wDFUXAoUVf/ ALFsvSf/AMCZ
P/iqP7FsvSf/AMCZP/iqLgUKKv8A9i2XpP8A+BMn/wAVR/Ytl6T/APgTJ/8A FUXAoUVf/sWy
9J//AAJk/wDiqP7FsvSf/wACZP8A4qi4FCir/wDYtl6T/wDgTJ/8VR/Ytl6T /wDgTJ/8VRcC
hRV/+xbL0n/8CZP/AIqj+xbL0n/8CZP/AIqi4FCir/8AYtl6T/8AgTJ/8VR/ Ytl6T/8AgTJ/
8VRcChRV/wDsWy9J/wDwJk/+Ko/sWy9J/wDwJk/+KouBQoq//Ytl6T/+BMn/ AMVR/Ytl6T/+
BMn/AMVRcChRV/8AsWy9J/8AwJk/+Ko/sWy9J/8AwJk/+KouBQoq/wD2LZek /wD4Eyf/ABVH
9i2XpP8A+BMn/wAVRcChRV/+xbL0n/8AAmT/AOKo/sWy9J//AAJk/wDiqLgU KKv/ANi2XpP/
AOBMn/xVH9i2XpP/AOBMn/xVFwKFFX/7FsvSf/wJk/8AiqP7FsvSf/wJk/8A iqLgUKKv/wBi
2XpP/wCBMn/xVH9i2XpP/wCBMn/xVFwKFFX/AOxbL0n/APAmT/4qj+xbL0n/ APAmT/4qi4FC
ir/9i2XpP/4Eyf8AxVH9i2XpP/4Eyf8AxVFwKFFX/wCxbL0n/wDAmT/4qj+x bL0n/wDAmT/4
qi4FCir/APYtl6T/APgTJ/8AFUf2LZek/wD4Eyf/ABVFwKFFX/7FsvSf/wAC ZP8A4qj+xbL0
n/8AAmT/AOKouBQoq/8A2LZek/8A4Eyf/FUf2LZek/8A4Eyf/FUXAoUVf/sW y9J//AmT/wCK
o/sWy9J//AmT/wCKouBQoq//AGLZek//AIEyf/FUf2LZek//AIEyf/FUXAoU Vf8A7FsvSf8A
8CZP/iqP7FsvSf8A8CZP/iqLgUKKv/2LZek//gTJ/wDFUf2LZek//gTJ/wDF UXAoUVf/ALFs
vSf/AMCZP/iqP7FsvSf/AMCZP/iqLgUKKv8A9i2XpP8A+BMn/wAVR/Ytl6T/ APgTJ/8AFUXA
oUUx9Jgk1WeH7TdQwxRIwCTtkli3Ukn+7+tOTR9PkaRU1O9Zo22uFuclTgHB 9Dgg/QigClc/
8hSz/wB4/wDoL1erJMP2bWltxLJKsU5CvIxZiDEW5/76xWtTA36ithtiYYx+ 8c9MfxH2H+e5
6mWoLQYhbkH97J0AH8Z9P/1+vOakCeiiigArjvHWmX+p6XqllZzXcDXtiYEe CIOrnbKCknyO
Qh3rkgBvQ9a7GqmoXdtbWzrcTQIXRgqzMoD8dMEjPUdx1oAytBt7wmd7i6vp D5aRi4uokSRy
DIeVCKON64wo6DrzWf8AE7Sr7V/h1qem6fDJdXlw8KxRqBk5nQ+wAA7noBkn qa6uC5gukL28
8cyA4LRuGAPpxSzTxW6B5pUjQsqBnYAFmIVRz3JIAHckCtaNV0qsakVqmn9w mrqx5np0E+k+
D9L8KzTaxqeo22p2W6RtKuRDGsd3EzKkpjCmNFVsMW5A4wMKPUKx/wDhLPDf 9o/2d/wkGlfb
vN8j7N9tj8zzM7dm3Od2eMdc1sVNSpKpNzlu9QStocH5F7beHYEmi1KKyOu3 7362iyrObdp7
loyvlfvcGQwHKclTk/Jurn3n1RrvULdpfEB1RNMV9Ejja62qzXF4LczhfkBK Lbhjcddp39Hr
1yoxBCtw9wsUYndFR5Ao3MqklQT1IBZiB23H1qBnJ+KtGvNU8TaXPZJsurTT 7yW1uXBEcdwJ
bVo1dgCQrhXVgOWQyAd65O0fWZtHurgWXiCyuLlLu40S3WKeMpdyXd0+LhU+ QDDWx/f/ALvG
ccb69cooA8r1mDWZtRiezi1l/E0N7qDxMyzm0SP7PdLald3+jA4a3GeuSQ3J euk8Cw30X2/z
r6+urQ+X5X2uzubfa/zb8fapXmPHl+iDA25YvjrJJ4YXhSWWNHmfZErMAXba WwvqdqscDsCe
1SUAeX6Npvimx8M6ZI8edSi8NNaaSILUxm3uGiRjHcCRmG7MMW1ztTIcMASg Mdhot/qF5pcN
xd6zd6aupq5cwXtk0JFrdBiHmmacAkwgnKx8gDJZxXqlV76/s9Ms5Ly/u4LS 1jxvmnkEaLkg
DLHgZJA/GgDy/U4fFfn+IZY77Vft3lahst7ezudvlbJfs2yUy+Ru/wBQR5Ke bu4P/LQ1oeJt
P1+31aG3s9W1VYUtFNnMlrPdPLdmSQyFvKljiXrDgTjyRnChVDivSKKAPN7m y8SWunPfaQ+q
trN1qGqQ7Z55JI1jAuzbkRykxxruS32tgDBAzhiDHrEcstvYro134gttH3zm 5e6ttUnnM+Iv
LAUSJcBNvm8g+XkHI3FcemUUAY4h1l/CUMUd1t1k2iB5p40QmXaNxIXeiMTn kB1UnOHA2nl5
bee3tYlubHXIXN2n9tXCSyzzXEPlS7Ghlh+fy/P2kRxiMqGJMaI5z6BRQB5G 8+qNd6hbtL4g
OqJpivokcbXW1Wa4vBbmcL8gJRbcMbjrtO/o9SanD4r8/wAQyx32q/bvK1DZ b29nc7fK2S/Z
tkpl8jd/qCPJTzd3B/5aGvVBBCtw9wsUYndFR5Ao3MqklQT1IBZiB23H1qSg DzfxwmtadZpF
pk+qme0tJJ7W6SG7u3vLkliUZYGWNMFUI81Wj/ebVUKjKS5svElrpz32kPqr azdahqkO2eeS
SNYwLs25EcpMca7kt9rYAwQM4Yg+kUUAed6VBbLrmq3FhF4nFm6aUgknW785 pFupSwBufmMQ
DIZAOAjP3Jqxe21yNE1rw8bO7fWtQuLma1u1t3aLc7s0EzTgbUMKiMfMQ6+Q Agb93u7gTwtc
PbrLGZ0RXeMMNyqxIUkdQCVYA99p9KkoA8rhn1m5S/fw9LrMuuC91VJWuGna 1EatcrAE879x
kSC2GE5ABB+XfUmmafrVxc2Nsura4+mS6gomcWt3alV+zXPmAtcyyTbWPkgn 5VU7ShEmSPTI
YIbZCkEUcSF2cqihQWZizHjuWJJPckmpKAPJ/FFx4mOq6nJp39qw3EsV7CbW 3trx1VFtZvJk
SbeYAzOkLARorhn2kkh92xqdlfaZrD2MT64/hwfZprpo57m4m+ZboMI5AWm+ +lplYzwDkgKz
k+gUUAeV6Xpt7qNm2l6a13bTwWWsSwNemWOS3lubp1tJm3jzA5RZ/nwXALZ+ /wDNc8W3L3Hh
uWbRLG+0iTRNPvGldrZrXyI/ssiLBG4AD/vPKb92WQeSDuyI93eRz6abgXEc tp59w5tRIrLu
laMuTHnqSpEp29sP05qxPBDdW8tvcRRzQSoUkjkUMrqRggg8EEcYoA8z1BNV kilXQ59cg0Ay
2/nyXkN9LOrbbjzNqlluiu77J/q2C/ePI80VoaFb+IIbq5vJ5dV1A2elRyWV rMWtI7qUy3W0
MHZiG8vyl/eMWwyNIN4G30CigDyfSbTWL3WrfTJLzXJ9GN3DJJMIdQsSCYLz eC80jS7dyW2c
PsyVGASd0evwapc+Hdbs9Vi8QTJ9iu7bSI7VbpjJIs9yiiXyuXBiFrhpshgS QTlyfXKjnnht
beW4uJY4YIkLySSMFVFAySSeAAOc0AcvqlnfTeIGk0C3u7O7Dp9rvpJdlpIM DIMRDec+3y/m
VUJVdgnQqVrrKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooA5bxF9tLakunTRwXjQQiKSRdyqf3vUf/r+h6HkdM8MXWh6jbXm napKXkyNS8/L
i66nfjPDZOBzwD353egX1itzePJ50sTYCts2kMB0zkHpk9PWo10RCP8Aj8uP ++Y//iKtW6iM
ZiW1xSepkQ/+S4rVqjdWq2msWyK7yEtlnfGT8jAdABwABwO1XqQzfqK2O6Jj nP7xx1z/ABH3
P+ew6CWorbd5Tb+vmP8A3um44689Pw9OMVIEtFFFABXGeOZdTi07VU0m8is7 24sNkLyKcuwE
vyxtvTY+WTD5IXIyK7Oo7g4tpTgn5DwCQTx6rz+XNAGFoM97eSXE0t3bXEoi RGnht2SJiDIQ
ApdiCNy5+Y/hkYyPi1BPc/DDVreKNpp5XgSOOJCWcm4jCqBySeg9zXcUVtQq +yrRqpfC0/uE
1dWPK7TWmi8F6Vomv+JdKvfEaarp8b20V0jzptvIf3b4Yl3UA7iB2Oc4LH1C eCG6t5be4ijm
glQpJHIoZXUjBBB4II4xUlFRUm6k3Nq1+2wJWPM9MisvDvh1ZLD7JoVvd67f W9/qUEEUZghj
nuvKJZ1KAbljiG8EAPtGCQRTl8X6kHvS/iTybq20/wA7SrPbbj+13FxdJGcF N0nmpDAf3JXP
mZXG5cesVXSxt49Rmv1jxdTRRwyPuPzIhcqMdODI/wCfsKgZx/i+xuLrxloV 1YR+ZqWn6ffX
dom4DzHWS1DR5PA8xGkj3HO3fuxlRXL6d4sl/sO7vNO1j7NC322+0eHYg/te d727Pk7ZFLvw
sI2R7XHncnLLj2CigDyfXtevf7VtbiLVPtGu2eoagYPD+2M7RFa3ghfy1UTH eqxnlsN5uQAC
uOo8C6pqOo/b1u9XsdVt4/LMVxaXS3OGO7chljgij4AQ7QCw3EscMldhRQB4 /wCEheaB4Zsd
Rs9GsbG6fw0Xso7QGQaxceUsi+aFRD5yiMkJ8xYTSbW+V6sWl5q2uaho1vL4 kguI11VTDf6b
cRXbxsbO73p5n2ZITwqfLsZhuJJAZMesUUAeT6n4s8S28/iGVNUsYZLWLUCt h5qvNBHEkphm
8gQbk3bIm3ySsjCTgZdANDxNrPiXSNWhso9ZsYmS0WeKS6dYBfXDSSbokiEM ryqoWMCONlkA
cAu7MGHpFFAHm9zrviLT9OfVba9n1G4udQ1Szg06W3jaNfIF20QQRoshbNui 8schm4yQRHrH
iK5t7exTSPGlpd2ErzmfV7q/tIVjlURbIBKtu8WSHd9hTedpIYBSD6ZRQBji 61h/CUN3DbwS
6u9ojtEEeNPMKgttSTa3HOEcoTgKzJksOXl1mW3tYmudevrO4mu0i1W5u4Ut /wCzY/KlZfLR
1MSxmVfLEh8wPuKiRyqlfQKKAPJ5fF+pB70v4k8m6ttP87SrPbbj+13FxdJG cFN0nmpDAf3J
XPmZXG5cGp+LPEtvP4hlTVLGGS1i1ArYearzQRxJKYZvIEG5N2yJt8krIwk4 GXQD1BLG3j1G
a/WPF1NFHDI+4/MiFyox04Mj/n7CrFAHm/jjxLq3hizQJrEEd5aWkl473c0V rDfMSxEMSGJ2
k27MFFdGCvHl2ZtwLnXfEWn6c+q217PqNxc6hqlnBp0tvG0a+QLtoggjRZC2 bdF5Y5DNxkgj
0iigDzfSdStT4k1mez8Y/wBpR+VpERv8QT4LXU6+RiFFUbtwXJGV8zdnAGDU fsfkar9o8j/h
PPNuf7K3Y+143v8AZfJ/6Y7Nm7b+7/1vmf8ALWvSKKAPL/8AhLNWj+3S6ZrH 9satHd6nE+i7
IpPs0cP2jyW2RKJRlooEyzEHzcdWUg0zXPEV9c2NlD4lsbiG61BYDe2kkd6V U21y7p5iwRRB
h5UbKNrMpOX3KyqfSLOxt9PgaG1j8uNpZJiNxOXkdpHPPqzMfbPHFWKAPJ/F HjjVtO1XUxY6
nBF+6vYksJ7iJri3aG1mkWYQeSGVWeFWVnkdWSQHaNw27Gp6tqWjaw+j3PiG dLD/AEaW41e5
S3SS1SRbr+LyxEql7eFQWQ8ysM5K7fQKKAPJ9Ke9v9Kii0S8/tG6tYtdvrS4 UxnN211JFbSs
QAnzq9xgEBG+Y4+XixrN9pemaXdX/gaSCO/tbS6m1N4FzIqrbSlTdB+TMJxF jzf3mfM7ebXp
CWNvHqM1+seLqaKOGR9x+ZELlRjpwZH/AD9hRf2NvqenXNheR+Za3UTwzJuI 3IwIYZHIyCel
AHm+oeKNSgilh0fxJBqOmebbiTXJ57eNLcstwXQzpC0K4MVuPmjY/v8AGfnQ roaFruuz3Vzc
Xt79stdP0qO8Ntp1uJXvWMt0qlHZE37kiQ/Kqq7BWQqhIb0CigDyfSfEut6r rVvoaeJ4Jo5L
uHdf6bdW144V4LxzHv8As6Rjm2jOPLLDcfmIIC1/E3iK6u/Cuv2ereIP7Ojh 0+9gtSfIjOqS
JNdQMjb1O5tsMJIi2EGY9AyAewUUAcnql5fQ+IGj0C4u7y7Lp9rsZIt9pGMD JMpK+S+3y/lV
nIVt4gcsWrrKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooApS/wDHw/1H8hUydBUMv/Hw/wBR/IVMnQVQjA1X/kO2v1/9kap6 g1X/AJDtr9f/
AGRqnoGb9RWw2xMMY/eOemP4j7D/AD3PUy1BaHMLcAfvZOhB/jPp/wDr9ec1 IE9FFFABXGeO
bi/g07VX02ztru9isN1us/JjYiX5o12OHfKphSAGwMniuzqpqFraz2zvcwRS eWjFWdEJXjnG
7gdO/HrQgMnQZrlpLgfYrK2kESFre2mLRK2ZOQ2xckgJk7R+OBnI+LU89t8M NWuIpGhnieB4
5InIZCLiMqwPBB6H2NdnBbQWqFLeCOFCclY0Cgn14pZoIrhAk0SSIGVwrqCA ykMp57ggEHsQ
DW1CqqVaNRq9mn9wmrqx5faaK0vgvStb1/w1pVl4jfVdPke5itUSd915D+8f Cgo7AncAe5zj
JUeoTwrc28sDmQJIhRjHIyMARjhlIKn3BBHasv8A4RPw3/aP9o/8I/pX27zf P+0/Yo/M8zO7
fuxndnnPXNbFRUmpzckrX6LZAtDz/RZbrTdMgisbqeS+1PW72wS41K5nvEgS GS6ZfkaQZ+SH
Zwy5yGJbGDG3jLXmi1i7Q6asGh2T3F1E1s5a7aKe6icI3mARBha5GRJt387s c9xPpOm3VhLY
XGn2k1nK5eS3khVo3YvvJKkYJLfNn1561n/8IhoJ1mLVH0y0knt7eC3tVeBC tqsTOyGL5coc
v2P8K4xioGY/i6fUrfxVotxp8t2wsrK8vZbKBmIu1R7ZWQxj77+XJIYwcfvN nOM1j6f4x1I6
PrN7YXVpc2mlJeak7zBpzeQm7uwkcbhwIwEt8BsOMMuFwuG9IMELXCXDRRmd EZEkKjcqsQWA
PUAlVJHfaPSs9fDWgqlki6JpoSwcvZqLVMW7FgxMfHyEsAcjHIzQBw/iLxFq UR0/xFKLR9P0
/U9REVisTLKzW1teplptxGG8pjgRjG4DJ25bqPC+q65e3F7Z67ZR288CRSxs BFGzK5ccxJPM
QAUOGLDdkgD5CTqf2Fo/9sf2v/ZVj/af/P79nTzvu7fv43fd469OKk03SdN0 a3a30vT7SxgZ
y7R2sKxKWwBkhQBnAAz7CgDzPwtr15pfh6PVpYtV/ceGm1K5i1O/M39oyBEZ ZICXk2KMSBwA
pHnRZU5XFjULvxFr1zpuhaxaWNvJJqCEreWsckU8ZtrptstslzJuUNCGVmcA sBhcx5PpCWFn
HFaxR2kCR2mPsyLGAIcKUGwfw/KSvHYkdKr2OhaPpkUcVhpVjaRxymdEgt0j CyFShcADhipK
564OOlAHD6h468RWsWrahHpUC6bB/aEVs83lqDJbLNg7vP3ybmgOUESEBidx CZa5rXijxRpt
69tBplpcPZWSX96yFBEFd5cR+ZLNH5YVYSDLtfOS2xMbT1j6Fo8l5dXkmlWL 3V3EYLmZrdC8
0ZABR2xllwAMHjgVJeaTpuoXFrcXun2lzPaPvtpJoVdoWyDlCRlTlQcj0HpQ Bxd3401jSdOu
NZvEsbqxN3qNtDaQwvDIn2YXLKzSl2DbhbEEBBy+f4cG5rGr+K9MuLHS7dLT UtQuknuDNa2I
VY4ozEu0xyXSZJaXO7zOMAbDksOsWws08vbaQL5Urzx4jA2SPu3OPRjvfJ6n c3qaz/8AhE/D
f9nf2d/wj+lfYfN8/wCzfYo/L8zG3ftxjdjjPXFAANZuG8JQ6zHp/nXElolx 9lgmEoBZQSA6
A71Gc5QMSB8qsSFOHB4g1K6hs2tdV02a71K9+xKiQM0WnMsMk7JIhZZHlwmx txjx8p2KQyt2
lU7zSdN1FJ0vtPtLpJ0RJlnhVxIqMWQNkchWJIB6EkigDh28Za80WsXaHTVg 0Oye4uomtnLX
bRT3UThG8wCIMLXIyJNu/ndjmPUPHXiK1i1bUI9KgXTYP7Qitnm8tQZLZZsH d5++Tc0BygiQ
gMTuITLdZ/wiGgnWYtUfTLSSe3t4Le1V4EK2qxM7IYvlyhy/Y/wrjGKuPoWj yXl1eSaVYvdX
cRguZmt0LzRkAFHbGWXAAweOBQBy/iXxTruhWbSQ2sF3dWFo1/qdvBAGSOEl iiiV5oyOI5F3
hJCdu7y1yFNe78aaxpOnXGs3iWN1Ym71G2htIYXhkT7MLllZpS7BtwtiCAg5 fP8ADg9hqeha
Prflf2tpVjf+Tny/tdukuzOM43A4zgdPQVYWws08vbaQL5Urzx4jA2SPu3OP RjvfJ6nc3qaA
OPtH1ix8Yaw17qGlSXTWmlIJTA9tF5bXNwrLgyOTIQWC84LFRj1jvbm5Oia1 4hN5dprWn3Fz
Da2i3DrFuR2WCFoAdrmZTGfmBdvPBQr+729RZeGtB01JEsNE021SR43dYLVE DMjbkJwOSrcg
9jyKsSaTps2qQ6pLp9o+oQpsiu2hUyovPCvjIHzNwD3PrQBxd3401jSdOuNZ vEsbqxN3qNtD
aQwvDIn2YXLKzSl2DbhbEEBBy+f4cEi8T+LhfWmlXNhYwX1zdpEslyqJtjeG 4ct5UU8p+U2+
QS6h8so2YL11GkeF9H0S6ubyzsYBfXMs0s14Yk85/NlMjKXABKgkAA9lXrir FjoWj6ZFHFYa
VY2kccpnRILdIwshUoXAA4YqSueuDjpQBxfiHx3q+ky391Z2cdxpYS8htZ5I Aii4t4JZGBbz
i7jfbyJjykHcOcDfoT6/r1prcfh2WbTZNQuHhMV8to6xRrIly+Gh80liPsjD IkX/AFgOPlw3
QT+GtBur+W/uNE02a8lQpJcSWqNI6lNhBYjJBX5cenHSrF5pOm6ik6X2n2l0 k6Ikyzwq4kVG
LIGyOQrEkA9CSRQB5vb3OpQadbLFHHd6hYP4g1WFYYWxPdRXEkKqE3E7G+0v 8oJbIX5uDnU1
7UH8KaXFq2iajPqclzaXNzL9rumuY5o47aSVZwoOI18wRL+72JiYDGTHt6zT fD2m6PezXGnW
0dqklvFb/Z4EVIkVHlcFVUDBLTOT68e+Y7rwvo9xp2sWcVjBZ/2vFJFezWkS RyS7wwLFsfM3
zscnPJNAHN6p4o8R6Tf/ANhrDaajqkzwGGe1tfLULIlyxBiknAYgWrc+av8A rBx8uHk0vxfq
k11dPq0VjZWGmaf9r1BwfNkBEtzGwAjZ1H+oDkBnKEMnzk7l6SPw1oMOlzaX Fommpp8z75bR
bVBE7ccsmME/KvJHYelXLaws7Pb9ltIINsSQDyowuI0zsTj+FdzYHQZOOtAH BweKvFcmrW+h
XFtaWOoTXEQFxdWYK+U8N0/EUdy/Ia1xu8wfePyjALU/EPiHWNd8IeKLKJ7G 2+waVdfbXa3e
T7TiS6gPljzF8rP2Zm58zHmAc7ct3lh4a0HSn36domm2bhw+63tUjO4Kyg/K Bztdxn0Zh3NF
74a0HUkjS/0TTbpI3kdFntUcKztucjI4LNyT3PJoAy9Y1u80fXEgt7iDUmuN jf2SqH7VGp+U
yIyAjy8rj96FXcxzMowo6io44IYXmeKKNHmffKyqAXbaFy3qdqqMnsAO1SUA FFFFABRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBSl/4+ H+o/kKmToKhl
/wCPh/qP5Cpk6CqEYGq/8h21+v8A7I1T1Bqv/Idtfr/7I1T0DN+orY7omOc/ vHHXP8R9z/ns
OglqK2JMTZDA+Y/3gQfvH1J49PbsOlSBLRRRQAVyHjbWbnRtL1W9gtbm6e0s fOiSKby1jbbK
S8n7xCyDYuQCW9Bya6+qOoada3aNLKjeYiEBkLg+oyEILfT3OOtCAoaLfyzN P/oV7CojR/s1
xMkkiMTIDlg7DkIuAGI5HTmsz4narfaR8OtT1LT5pLW8t3haKRSMjE6D3BBH Y9QcEdRXT2lh
bWKsLeMrvPzFmLE+nJJOPb3PrTdS0yy1ixay1G2S5tXZHaKTlWKsHXI7jKjg 8HocitqFSNOt
GcldJptejE02rHnWnTz6t4P0vxVNDrGmajc6nZbo21W5MMiyXcSsyRGQqI3V mwpXgHjIwx9M
njaa3liSaSB3QqssYUshI+8NwIyOvII9Qax5vCWlXN6LudtSlcXC3IjfVLlo hIrh1PlGTZgM
AQuMDA4rcqKkoym5RVk+nYEcPo+ratZ6YrS30+sX99qt1p9pHeNFBEnkSXHJ aKLIzHAcna2W
wAFBJA3j282388ejQG10q0a51JmvSHXZLcRSLCvlkSYNs5UsY92Vzt5x0kvh 7TJrD7EYJEiF
xJdK0U8kciSyOzu6SKwdSS752kcMV6HFZf8Awgmktq0l0/nm1a0itvsi3Eqp Jtkld2mw+J95
mO4SBs/MTneagZX8Wa3qOjeIdIlguNumQWl1e6lBsU+ZDG8CFtxBYeWszy4X ltm3HzDFO38b
X0Fnqkr2kd4mlPeXN9I83lMlst1cxoIlVCJHCW7DDFBwvzHcSO0ext5NRhv2 jzdQxSQxvuPy
o5QsMdOTGn5e5rDtvAXhuysLawtrCSG0t0MYhS6mCyoXZyko3/vU3O/yybh8 7DGGIIBh654v
vLe50/VTa+VoVpqF6krxXRM8/wBntrsOrRbQu3fCxXMhztQkAn5eg8MeIrrX ftSXmkz2MkGw
hminWOQNnhTNFExYbTkBcAMvJJIEkvhDQ57/AO2TWkkh3yP5D3Ept90iMkh8 gt5WWEj5O3ku
xPJJq5pmi2WkeabVZ2klwHmubmS4kYDOF3yMzbRliFzgFmIGScgHB+FPGN3/ AGMNUvtQ1LUo
INC/tPU1ubJIGgk2qyCD93GHRwtxzlx+7X5hn5pL7xNrWvJp+nR6RPZzT6gs UitPd2UdxGbe
4k2rO0EcqsrQhjsTGNo3EMwHaL4c0hbKys/sMbW9lbm1hjclh5JQIY2yfnQq FyrZBKqTyoIj
tPC+k2c8NwkM8txDL5yT3N3LPIGCOgG+RixULLJhSdoLsQMnNAHN3fxHlt31 aSPQbuazsUvA
s4SZQz26yFt7mLylQtEyhlkc5KZUEsFsar45vdMvY7M+Hbua4W3W7uIIFlne OJ3dUVfKidDK
RG2VZkQHADsMsNi58IaHdvdNPaSSJdJKskJuJfKHmKVkZI92xHYM+XUBjvfn 5jmxqXh7TNWu
FnvIJGcII3CTyRrMgJISVVYCVOW+Vww+ZuPmOQDn5fHc1hbz6jqWlRx6Wtxe 28MltdGWd2th
OzFo2RVUFbeTGHPJUdyRJq3i3VtF+yWt1okEmpXXmyJFaT3FxGIo/LBYtHbM 4bdIox5e3AOW
BwDuP4c0iW3jt5bGOWCO4nuRHISymSYSCUkE4YMJpRtOR83TgYrnwlpTW6Qs 2pEo7Mk51S58
9dwAZRL5m8Idqkpu2kqDjIzQBYm1yG28NDXLi1u4Yvs6ztbyxhZY9wB2uCcI RnDFiFXBLEAE
jL/4SLVDa2VytjYu2qyrFpkAu8qR5UkxeWZVYDKIcKiuAwHzsGyvSQQQ2tvF b28UcMESBI44
1CqigYAAHAAHGKy5vC2jTfaCLPyGuJRO7WsrwN5vzZlUxkFZGDMrOMMynaxI 4oA59vHt5tv5
49GgNrpVo1zqTNekOuyW4ikWFfLIkwbZypYx7srnbziO7+I8tu+rSR6DdzWd il4FnCTKGe3W
QtvcxeUqFomUMsjnJTKglgup/wAIJpLatJdP55tWtIrb7ItxKqSbZJXdpsPi feZjuEgbPzE5
3mrlz4Q0O7e6ae0kkS6SVZITcS+UPMUrIyR7tiOwZ8uoDHe/PzHIBl6/42n8 P2cNxc6VuZYn
ub22jeWWa2gBO0nyonQMVVvvuiblYB2ALCOXx3NYW8+o6lpUcelrcXtvDJbX RlndrYTsxaNk
VVBW3kxhzyVHckbms+F9J1/f/aEM58yIwS+RdywedGc/JJ5bLvUbmwGyBubH 3jmR/DmkS28d
vLYxywR3E9yI5CWUyTCQSkgnDBhNKNpyPm6cDABh6fqPiD/hK9WjvLCAyJaa dstLa/aSNUee
4WSXLxphgoJIC/MI1GckYju9X1P+xNW8VR38kcGmPeBdMEcZimS2eRG3uV37 38tiGVgFymVf
a2/Yt/COj2xmYR3czzPbu73V9POxMEhkiw0jsQFck4HByc5qxN4e0y41QajJ BIZ96yMgnkEU
jrja7xBtjuNq4ZlJGxMH5VwAc/L47msLefUdS0qOPS1uL23hktroyzu1sJ2Y tGyKqgrbyYw5
5KjuSI7fx1qc7W9ufDM4vLm7W2iDGaGE7oppA2+eGNjt8k7wEOFYEb2+StTT fBWmWZuXuxJf
vPcXUxS5lkeBRPJIxCwsxjU7ZChYKCQW/vEVctPC+k2c8NwkM8txDL5yT3N3 LPIGCOgG+Rix
ULLJhSdoLsQMnNAHP638RBot9fR/2d9qtYYrgwTwtNtklhheV42cwiIY8qRT tkdgwwV+9tuS
eK9St79dHuNJtBrUrxCCKO+ZrdldJ3BaUxBlOLabgRtzs5+Ylbl74K0HUJ5Z bm1ndZfNLQi8
mWEGVHSRhEHCKzLI+WABJdjnJJq5f+HtM1K4kubmCT7RIkaefFPJFIojMhXY 6MCh/eyAlSCQ
5ByDigDh08R6lZ6TBd3ZkaewfXNVuIkumZZltppIhbbiASmZkIYjjyV+Xkbd jXNX1PwVaDUb
y/k1hJ0nL27xxwLE8dvLcDyiq5CHyWXa5kPzKd3ynfsaR4YtNF1KS4tXkMH2 cRQxTO8rRM0s
ksz+Y7FiZGdC3r5a5JwMV7zwVpkujarYWYktnvrKaySR5ZJltUkXBWJGbEaf d+RNoOxR/CMA
GfqXje90d2sb7RozqzPCIYbSeW4iZZFmYEskPmAgW0uQsTfwc4LFbGl+MptQ vTFcaRJp9vBZ
LeXlzeSmFYFLzofldVfBMG5SwXKEs2wgK2gPCOji3eIx3bu7q/2mS+ne4UqC BtnLmRQAzjCs
Bh3H8bZsW3hzSLRJ0jsYylxbrbTrKTIJow0jYfcTuJaWQsxyWLksTQBy9r4/ 1C8uotNi0GNd
UluI4xHcTXFvFseKeQNult1fP+jOMCMjlfmPIFfxD4x1K+8J6+mk2UcN3ZaZ cveTPetEbdla
eHMBVCZCHt5SCfL42Hgkheos/COj2N+l/HHdy3aOrrNdX09wwKpKi4MjtwFn l46fOT1wRHe+
CtBv4JYZrWdI5vNEwgvJofOEjvI6ybHG9d0khCtkDe2AATQAaxr9x4fvEkv4 IJdMuJUhgkhl
CzrIw+55TH9791iPLJc5CrG2Cx6CqcelWMWqTamttGb+VPLa4b5nCcfIpPKp lQdowM5OMkk3
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooApS/
8fD/AFH8hUydBUMv/Hw/1H8hUydBVCMDVf8AkO2v1/8AZGqeoNV/5Dtr9f8A 2RqnoGb9RWw2
xMMY/eOemP4j7D/Pc9TLUFoVMLFSMebIOPXec9h3/wD1nqZAnooooAK5bxhr 40PTdRupftTR
Wtn5qw20HmeaxEh2ufLfYn7vG4gKM8npXU1laxo9tqME7TuVV4THKpK7JE5+ V9ysMct26E5z
QgItI1ZbvzSsl5LCEV1NzaNFKCS4IKbFIHycZXJz3yKofEHX7zw74F1DWdNK rc2rwlRLHlW/
fIrAg9iCRkdjkHoa3bDTY7AyMsssskmAzykZwM4HAA7n86h17QrLxJo02lai rtaTNG0io20s
EdX256gEqAcc4JwQea2oShGtGVRXimr+nUTvY4jT/EF7rfhqw8VWGt6xDHca nawyafcwW/lK
JLqOKRFbyQzoA7AMGzxydwIHos4ma3lW3kjjnKERvIhdVbHBKggkZ7ZGfUVg TeEjO0Mba7qS
6fBcQzxafHFapCgikWSOMbYQ4RSijG7OB1ro6io4ObcFZdEC8zj9J8R6pHpj XOreRf3E+oT2
Flaaba+S8jwyTK3MsxXlIWfkrjBGWJFSN4+slM7LpmpPBaW/2i/nURbbJRJL G4cGTcxRoJc+
WHzt+XdkZ0H8L232CO2gu7u3lhvZ76C6jKGSGWV5GcgMpQjE0i4ZTwfUA1jj wCG1K9U6ndpp
d3ZR291Ahj3XrGW4knMpMeVDmc/6opjc2NuFxAy54k8SXmieIdHgSOBtMlin n1CR1JkijR4Y
w6nIUKrThnLcBFY9ua9v46SO2u5Luynl+xS3TXklqqhLS2juZoklcO4ZsrA5 IjDH5D8oyoPQ
XmjWd/qMV5dJ5uy0nszC4DRyRzGMuGUjn/VKPTBOQe3P2vw7sLTTPsCarqrw yxPBfNLLG738
TSSSFZWKEjmaX5k2N85ySQCACPV/GotdR0+RILuDR4725jvNQZIzFIsFvcNI iqGMuVki67Bn
yzgkEbtTwx4w0zxV9qWxO2a12GWPz4ZsK+dp3Qu6clW43bhjJABBNe78C2F9 OVuL2+fTTLcT
f2bujEO+dJUlO4J5vzefKfv8FuMAADY0zTJdP81rjVL7UZpMDzLsoNqjOAFj VEHJPO3ccgEk
BQADj/C3j19Q06O/1LUtKu7X+ym1G9fTYmH9mlQhMUo8yQliHfH3T+5fg/wx 3XxCTXIbW00A
Xf2uW9WCdLKazmnSNoZpFaN/MeDJMBBDHIUNwCUJ6RPB2lppNrpp89reHTxp kvz4N1bCMoEl
IAzjJYEYKktggMwaSDw0FurO7vNW1K/uLS48+N7howP9VJHt2RoqAYmc5ADE 7ckhQAAY918U
PD1rf6haM8jvZJcE+XJCzSPAjNIgj8zzFIEcnzOqqdvDfMu6TVviRomiSwR6 is9s0sX2h1na
KF4oSzKshSR1dtwRjsRWkGMMisQpuXXg22urfULNtS1JNPvUuAbKORFjjecN 5jg7N7EmSRtr
sygtkL8q7bmoeH0vtRN7HqF9ZSSxLBci0dV+0RKWKqWKlkx5knzRlG+c85C4 AM//AITqwi8+
a9sr6ysIpbqFb6ZY2jle38wyBVR2k6QysNyjIT1IBj1Xx7aaHb27atpt3YXF y7iG2urm0jZ0
QLucO04jxl1G3fuPJC4BIuXPg7S7zTo7C58+W1W7urpkL43m4E4kUkAHbi4f GMEYXng5H8MT
SeTM3iLVTfw+Ysd9stvMWJ9haLb5Pl7SY0bO3dkfewSKANAa3pzaHDrQuM2E 0STRSBGzIr42
BVxuLNuUBQNxJAAycVnv4mljiWZ9FvlW5lEFhASiz3bbXckIzARrsQsPMZW4 YFVIUNsfYbdt
O+wSx+famLyWS4Yy+YmMEOXyXyOu7Oe+ax38I2axLHZ3l9ZLDKJ7QRShxZuF dCYlkVgqlHKb
MFFGNqqeaAKbePrJTOy6ZqTwWlv9ov51EW2yUSSxuHBk3MUaCXPlh87fl3ZG a918UPD1rf6h
aM8jvZJcE+XJCzSPAjNIgj8zzFIEcnzOqqdvDfMu4HgENqV6p1O7TS7uyjt7 qBDHuvWMtxJO
ZSY8qHM5/wBUUxubG3C40LrwbbXVvqFm2pakmn3qXANlHIixxvOG8xwdm9iT JI212ZQWyF+V
doBHrPjvTNAs7G71OGe1gu/MYGeSGF0RCPnMbyLI2QQ2xFZxnBUN8tH/AAnV hF5817ZX1lYR
S3UK30yxtHK9v5hkCqjtJ0hlYblGQnqQDY1/wnBr32v/AImN9Y/bbT7Fd/ZP KP2iH58KfMR9
uPMk5XafnOScDBc+DtLvNOjsLnz5bVbu6umQvjebgTiRSQAduLh8YwRheeDk Ap2PiXUJfEep
w3ek6lbQQ29h5Vo6wySBpp5o2lzE7DYAqE5bgRscepdeItSSw1DxBCLQaLpr 3CzWrxMbiZYH
ZJXWQNtU5R9qFW3BVyybzsuWvhYwXVzdT67qt1dXH2UNNI0MbBIJWkVB5UaD axdg2QcqxGRU
k/he2nuJf9Lu00+dzJc6YhT7PO5OWLArvAY8sqsFc7tyne+4Ap/8J1YRefNe 2V9ZWEUt1Ct9
MsbRyvb+YZAqo7SdIZWG5RkJ6kA07P4maNfhEtba7uLp7hbdba1eC5Ys8cro S0UjIAfJccsN
uAW2qd1SWfgVJYLmHW72e9tZbu+mjsQyrDELh5hkMqLJu8qZ1OWIBdsdFI1I PDQW6s7u81bU
r+4tLjz43uGjA/1Uke3ZGioBiZzkAMTtySFAABn6t8QtG0XVr7TbwSCe0t5J 8RzQO0myEzFR
GJPMU7FY5dVXjryubB8YRRubWbSNSi1Quixaa3kmWUOsjKysJDEBiGY/M4P7 s8crur6l4Bst
TEsEup6lHYO9zILKMxeWklxHKkrhjGXyfPlbBYgFumAANDUvC9tqGqNqgu7u 1vwkKxTwFCYT
H5wDKHVlJK3EqncCMEYAIBoA5uHxjexaZa3t558fkS6vfXsJSMubS1klj8kb SV8wM8GMHB2N
lv72pqPiLUvC8IvfEItJ7SZJmWPT4mD27RwyTlCXbEoKRON+I+Qvy4Y7JNL8 IJY38wu5f7Rs
TaSxR/awrOz3E8kt1vVVVCrnyQBjjYQAMndHq/g1r7QdUsxqV3ezy2U9tYLq Eislo0kbJkFU
3McNt3uXfG7n5m3ABf8Aj/T9It5Dqtld6fdo8araXUtujOJBIUYSeb5QB8mX 7zg/IRjLKGsa
L4103xBew2umwXc3mW4uHmVFMUSl5YyGkDFSQ8LL8pbdkFdyhmUPg+KRzdTa vqUuqB0aLUm8
kSxBFkVVVRGIiMTTD5kJ/eHnhdthPCtiUv0u5ru9GoWS2N39olyZUDSsTkYK kmd+FwANoUKA
BQBj2fxK0vUgken2N3eXj3CwC0tZ7WVvmjlkDF1mMQGIZOC+75RxggmPxD46 KeF9Wm0WyvpL
+20+eaUqsP8AoDqZYwZN7gNiSGUfJ5n+rPUFd2pa+D4otbi1i71fUtQvInjZ HuPJUAIk6BcR
xqMYuZD65284GDXvPANlc2t9bwanqVmmoJPHeGAxEzxyyyylDvjbaFaeUArt OG5JwCADUvte
/sq8kXUrKeGw4KahGPNhUYGfNx80WMMSxHlhQCXBO0bFZc2gWN3qg1C+WS8k jdXt47ht0Vuy
4wyR/dDg5PmEFxuIDbcAalABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAUpf+Ph/qP5Cpk6CoZf+Ph/qP5Cpk6CqEYGq/8AIdtf r/7I1T1Bqv8A
yHbX6/8AsjVPQM36itjuiY5z+8cdc/xH3P8AnsOglqK2O6JjnP7xx1z/ABH3 P+ew6CQJaKKK
ACsTW9attNd0vNUsNMt9iAz3j7Q7PvwqneuDhCepP0xW3WbqFhcSzNc2tz5U hjCMpj3bgpJG
PmXB+Y9T6dKaAi0rXLW/R5E1Gxu7fYHS6tmHluCXBAO5gceW2Tn19KqeNfEj +F/CF5rltFHc
tavEDGzYDAyqjjI6HBPPOD2PStPTtPks5JpZrjz5ZQqkhNoAXOOMnn5j39Kq +K/DsXivw5c6
LcTvBDctEZHjALbVkVyBngEhcZ5xnOD0rWg6arRdT4bq/pfUTvbQ5q18Xajq mkWviHStW0q6
0qfULa2a1bTpEniEs8cZR388gSKJM524OAQMEV3U5mW3la3jjknCExpI5RWb HALAEgZ74OPQ
1yn/AAiOox2dppNrf6VaaHaXcE8VrBpsgkCRTLKqmQzkFiUG5yvJJOMmuvqK nI5v2fw9L72B
eZy+l+LJ5NMmv9asYLKMXctnBHZzS3ks0kckkbgRrErH/Vsw2hjtBJChTVh/ GugpKsZupzmI
TSOtnMyQIWdMzOE2w4aOQN5hXbsbdjBqM+F5orC2S0v40vLTU7nUbeWW3Lxh pnmJV0DqWAW4
cDDLyAemVOGPBGqG/wBWshfwR6ZqenrDfTNbbnmeSe7knEOJB5WPtB27hJjc v3tpzAzoNb8T
/wBi+IdF017PzLfUPM82683H2fDxRp8mCX3STxpwRjdk8A4jg8a6Z5TNeGS3 dLi4icJFJMsK
RTyQiWV1XESN5THc+Bw3J2k1c1Xw9b6xqKTXjb7U6fdWE1vgjzEnMRb5gQRg REcf3uoxzzdr
8Pr6DSbmxl1+O4fUreW21Wd7HDTo808pMQVwIn/0mUZIcfdO0YIIBqal4zsr TWtPsopf3L3c
sV5dS28iwRpHBNI+2cgR7laIBhuOMOCAQcbGma1Zav5otWnWSLBeG5tpLeRQ c4bZIqttOGAb
GCVYA5BxzeoeBJtSBsJtVjXRTcXlx5CWpFxuuY51kHml9uAblyP3fQKDnBJ1 PDHhlPD32pxH
pUclxsDLpmmrZx4XOCQGZmb5jyWxgDAB3FgCnoPjGa/t7G41eytNNgv9MbVI JEvTKqQqIy/m
lkQIQJkPG4cNkjAzHrPjeGO1tU0zz0uri7W3YXOl3LyQgxSyB/swCyyK3kso IwM7jk7GFR2H
w403TdB/sq0eO2S60wabqklvbrGbxRGyiXHO2UMzHd82QzBg3ylZNJ8DJpt9 Z3gOlW8lvdi4
aPTNKW0jkAhmiAIDMxb9+TksRhQAoJYkA1Lnxfodo90s93JGlqkrSTG3l8o+ WpaRUk27HdQr
5RSWGx+PlOCTxfocSQyG7kaKVPM82O3ldEi3FRK7KpEcR2sVkYhGClgSATXP 3fw0trh9WEcm
mwi+S8K3I0tGu1e4WQNvnLZZAZWwqhDgIpYgNu0PEXge21/WRqLrprvJbpbS /btNS7ZEVnYG
EscRv+8bJZXBwny8EMAaEXi/Q5bieE3ckIgeZHnubeWGAtEWEgWV1CMV2OSF Y8Ix6KSA+LdK
W3SZl1IF3ZUgOl3PnttALMIvL3lBuUF9u0FgM5OKz77wPDqOjR6XcX0gg+23 11I0cYDMt0ty
pQZJAKi5+9g52dOeI9W8HXmvfZLjVrjQ72+tPNSP7To5ltvLk8sn900xPmAx jDh8YZht5zQB
1H2+z/s7+0ftcH2HyvP+0+YPL8vG7fu6bcc56YrLHizTGt3ugLtrTescMyWs jfanIJxAgBeU
BRu3IpUqchiFbbcGjWZ0OHSJk821iiSJcARkbMbWXywoRgVBBQLtIBXGBjLn 8NX2Lc2+tyO9
jcC5sGvofP8AJby5ImRyrI0qbJDjJ37huZ3zigCR/GugpKsZupzmITSOtnMy QIWdMzOE2w4a
OQN5hXbsbdjBqS58X6HaPdLPdyRpapK0kxt5fKPlqWkVJNux3UK+UUlhsfj5 Tjmx4I1Q3+rW
Qv4I9M1PT1hvpmttzzPJPdyTiHEg8rH2g7dwkxuX7205ku/hpbXD6sI5NNhF 8l4VuRpaNdq9
wsgbfOWyyAythVCHARSxAbcAdJN4o0mCztrx5pzZ3G4pdJaSvCFU4MjSBSqR 9w7EKV+YErzU
cXi/Q5bieE3ckIgeZHnubeWGAtEWEgWV1CMV2OSFY8Ix6KSMvxl4H/4Szzv9 IsV860Nr/p9h
9q+z53fvIPnXypDu5bnOyPpt5kvvA8Oo6NHpdxfSCD7bfXUjRxgMy3S3KlBk kAqLn72DnZ05
4AJLLxla3WtX8DrPb2NvFZBGubGeCRpriaWIDbIoJUlYwCBjJbJ44kuPFE0K XWpR2Eb6DZPK
l1eG4Kyr5TFZWSLYdyIysDllY7H2q3yby00LWo9SvNRutatGu7lLSHda2BjV YoZXdlIeV8l1
ldc5G3ggZFFx4XmmS602O/jTQb15XurM25aVvNYtKqS7xtR2ZicqzDe+1l+T YAWIvF+hy3E8
Ju5IRA8yPPc28sMBaIsJAsrqEYrsckKx4Rj0UkRv410GKJXnup7dnlEKQ3Fn NFMzsrsoEbIH
O4RuFwPmZSq5bisODwTfatYXVjrl3HFp5vdSmgt7aHbOouHuEDNKXZWBjnZg NgIJXJ+Ug3NJ
8DJpt9Z3gOlW8lvdi4aPTNKW0jkAhmiAIDMxb9+TksRhQAoJYkA2L/xRpOlz 3MV9NPb/AGaJ
5nkltJVjZVQyMEk27ZGCBm2oS2Fbj5TiMeLtHNu8pku0dHVPs0ljOlwxYEjb AUEjAhXOVUjC
Of4Gxzes/DT+1766m+3WMfn/AGo/aW07feHz4ZYtjz+YN0aed8q7RhY0XPGa 3NU8LzXniD+3
LS/jgvIkgFuJbcyRq0YuVJcB1LArdOAAVwVByRkUAZ9v43MlhZXsyxxQNcaj Ld74JEaKxtXl
QybT8wcN9nBUjd87YUYO3Ql8UTaSPP8AEVhHplnIkjwSpcG4YbI2lZZVVPlf y0dvkMi/Iw3Z
278/TfB832u5tNaMd5ZmyuozLCphWdr24kluE272ZQoSEKc/xNyT908R+F9X 1bw5qcF3fx6n
PHZXKabEluLdjM8DxBpW37Wfa5XgRp87Hb93YAbA8XaObd5TJdo6OqfZpLGd LhiwJG2AoJGB
CucqpGEc/wADYktPFOjX2ow6fbXnmXksXnLAInDqmXUlgR8m1o3Rt2NrYVsM yg4epeBZtbdr
3V7zTbzUA8JjWTTS1oVjWZVDwNIS5/0mU53jkIcfKd1zTfBqadBfxR3v2dbz T0sz/Z8C2vkE
PO5eILwnNwdvBI2AlnJJoAsP400SOJWd75ZHlEK25025E7MVdgRD5fmbSI5M Nt2/IwzkGqfi
Lx1p+meGr2/sHkubuOyluIY0tJpRGyhgBOEXMQ3oynfswUccFWxT0b4ff2Xr 0Oq+dpUHlyxS
fZ9M0v7JG2yK5j5HmN8x+053ekYGOcgvPAV41jq9tYazBB/a8Vxb3bT2RlxH JNcSr5YEi7WX
7TICTuBwpwuCCAdJNr9jaaoNPvmks5JHVLeS4XbFcM2MKkn3S5OR5ZIc7SQu 3BOpWPfaD/at
5I2pXs81hwE0+M+VCwwM+bj5pc5YFSfLKkAoSNx2KACiiigAooooAKKKKACi iigAooooAKKK
ooooAKKKKACiiigAooooAKKKKACiiigAooooApS/8fD/AFH8hUydBUMv/Hw/ 1H8hUydBVCMD
Vf8AkO2v1/8AZGqeoNV/5Dtr9f8A2RqnoGb9RWw2xMMY/eOemP4j7D/Pc9TL UVsNsTDGP3jn
pj+I+w/z3PUyBLRRRQAVFdDdZzDGcxsMYznj0wc/kfoalqK6G6zmGM5jYYxn PHpg5/I/Q0AS
1Bd3H2W3Mm3cSyoozgFmYKMnsMkZ/rU9VtQt3urNo4mVZAyOu7oSrBgD9cYz QBVFzdWsm+4t
7dY5ZUUmOcswLbUHGxc84zk5x9AKn1aO+m0a+i0uaODUHt5FtZZBlUlKnYx4 PAbB6H6Gud07
wbb6ffRz2uj6Jp5DKXlsoFRyqsH28IuQSo7+/at7U0uLTR72bR7OCTUY7aQ2 kTAKryBPkUnI
4JVR1HAHIxTYHLeDv+E4v/CGl31/r2kSXF1AJyz6Y7ttf5lBKSxrkKVHCj8e ptfDmTxNL4du
X8VajBf3wv7iFJYECgJG3lEYCL/GjkcdCPoKvg7/AITiw8IaXY3+g6RHcWsA gKvqbo21PlUk
JFIuSoU8Mfw6C18OY/E0Xh25TxVp0FhfG/uJkigcMCkjeaTkO38buBz0A+p3 rcttLb6bbedu
u24kcXN4msoJ9YhkiuA2lw+dIdoxKAgdvL5+YqGXPTBdfUVopqFlJfSWKXdu 15Gu57dZAZFH
HJXOQOR+Yrndb8M3t/aaybSW3S8u5mMDOxC+W9vHDIrkDOPlLADjcsZPTFF5 4Zvb62l015be
Kz867nS5Vi0jGdZhtMeAAF8887znYOBu4z1A0YPFGlXFzehL+yNnaQwyPdrc qYwZGddpPQEb
B353D8bGp6zb6box1QJLdwHy/LW0AkaXeyquznDZLDvWHe6Dq2p6i2oXMVrD JH5PlwQX8q79
gnU5lVFZP9fngHO3B4PGiuiSroFvYR+VHIl3FcuPMdwMXCzMN7ZZjwfmOMnn Cg4AIlXxJpz6
o1ksm5FtDeG7DKYAg25G/PUK6N/usDnkVNJr+jQ28NxJq9gkE+7ypGuUCybT g7TnBweDisuf
wzJBJG2lSpCqwzq2W2M2+SFggZRlV2RGMMOUXZjO0VnWOk61pWvrcQ2VvK06 3LkS380ixgra
qAZmjLFiYmIBHTODxQM6v+1dO/tH+zvt9r9u/wCfbzl8zpu+7nPTn6VDa67p l3LBAl/ai7mj
WRbX7RG0mCu7orHPy85GRjkEjmud0rQtRt1n0nZF9hgu7N/tbsyvJ5EVuflj 2kEExbc7+Mnr
twbOmeGb2y0EWMktuZftNjNlWO3EK24bt1Pktj6jpzgA34NV066vJbO3v7Wa 6iz5kMcys6YO
DlQcjB4p97f2unwiW7nSJWbYgP3nbsqgcsxwcKMk9hXNeH4L2PWLK0ktsWuk 2ElkLnbIvmnd
EFOHRRyIifkLgevQnWutJmTVH1bT5YhdtGI3juYwyug52q4+ePJA6EqOTsLE mmIfLrkEUz/6
PcNZxMUmvVC+TEw4IPzbiAeCwUqvOSNrYswarp11eS2dvf2s11FnzIY5lZ0w cHKg5GDxWXPo
961peaRGbc6betMZJ2ciaMSszSKE27WOWbDZGMjKtt+bLGhajrGnT2NwkVna rd37xzFmaR/N
M8YzGVAAxLuB3HIA/vZCA6WPWtKmtjcxanZPbhmUyrOpXKqXIznGQoLH2Gae 2q6clxPbvf2q
z28ZlmjMyhokABLMM5AwQcn1FYFt4YmbULS8ube3UxXKSuj3s12xCRzBSHlH UPKCAAMYJySQ
BW1rwxq2qTTDzYnDfads0l7KBiSGWNF8jaUXb5ijcDkhSerEUDOlTWtKksZL 5NTsms422vcL
OpjU8cFs4B5H5iqNv4mt7i3tLhRF5E9xcoZBMCqQwmQGbOMbCUQZ6DzBz0yz UNHvZdfXVrU2
7tCsPlwyuUDlVuFYFgp2jE4IODkqRgZzVG00K4upriy1JPJQ2l2rvbsWVvtc 7OVV2Ucosa9u
d44GOQDZj1yDcftdvcWETKzxTXYVFlUAsSPmJUhRu2uFbAJx8rYmTWtKksZL 5NTsms422vcL
OpjU8cFs4B5H5isPxDp2q6lod6LyK3LWttcNbraFna4kaGSMEqR8gw7fIC5y R83y/MX2galq
d3/aNwlvFco0Wy2gvZUVgizDPnKqspPnk4Cn7mM/McAHRJqFlK0Sx3du7TKr RhZAS4YMVI55
BCMR6hT6Gq39v6N9j+2f2vYfZfM8rzvtKbN+M7d2cZxzisvTvDc9jJdzxPb2 1zNZCCGZd07Q
SGSaRjmTlxmRCSSNxXJC8AV9P8OahFr0OoTLFFHHJGxQ6hNdsQsdwp+aRQRz MvHTgnr1YjW1
jxHp2kaO9/Jd2rbrd5rZGuFX7ThcgIe+cjpnqKvpf2r30liJ0F1Gu8wtwxXj 5gD1XkDcMjOR
nIIrl7jw3qqWerw2v2KVtThngYyzNGIg007qwwjbjifkcYK9TnjZ1HSZtXuF S7lijsYZFkiS
OMGVnA+9vb/V9WHyAMMAhxnAAOq8P/8AIbt/+Bf+gmu3riPD/wDyG7f/AIF/ 6Ca7eoluNBRR
RUjCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigClL/AMfD/UfyFTJ0FQy/8fD/AFH8hUydBVCMDVf+Q7a/X/2RqnqD Vf8AkO2v1/8A
ZGqegZv1BaBRCwUDHmyHj13nPc9//wBQ6CeorY7omOc/vHHXP8R9z/nsOgkC WiiigAqC9CtY
3AcAqYmBz0xj6j+Y+oqeoro7bOY5xiNjnOMceuRj8x9RQBLRRRQAUUUUAZ73 0kkgNvZ3M0cc
jAuhQBiMqRy4PB9Rjj6GrdvcJcwCVAQMlSG6qwJBB+hBHHFcnqehyz3Z82DU mJeQRtaatLbI
wZ2cfIkqAthjkkZ46kAV0GnWLx2Crcb1lZnZlWUjbuZjjg4zh+3cdeAabQEl xa6dbW8k8tpb
CONSzHy1HAqOxi06/s0uI7KABsgqYlypBwQeODkUmraWNQiEis4nhG6IZypY cjIP/wBY98gg
EQaLpRtgLyfetzIuGjDfKo6Ae5wByfyGABnzS5rAGrXOiaJFBJe2g/0iXyYU gsXnd32s+Aka
s33UY9O1WLGLTNQs47qGwCRvnAns2hcYJHKOoYdO4569KoeJ9FfW7nQY9s/2 e31Bprh4LloH
RPs06Ah0ZW++6D5T354zXL+JvBN1datD9mXVbm1S0WGzdLqCR7SfzJGeVpro PLHnfHh4dzjy
+nyIKsDt7+PSdM065v7y3t47W1ieaZ/JB2ooJY4AycAHpVj+zrH/AJ87f/v0 v+FeaeIfCOu6
xrt+8NlJDcXqXltNeItrHavA9tLHCGZR9pcgmDcGyoZWIGFTFzVtGv49H1uL R/Cc8EOraJ/Z
8FjA1rF9kkVrnJkAlCBWM6sChY8NkA4yAd//AGdY/wDPnb/9+l/wqvfR6Tp1 nJdXVvbxwpgE
iEMSSQFVVAJZiSAFAJJIABJriL7wXdSaDIv2SdpZtburu+hhaCWS5tzLcGFF WfMJUGWOTY2A
DvYASdegsdJNj4Ej0+602+vtmStoJ4fPUGUsgVlMccbICpAQgR7AEJ2qSAae mtpWq27T2+ns
iK5Qi6097ds4B4WRFJHPXGOvoauf2dY/8+dv/wB+l/wrzjU/C2r6nFbNd2eq zaTFLOYdMeW0
u7mIMsOxpDdGSNsMlyQ29nUSqAQCyrHqmhT6abN9U0iTULv+09JFvrEksVw1 qiyWsbRmV9su
TIsrZVMHzcnBZgADu5rnRINcttGktB9uuYmmiUWLshReGJkC7BgkA5I+8v8A eGZNTfRtHspL
y+tYo7eNHeSRbUuEVEZ2LbVOBtU8nqcAckA85440zVtVvJ4LDSp7iOXw/qNk JxLEqCaYRlFI
Zw3/ACxIJxgb15xuK5fiXwHd3N5cWGgadaWOlzW+FWLZDAkz2t/C7lF5zmW2 BIUkjHXbwAd+
LTT2uHgFjFvRFck22FwxIGGxgn5TkA5HGcZGafn6T/bkmkf2ePtCRRSlhbBk xJ5u3JAO3/UP
ktgcqASTiuQvfDl3Ot2LLwz9i0i5tLSGTTkis2lAjlunYRxszQbt8kLndxtZ sfOBjLsPCniG
3e2uLjQ5L2K3Rgtndz24MkSrqgjhYKTGo23FumFGxQ+AMKQAD1P+zrH/AJ87 f/v0v+FH9nWP
/Pnb/wDfpf8ACvMJvBMkunWQXw/fW9qJZ5LzT7e30797cOIQkyQyNJAsaqjo OfMGf4tzs3Ue
F/C9xp0msT3jTx38/lQw3rXIuJAgtLeNnVmXG4yRtlig3lFLKQFAAN+5XRbP d9qWwg2xPOfN
CLiNMb35/hXcuT0GRnrVfTLnRNX80WtoFkiwXhubF7eRQc4bZIqttOGAbGCV YA5BxgReFr+C
xnsPsdi10Zbe7GqJLJuu3t5klWOfzC8q9NitvlwoY4XCoc/xnb3WsWkGq3+h zw29tLbWY065
aCSS782+tGYYVzGFxEFG5vmLtkKFBYA7/wDs6x/587f/AL9L/hR/Z1j/AM+d v/36X/CvNL/w
dfXYRzo93Dov2iZ4dEtUsXa33RwKpMU263Ubo7hsoSw88f35ANSy8J6jZaXr 7va/adRuvIt1
kuJ1uXltxbW0c+0yAIZGMcgy6qHZIy42gYAO3/s6x/587f8A79L/AIVT1M6X pVqlxPYRMj3E
FuAkKk7pZViU8443OCfbPXpXCeHPAzy6xGutaD5ujQfa/stvqcVo/k71s9uI of3aZaO4Pygd
yeW5jt/C+sNb6Z/a2gyajrAuNLnGqSSQSNZpELbz4zI7+ZndHO2EDA+ZnJLN gA9B0qXT77z7
izs0RYLiS3WXylXeyEo5XHOA4dOQMlSRlSCdOvO9E8N22rJ4bs9V0u0voNC0 y40y7juokkWO
5RrZVYI3OHWN3VsAlGUnG4Cs8eHPE0lx4dur2xu31SzTTka8hNo2yJTGbgTT OfPLk/aMiNtj
Kyjnc+QD1Sqeq6lDo+l3Go3KyG3tk8yYoASkY+8+M8hVyxAySAcAnAPnejeB 73S7HSzBpEFt
dWtpo53RGNWjnWY/bmBB+80QVXYf6xQFy2MVJ4X0e58Fpc6tqkGpGWCyMd25 a0xqNyWTBiWJ
RJO7MGCtOwfMgGCZGwAekCeFrh7dZYzOiK7xhhuVWJCkjqASrAHvtPpUlcP/ AMItfv4e0HRP
sdiLrTdPihOrvLIGt3CBWEHllJTu2Yb54vlZfv8AzKO0gjaG3iieaSd0QK0s gUM5A+8doAye
vAA9AKAJKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooA
KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
igAooooApS/8fD/UfyFTJ0FU7ifF88KRPI4UO23ACg8DJJHXB/I0v23yx81u 4+skf/xVUIy9
V/5Dtr9f/ZGqeqV5crc61bsqshVyrK2Mg7GI6ZByCDwe9XaBm/UVsCImyWJ8 x/vEk/ePqBx6
e3c9alqK2G2JhjH7xz0x/EfYf57nqZAlooooAKiugTZzBSwJjbBQkMOO2ATn 6A/Spaiuhus5
hjOY2GMZzx6YOfyP0NAEtFFFABRRRQBHIWEkIUnBfDY9Np68Hvj0+vYyVFMM y25xnEhPTOPl
b2OP0+vYy0AFR25ZraIuSWKAnPXOPoP5D6CpKgjtzEiIs8gVAAFCoBgY9F9j /wB9H2wAT1Ri
1azm1m40pJM3UESyuvse31Hyk/7y+tSXFrNNZSwJezxSOAFnUJuTgdPlxzj0 7nGOMcDaeHNS
bxA+nC4eGa2xcPqabt8it0xk5y2GBySPlPXvEpNNWRcYpp3Z6RWXpviXQdZu Gt9L1vTb6dUL
tHa3SSsFyBkhSTjJAz7itKJGjiRGkaRlUAu2MsfU4AGfoBXnNhoviLT/AIX6 cLfV9V+1f2fZ
xyWc1vH/AKKmYvO2rGiTFljEgCh9/od+0iyD0io454ZnmSKWN3hfZKqsCUba Gw3odrKcHsQe
9eZumsL4ehtZbzVWs3u5JI777BqAkjARAsXkxz/airM0zb5XwCmNu0xGo9Ig 1lLK51G9i1mP
XLp9Mv59izqjwIlmLn92v7vzcxzAxgeYQCApUgEA9Uorz/TG1PW/HclyZdct 9FEtxLGksc1s
km2Kw2KyuoIXeJyAMbsOOVLhjwFDr6aiX1e+vpZjaf6fDNZzxxpc5X7sksrI 2D5oH2dVjI5O
B5YoA7hb+zfy9t3A3myvBHiQHfIm7cg9WGx8jqNrehouL63tJ7SGeTZJdymG AbSd7hGkI46f
KjHn09cVx/8AZeqWfiO+NvZfarHT/tGqafbb/LElzOmAokI+9v8AtpYEkKLi M84ATj5bPxNd
iaz06XVbtY90lnPJaXlqYrh7K/Q4e6dnHzfZxu3hAWXABJJAPaKjnnhtbeW4 uJY4YIkLySSM
FVFAySSeAAOc15vr+oavrOqXMulPrNrpASzS4eTTrxCAPtZfZEvlzMd5tgxi IOMbsqGFdBBb
lvAMSa3PqU5RxIk8dlJ9oXbNugcRfvXJXEZxJuYhcyDO8UAdBpurabrNu1xp eoWl9ArlGktZ
llUNgHBKkjOCDj3FXK8vm1CafXNPg1q58Ry6YYr02slvDdW9zcBfsmHmitlR htd50GUUYCnB
3BmLCHxg+vac+r319FfD7HmGGzmkjdPKi+0bpElW1XL/AGgHerOBymf3QoA9 Qori/D8eoS+G
rmOGbUofErW8QvpNQFx5QuMHzPJMgMQG7eA0Ssg+U7XUBTT/ALLnuLnTLOa0 1y2upNQH9q3I
vZSZ4xbXBVlniYYh80ZEY8sKWH7tN4BAPQKK8n1+48TRaKVh/tWC6sPtv9ny pbXly9yyzyrC
jCJwOEjgIecSLJ5mecPusXdlr8VtqF1bvrhuvK1m8jAnnYfaIbnFmFTONpRm xGBskGCVbaMA
HqFFef6NDr//AAnMkt5fX3/H3c+bb/Y5/J+zZfyf3rS/Z/u+Sf3SeZnhv+Wp qxNY+KrnTtIf
Q76+gtRp8IZdQvIorkvjkyh7SY+ZjG47hzngdSAdhe31vp8CzXUnlxtLHCDt Jy8jrGg49WZR
7Z54qPTNVsdZso7zT7mO4gdEcMvUB0V13A8qSrq2CAcMPWq+lWV22iW9vrvl 3V2j73Lukw3K
+5DkRRgkYUghFwQOpGT5fpkHiC18M2FvNFrLmJIEh0pVu7fzyLG0UD7TF/x7 hZPNGH/dsxfd
grvUA9YbVbFXtU+0xsbq4e1h2fMGlRXZ0yMgECKTOcYKkdeKuVyfhLSoLWbU kuba7+3x6nc3
X+kea0SCSaZo3gLZjBMUnzeVz8xD88UaBZ30eqLLp9vd6d4f2HFpfS7i5/hM URBaBMbcKXUK
FZfIUncADrKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
iiigAooooAKKKKAMo/8AIYvv+uEH85KpXvf8Kun/AJDF9/1wg/nJVG96GriD M0/8htf+uif+
k4rWrJP/ACG1/wCuif8ApOK1qQG/UFoMQtyD+9k6AD+M+n/6/XnNT1FbHdEx zn94465/iPuf
89h0EgS0UUUAFQXozY3AyB+6bkgEDj0bj8+KnqK6O2zmOcYjY5zjHHrkY/Mf UUAS0UUUAFFF
FAEE4/fWvIH709QDn5G6Z6fhz+GanqC4LboQjhWLkAnpna3bcM/Tn+ocVuOc SxDrjMZPrj+L
/d/I+vABi6n4mk03V49OGh39zLNn7O0VxaJ9owoZtiyTq5255+Xj6c1ZsvEN rql48GmxT3cc
F1NaXc6BVS2ljAJVg5DNnIAKBh6kDmvH/iDbzSeJvFsp1jQ4L1fsH9mLd3sK 3UewKzeS7Sqb
fBJY5HzZ465q94IuJh8SrkWOt2H2O71PUbqaKLVoZlu4nCmHZCkjEOCrMW2q dowWP3a9P6nQ
9jzqqua17ab2Tt+NvVP5RzO+x7RRXH+Pf7H8zw1/b/2H+zP7Vbzvt+zyf+PS 527t/wAv3tuM
98Vzd/rGp6aEh0rUbTTPDk1xM9he3F1HbRCJY4AkcckkMq7Gdrkou0ZSMFGE agHzCz1SivJ9
d8Tat9i1OG9v4Jbj+xJZfsFgsTxxMLMyO13BPH50alzhedpBjV1Un5zxJ4v1 KwS6lg8SeRqq
S6kjaPttz5MUNvdNDLsKGUZ8qGTLMVO/gbWAoA9Yorn9GlvbbxDqWjXWoz6h HBaW10k9ykay
AyvMpX92iLtHkqR8ucs2SRgDk9J8VWUfwo0OHS9ZtFu4rKzt57iO8iRLFvKz md2SQRA+WyDc
hyzKvBOQAekCeFrh7dZYzOiK7xhhuVWJCkjqASrAHvtPpRPPDa28txcSxwwR IXkkkYKqKBkk
k8AAc5rxuz8VXU1xqGrN4hgi1ddKVLO1glgkTVpIbq+SNRlA0u7Yg/dCMt5n AXKgWPEWv67d
2viq0ub+xEP2TU4ZNN88NNFAkUwjl8lYQ8e4LG295ShEnABdAAD2CiuH8X2N xdeMtCurCPzN
S0/T767tE3AeY6yWoaPJ4HmI0ke452792MqK5uOWfwrHrOmQ6vHZXEusGa41 S4uIrOCWU2ds
0uWkimVXkeRnWML0V8EBcEA9coryvQvGeoarLDdSa7H/AGlNcacI9CjEO14Z oLZ5nCbTMQvm
zPnfgbOchSDX03xReaho+hOuvR64btNPn1HfHbyCxna7tFEeI0AQsJJsB8sD ECpBUmgD1gwQ
tcJcNFGZ0RkSQqNyqxBYA9QCVUkd9o9Kkry+28Q69Z6DoVxNrM902saVFe3M 88MI+xDzbVZZ
I9iKAqpcyuTIHA8tSeAwa4L2fXfAXju1tNWk8QJGlxa2VxGInaUNZxtsHkqq sd8jjgZ7dqAP
RKK87m1XWJ01r+wfEkmqwWWhC6tJIYYJnublmu1XDRoFIBjUbVXJKLz98PX1 /wAbz3GqXMfh
7XdNfTVSzWa9W7iWK0L/AGsszTbJFQsYoE+dWHzAAAsGoA9MorH8LXd5feHL S4v54Lidt486
AkpKodgjhiibsqFO5VVWzuUbSK2KACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooA
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDKP/IYvv8A rhB/OSqN70NX
iM6xfAf88YP5yVUv43VdzIwHTJFXEDKP/IbX/ron/pOK1qyT/wAhtf8Aron/ AKTitakBv1Fb
bvKbf18x/wC903HHXnp+HpxipaithtiYYx+8c9MfxH2H+e56mQJaKKKACorr d9jm2ff8ttv3
uuP9nn8ufSpaiuhus5hjOY2GMZzx6YOfyP0NAEtFFFABRRRQBFNu82329PMO 773Ta3px1x14
/HFS1BcBt0JRAzByQD0ztbvtOPrx/QuLXHOIoj1xmQj1x/D/ALv5n05AMy+8 S2Gn3klrNb6q
8iYyYNJupkOQDw6RlT17Hjp1qzHrWnz3iWtvObiQyyQsbeNpUikQAskjqCsb DI4cgnoMmvKf
HFp4ruPEviLVbDT72aXSPsf9i3EbSq0O8DzvJiVCk+7JD7jwBjkDAveDF8S6 d4+1O1SzvU0q
81jUri7FxaFIlj+TyZY5Co3MzZXAZhtGdo+9Xp/2cvY+051e17fJO33Py1uu zcc+trHq9Fcn
44W9mPh+0sTIXudTKPEuoS2QkUW074aWIFwMqGwAclQD61j3uv8AiPQD/Ztl pEcg06yW+vDJ
f/alKvJNhTc3EsTIMRE7ysmN33cIN3mFnolZ/wDYtkdY/tR1nkuhygluZHjj O3buSMsURtuR
uVQcM3PzHPB+L/GGrwWmsLZxSf2XNb31pa3scYhaK4ht5mYiTzi7EPBIv+qQ dwxwN+5qHiHW
NHs/Ei3L2NzdaToi6hHJHbvEkkjG54KmRjtxCnG7P3jnkAAHYUVwc/irxH9g EtvZWk093rFz
ptlHCm9gsL3BMjq8kaklYNu3euOW3HIjFy61fUbrwZY3lwv2O+Oq2lvMsEyn pfxxOCUdgNwB
3JubbuKknBJAOworj/GXinUdC859Ktftn9n2hvtQh8hTiH5tn7xpk2bvKlGV WUjbnb0DYdv4
i1Lwpol3qMotLzT5NT1gRWqxNFKjRvdz5aXcwYHyWXAQY3g5O3DAHplFedwa rrl74k0Cz12y
jt54NTEsbARRsyvZ3o5iSeYgAocMWG7JAHyEkmTXrnxT4jt7K9uzaX97Hprn zX/0BRawSmWL
HERKPcDdzmUwcY3GgDvLext7Se7mgj2SXcomnO4ne4RYweenyoo49PXNFhY2 +madbWFnH5dr
axJDCm4naigBRk8nAA6153onjDV49G8NSRRSX9mLfTbTUp5IwWW4nWIZMrTB icTRPxE4Ocbg
SSkkfjHxImi6JPNJpT3WuWltc27JZyKlr5k9rEysplJk4usggpjZ33cAHok8 K3NvLA5kCSIU
YxyMjAEY4ZSCp9wQR2qvpul2mk27Q2iSAO5eR5ZXlkkbAGXdyWY4AAJJwFA6 ACuD1HxZrdpr
Q00NYtfwSmza58qUQuZJtOAfyBL2W8I5YnKZDKGZa1INf1671uTw7FNpseoW 7zGW+a0dopFj
S2fCw+aCpP2tRkyN/qycfNhQDtKK8/1S4vPFXhbwQ8n2FZNXliluYbm2M9s+ bKaUq0W8blDK
CAW4KqeSKz/G/inUX0vXbVLXztEvLS/sYrnyFj2TRW0zP83nFnw8Mi4MSDuG IA3gHqFFcHqn
i/WtLu7+Ga0jjuGcR6dYG1LNMjXEUCzifzRG4zKrGI+Ww3AEgYc9B4X1LU9R srldYtY7e8tr
gwsqmMFhsRwWRJZRGcPjaXJIAbgMAADcooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAy/+Yze5 /wCeMH85K5oR
Is0ZWFVIJ5EG3se/kJ/6FXSH/kMX3/XCD+clUb3vVxEzNP8AyG1/66J/6Tit ask/8htf+uif
+k4rWpDN+oLQ5hbgD97J0IP8Z9P/ANfrzmp6itjuiY5z+8cdc/xH3P8AnsOg kCWiiigAqC9O
LG4OAf3TcEgA8ercfnxU9RXR22cxzjEbHOcY49cjH5j6igCWiiigAooooAgn P7614B/enqQM
fI3TPX8OfwzU9QXDlGhIBY7zhQQC3yscckf1/qHGZxnFtKcZ6Feevv7D/voe +ADMvvCfhvU7
yS8v/D+lXd1JjfNPZRyO2AAMsRk4AA/Cix8J+G9MvI7yw8P6VaXUedk0FlHG 65BBwwGRkEj8
a4f4seKNV8Naz4ZGmrPcR3v2m3uLKKR0NyreUAqlPmV+flZfmBPHUg9Dp9iu meM9Kjgl1WOO
70q7lmtr3UZrna6yWu3IeR1DLvcZU9zya6KmGnTpQqvaV7fJ2EndtHVyQQzP C8sUbvC++JmU
Eo20rlfQ7WYZHYkd6r3mk6bqFxa3F7p9pcz2j77aSaFXaFsg5QkZU5UHI9B6 VT16+uLdtMsb
WTyJtTuzai4ChjABFJKzKp4LYiKjPALAkMBtOHdDX9K8VaTaWV9JrLy2V7LI up3K2y4D2oB/
cwYJXJxlc/O3zdq5xnSf2Fo/9sf2v/ZVj/af/P79nTzvu7fv43fd469OKrze E/DdxZ21nN4f
0qS1td32eF7KMpFuOW2qRhcnk461xcHjxrzxBBf2y3b2ktuyW9rNKqKzzjTD Du2j5QGujknz
CNzkZBC1oHWNatvDPj++uGjt9QsHleBIpzcRwFbGF12F0XI3HcRtAyx69SAd hPpOm3VhLYXG
n2k1nK5eS3khVo3YvvJKkYJLfNn1560TaTptzpY0ufT7SXTwioLR4VaIKuNo 2EYwMDAxxgVx
9p4rm02w1m7M+patZ2j20ET3tmYLj7VK+0xNGsSNsAe3bIjZsSNjeQFEcOva t4i8Q6Hb/wBm
z2cafaZrmGW4uLRXMT222RCYkklUCZh5bqiM24HIVWIB1E3hPw3cWdtZzeH9 KktbXd9nheyj
KRbjltqkYXJ5OOtWLXQtHsdRn1Gz0qxt76fd51zDbokkm47m3MBk5IBOeprj 7T4lz3diL2Pw
3fPbzfZ3tCqSx+Yss0UShmljSMSEShgEd1O1vnAAY6B8a3S+IxpB0OeXyZYb a8ltlnlEUsiI
x2sIfLMaiRSWd42wGOz7oYA6Cx0LR9MijisNKsbSOOUzokFukYWQqULgAcMV JXPXBx0q5HBD
C8zxRRo8z75WVQC7bQuW9TtVRk9gB2ri7Tx7eNpmnXV9o0EMmrWkVzp8cF6Z Q3mSQRhZWMa+
X81zFkqH43nqAGk1XxtqGkXsdhNoElzeR263N3FYG4uQqM7qgiZICGciNuJP KGcAMRkqAdA/
hrQZLi0uH0TTWnskRLWRrVC0CocoEOMqFPIAxjtWXb/D7w3a+HE0OHToEtT9 m+0OsEYe78h1
dfOIXD5K/Nkc7m6ZrU1/Xbbw7pbX92kjxhwmFZEGT/eeRlRB7uygnAGWZQc+ TWNeguLawbTt
Nl1S7Sa4SAXjpBFDGY1YGXyyzuWlUj92owSP4cuAakOhaPbwW8EGlWMUNtny I0t0VYsush2g
D5fnRW4/iUHqBVPX/Cun+IbJrWdY4Q9wLmR1tLeUyOE2AsJo3UnbgZxnCgZx xWPp/jubUgL+
HSo10U3Fnb+e90RcbrmOBoz5QTbgG5QH950DEZwAadp8S57uxF7H4bvnt5vs 72hVJY/MWWaK
JQzSxpGJCJQwCO6na3zgAMQDtLTSrGysrCzgtoxBp6KlorfOYQqFBtJyc7SV znOCfU1Xn8Na
DdX8t/caJps15KhSS4ktUaR1KbCCxGSCvy49OOlY+oeMpdM1mxsbiwjkSR4I LuS1eaX7NPKw
UIW8kR4y8Z+d0bawITlQ1Pw/4n8QXnh7w8kun2Nzq+o6eLwM960cbxKkO52K wnbIWmX5ApUD
PzcAEA6iLQtHh+3eVpVjH/aGftu23Qfac5z5nHz53N1z94+tWLGws9Ms47Ow tILS1jzshgjE
aLkknCjgZJJ/Gub0fxhd+IbTUbvStDkkgtrdJbfzrlI2uZJLeKeOPHIQ4l2s ScD5SC2W2WDJ
qetatqkdnqkmmppdwtuiJDHKtw5hjlLS7hnZ+8VdqFDwx3/MNgB0lFcPpHj2 81S1i1FtGgh0
xpbK3kkF6WmWS5igdcR+WFKhrlFJ3g4DHHRTXtPiXPd2IvY/Dd89vN9ne0Kp LH5iyzRRKGaW
NIxIRKGAR3U7W+cABiAegUVyeoeMpdM1mxsbiwjkSR4ILuS1eaX7NPKwUIW8 kR4y8Z+d0baw
ITlQ1Pw/4n8QXnh7w8kun2Nzq+o6eLwM960cbxKkO52KwnbIWmX5ApUDPzcA EA7iiuLtvHzX
2h63rVto8n9n6bZC7WSa4VWnLWsVwqbQDtO2QhieB8uN2WCSaVb6zdJNpsev zwyaF5NiZjCk
n26UW8UjSzb8ttPmAbUZW4Y7yWGwA7CiuH0jx7eapaxai2jQQ6Y0tlbySC9L TLJcxQOuI/LC
lQ1yik7wcBjjopr2nxLnu7EXsfhu+e3m+zvaFUlj8xZZoolDNLGkYkIlDAI7 qdrfOAAxAPQK
K5PUPGUumazY2NxYRyJI8EF3JavNL9mnlYKELeSI8ZeM/O6NtYEJyoan4f8A E/iC88PeHkl0
+xudX1HTxeBnvWjjeJUh3OxWE7ZC0y/IFKgZ+bgAgHcUVy+geKbjxWl6+nWP 2W1jijMF3dMH
3PLbxTIDEpBOBL8w3Dou0ncdlzSPEDX2qXekXlrHb6laIrzLb3C3EQDcj5gA ynBHEiIW+bbu
ClqANyiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigDKP/IY
vv8ArhB/OSqV70P4VdP/ACGL7/rhB/OSqN70NXEDNP8AyG1/66J/6Titask/ 8htf+uif+k4r
WpAb9RWxJibIYHzH+8CD94+pPHp7dh0qWorYbYmGMfvHPTH8R9h/nuepkCWi iigAqK6JFnMV
DEiNsBASx47YIOfoR9alqK6G6zmGM5jYYxnPHpg5/I/Q0AS0UUUAFFFFAEUx Ilt8BiDIc7Qc
D5W64PT655xx3EtQXBCtC5UkI5Y4UsR8regP9Pr2LjcoucrLxnpEx6Z9v9k/ p6jIBVvtG0/U
bqG6uoN1zBFLDDMrsjxLIAHKMpBViFA3DDDnBGTVbT/DGm6ZqIv4DfSXSxNC r3eoXFztRipY
ASuwGSi9PQVyXxN8dXXgrUtC2mQ2F8lzHdCFU81MeXtkjLAjeu4kBgVOcEdC NrTn1C08Vabb
Sa5qOoWd9ptzc+XfW8MTIyPbhThIo2U4lbIb8gRXRUoVYUoVJfDK9vk3dffr 8xJq7R0d9Y2+
o2clrdR+ZC+CQGKkEEFWVhgqwIBDAgggEEEVTsPD+n6dcR3EP2uSeJJESS6v ZrhlWQxlwDI7
HBMSHHbBxjJya1qU1iLK2tFjN5qFx9lt3lBMcbeW8hdwCCQFjchRjccDKglh h3OreItI8Q6Z
Z3Mf9s/aLS7leHTLaO3xse2CMfOmPTe44fnePl4zXOM0IPBPh22iEcOn7FWI QqRNJlVCwqCp
3ZDAW0GGHzAxggg5JsQeF9Jt9J1HTBDPJa6lv+1ie7lmeXdGIzl3Yt9xVHB4 xxXNp49hm8QR
vbzyT6W1vIYo47cI08jiwMABZs5Y3ZGTsA34YDbuNhfFGpp4e8a6pLaSW8+k vK1raXYjJjCW
cUoVvKYggszNwxOGxkYwADpL7RNO1GWSW5t90kkQhZ1dkJUMHQ5Uj5kYbkb7 yEkqQScx2Hh7
TNNuI7m2gk+0RpInnyzySyMJDGW3u7Euf3UYBYkgIAMAYrn7LxvDbWGqXuoa npupWFkkDLqO
mKI4Hkldk8jLSOodSEJYuABMpbaBuNeDxv8A8JHrOjW+ifazbu87XgtHtZGj aJrf5Xcu0bRF
Z8t5RZ+VAIIYUAdBF4Q0OE5W0kIV42iV7iV1g2SLIqxKWIiQNHGdibVOxQQQ oAsTeHtMuNUG
oyQSGfesjIJ5BFI642u8QbY7jauGZSRsTB+Vcc3bfFbw3drK0DTyqvltGIDH O8qPLHEHEcbs
64aWP5HVXOcBSQQLkvxC0a28QQaJciSC8d4YpEkmg3QzShSkZQSb2PzoN0au g3fewrFQDUbw
tozWdnamz/c2Vp9jtgJXBiizGRtbOQwMMZD53AoCCDUcnhHR5khSaO7lEaeW 3mX07GdNxbZM
S+ZkyzYWTcAGYAYJBz7Tx9ZXFhb3c2malaC8t0uLCOYRFrtXeNFCbJGCktNC v7wp/rAegYrH
q3xG0nQZYIdXgnsbh4vPmgnnt1e3i3MoYjzf3mdjHbF5jccgEqCAdhWGfCGh i3S3gtJLOON2
aIWNxLbeVuA3KhiZSiMVVii4UsNxBbmtDUtUtNJt1mu3kAdwkaRRPLJI2CcI iAsxwCSADgKT
0BNc/feMJ9Mmtjf6Rdwm5RzDZL5Uk7nzraFdzeYI0O+4+7lgVwxZSCpALFj4 K0yz1a7viJGS
S4imgtElkS3gEcMUaDyQ3lsVMQYMVyDtx90GrEXhDQ4TlbSQhXjaJXuJXWDZ IsirEpYiJA0c
Z2JtU7FBBCgCm/je1WeGxXTb5tXllki/szfAsylESRvmaURthJY2wrscP0+V 9tO6+KHh61v9
QtGeR3skuCfLkhZpHgRmkQR+Z5ikCOT5nVVO3hvmXcAbl74X0m/1Fb6eGfzh LHOViu5Y45JI
ypR3jVgjsCicsCcKo6AARnwjo/2dIEju4UjdmiMF9PE0KsADHGyuCkXyr+7U hPlX5eBVew8S
3d94qfTV0m7WzNlDcrNIqRtFvedcyKzhgGESFVClhk7wp4FPUfFd5Y3llfSR eRpD6Jc6rc2k
1oReJ5IjJTPmBVb98Mgg4KEZ+bKgG4PDmkLpuoacljHHZ6gmy5hjJRWXylhw AD8o8tFXC4xj
1o1Lw9pmrXCz3kEjOEEbhJ5I1mQEkJKqsBKnLfK4YfM3HzHOXceN7Wz/AHF7 pt9a6k8sMUOn
zPAJJjLv8va4lMQz5UuAzg5TGMsoaOX4haNbeIINEuRJBeO8MUiSTQboZpQp SMoJN7H50G6N
XQbvvYVioBch8JWS69f6tcyT3El1dx3KQmeQQxlIo0XMW7y3YGLeGK5B245U GpIvCGhwnK2k
hCvG0SvcSusGyRZFWJSxESBo4zsTap2KCCFAGXYeNpdW1HQTp+jXz6fqtpNc BpUSORFU24Em
GkH7sec4OAWJUFQykM0aa5rU2rWb21zaDT77XZ7FY7i2LSJFDC4cKVdQCZba fBO/iRTxt2UA
bl74X0m/1Fb6eGfzhLHOViu5Y45JIypR3jVgjsCicsCcKo6AARnwjo/2dIEj u4UjdmiMF9PE
0KsADHGyuCkXyr+7UhPlX5eBWXH8RdMXR01O+sb7Tree0W8tTdmEfaY2aNQQ VkZU+aaIfvCg
G8EnAYqat8RtJ0GWCHV4J7G4eLz5oJ57dXt4tzKGI8395nYx2xeY3HIBKggG pdeF7F9LuNPs
Y47KC5uLeW4jRMpIkflKYtmQAjRRCIqOME5B5Bsal4e0zVrhZ7yCRnCCNwk8 kazICSElVWAl
TlvlcMPmbj5jnDuvG0rT2Y0zRr66RtVm06VSiI0rRpcFvKLyKpw0CksTt2sQ PnDKuxfa9/ZV
5IupWU8NhwU1CMebCowM+bj5osYYliPLCgEuCdoAK8PhKyXXr/VrmSe4kuru O5SEzyCGMpFG
i5i3eW7AxbwxXIO3HKg1JF4Q0OE5W0kIV42iV7iV1g2SLIqxKWIiQNHGdibV OxQQQoA3KKAM
e98L6Tf6it9PDP5wljnKxXcscckkZUo7xqwR2BROWBOFUdAAIz4R0f7OkCR3 cKRuzRGC+nia
FWABjjZXBSL5V/dqQnyr8vArcooAz7fRNOs7W7trS3+yw3ePMW3dosYiWIbC pGzCIgG3GNuR
zzVixsLPTLOOzsLSC0tY87IYIxGi5JJwo4GSSfxqxRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAZR/5DF9/wBcIP5yVRvehq9e2Nvd XTPKrbhgZV2U
kY74Iz36+p9aaui2JHKTf+BEn/xVWtBGCf8AkNr/ANdE/wDScVrVTvbaK01i 1jhUqu4k5YsS
djdSeTVykM36gtCphYqRjzZBx67znsO//wCs9TPUVsd0THOf3jjrn+I+5/z2 HQSBLRRRQAVB
elVsbguQFETE56Yx9D/I/Q1PUV0dtnMc4xGxznGOPXIx+Y+ooAlooooAKKKK AIJyomtQxGTK
QufXY3Tg9s+n17GeoLiRYmhZ3CKHJJLYGNrH1H9fp3DjdW65zPEMZzlxxjOf /QW/75PpQBla
z4Y0/XNSsNQuvMF1p6Si0ddpEMj7f3oVgQXXYCuQQDzgnGG2Hh2S11mPVLvW 9S1GeK3kt4lu
lgVUWRo2YjyokJOYk6k96xPHnj1fBepaPBOsa2mopcI9y0bSG3ddmxygILoC x3KCCR0ORg6G
manrA8RWFneajpWoWV9p893FNZWjw/ceAAhjNIGVhMTxjoOa3qU6ypwnP4Xe 33u/4iTV2bep
abDqduscjSRSRuJILiIgSQSAEB0JBGcEggggglWBUkGnZaCbbUYL+61W+1C6 gimhR7kQrhJT
ESMRxoODCuP95s54xY1bU/7NigSKHz7y7l+z2sBbYJJNrP8AM2DtUKjsTgnC nAZsKcOfxTqG
lazp9prenRwpdW9zLt0xLi/bMbQBT8kSkA+a+cqRwvzc4rAZHa/DjR7OKNIr m+3RRJHE5dCU
ZFtVRx8uCymyhYZBUndkEHA0I/CcH9i63pt1qN9ef2zv+1XM3lLJ80Kw/LsR VGERcfL165qm
fG1p/wAJB9nFxaPpq280hnhLys7AWbRBcDDFhdYCpv3ZTBySoIvGRfQ/Ferr aSNBozyGGGWG
S2kkVLWOYhxINyks7AHaOMHB6kA1NQ8N2d/LcSeZPA1x5byCFgAZo2RopsEE eYhRcHowADhg
qgFl4fS01GDUJtQvr28iimiMty6neJDET8qqqrjyUAChR94kFmJqvbeJHt5b +3122gsrizih
nb7LO1yjpKzpGFPlozSF42GwKc5QAktgU7nxjHPrOj2GmtIou3kM7S6dO8kf ltCDG8QCtCWE
6sJJPlUYJBDg0AWIfBttDaw2balqUlnbPAbS2aRAlskMqSIihUBcZiRd0hds A4YFmJuN4fT+
2JL+HUL63jnlSe4tIXVY55VVVVmO3zBwkYKq4UhMEEFt1dvG3h2OCS4m1DyL dNhE88MkUcis
6oJI3ZQske50y6kqA6kkAg1YHijSTeQ2pmnWSXYMvaSqkbOAUjkcrtjkO5cI 5VvnUYywyAU2
8Faa1hpVp592BpdkLO1kDruXa8LpIflwXVreNhxtPIKkHFSP4WMkqzNruqi4 aIQXU6NCj3cS
s7KrFYxs2+Y4DRbG+brkAgs/Gug31mbqK6nWExLNGZ7OaEzoxABiV0BlyXQD YG5dB1ZcySeL
tHhSF5pLuISJ5jeZYzqYE3Fd8wKZhTKthpNoIViDgEgA1L6ws9Ts5LO/tILu 1kxvhnjEiNgg
jKng4IB/CsOXwXYzzWkkl7qUgtH3QLNceaVHnQTbS7guw32yn5mJAdgCBtC7 l9f2emWcl5f3
cFpax43zTyCNFyQBljwMkgfjWO/jHTYvJ8621WNrjzDbx/2ZcPJKibA7+WqF 0UNIF+dVyeQC
CCQCPVPBllq4v4bi8u/seo3AnvbQLE0c+I4owpLRllAEKkFGVgSSCDtwXXg2 2urfULNtS1JN
PvUuAbKORFjjecN5jg7N7EmSRtrsygtkL8q7bC+MNAke6SLUo5jaojy+SjSA B1Ro8FQQxcSJ
sAyXOQuSrAZ8/jizj1nT4Y0u5bSe3uWmSPTrh7iKWNoNqtEqb0BWYn5lGQUI OCMgG4+kodcX
VormeGYxCGeNNpS4Rd5QNuUkbTI5G0rndzkAAY994Jg1GKCK51nVXji0qXSm DPExmjlUK7uz
RljIdiNnIGUHGCwOgPFOjNeQ20d55vm7As8UTvAC4BRWmUGNWYMm1SwJ3pgH cuad34luZtSs
7HQbO0vnnS7Z3urp7ZUNvKkTqMROSd7kdAPlJycigCxqvhmLU7i8nXULu1e8 t4rW4ESQyLJE
hlOwrLG4IPnNnjnA6c5jsvCNnpk8Q068vrOxTyi9jDKPLlaJEjQsxUycLHGC A4VgnzA7m3R6
d470DUrI3MV1IpS3huJYWhYvEJUjeNSFBBdhKgVQSXO4LuKsBXn8cWces6fD Gl3LaT29y0yR
6dcPcRSxtBtVolTegKzE/MoyChBwRkA0LbwvbWVvokVpd3cL6RbraQyqULSw AJujfcpGG8qM
kqFb5eCuTmnY+E5V07w99r1GeK+02Vr24+ybDHc3UgbzmO9CdrGWbhduBIcA YXboDxTozXkN
tHeeb5uwLPFE7wAuAUVplBjVmDJtUsCd6YB3LnHHinWLnXJNP0zTLG6jkluv s0s929uDHb+R
HJnEchLefJKvRRiPPIIJANCPwnBbWelwWWo31pJpmnnT7eePymcRkwkkh0ZS 37hRnGPmbjOC
K9p4FsNNghh0y9vtPjEXk3AtGjT7Sm95MH5P3fzSyn9z5eN5xgKu2TTvHega lZG5iupFKW8N
xLC0LF4hKkbxqQoILsJUCqCS53BdxVgK8/jizj1nT4Y0u5bSe3uWmSPTrh7i KWNoNqtEqb0B
WYn5lGQUIOCMgGg/he2+wR20F3d28sN7PfQXUZQyQyyvIzkBlKEYmkXDKeD6 gGrE2gWN3qg1
C+WS8kjdXt47ht0Vuy4wyR/dDg5PmEFxuIDbcARjxTozXkNtHeeb5uwLPFE7 wAuAUVplBjVm
DJtUsCd6YB3LmSHX7GTVDpc7SWl+XZYoLpfLNwFyd0R+7KNoDHYSVBG4KeKA NSiiigAooooA
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigClL/x8
P9R/IVMnQVDL/wAfD/UfyFTJ0FUIwNV/5Dtr9f8A2RqnqDVf+Q7a/X/2Rqno Gb9RWx3RMc5/
eOOuf4j7n/PYdBLUVsNsTDGP3jnpj+I+w/z3PUyBLRRRQAVFdHbZzHOMRsc5 xjj1yMfmPqKl
qK6G6zmGM5jYYxnPHpg5/I/Q0AS0UUUAFFFFAEUxxLbjOMyEdcZ+VvcZ/X6d xLUUwzLbnGcS
E9M4+VvY4/T69jLQBy/irwTZeK9S0u8vWjb+zUmMME0W+J5X2bWkXILIpTJT I3ZwSBkGxZaN
rH/CQwatq2qWNz9ntJraOK0sHg/1jxMWJaZ848oDAA6msXxZ4o17SdbnttLt mnggt7aRo7fS
nvZi0rXAzhZowqAQDnnlq1rO81618VWml6peabdwXVlcXCta2TwMjRPCuDum cEETHsOgracq
jpxUn7qvb77v8xK1zU1bTP7SigeKbyLy0l+0Ws5XeI5NrJ8y5G5SrupGQcMc FWwwp2ej6l/b
NpqmqajaXE9tb3Fuq2tm0ClZWhbJ3SOcgwnvzuHTHOhqWpQ6ZbrJIskskjiO C3iAMk8hBIRA
SBnAJJJAABZiFBIp/wDCR2tpp323XE/sGMy+Uo1O4gTecZGGSRl554zn5Txi sRnL2Pwy+wxW
4Gr75LaKIRMbbA8yNbEIzDfyu6wUlQQSJCAwI3HYHha8uNA8S2F/qcEl1rvm b54LQxpFut0g
GEMjE4EYP3uc9q1LnxLoNlcXNvd63psE9qge4jlukVoVJUAuCcqCXQAn+8PU VJ/buj/2x/ZH
9q2P9p/8+X2hPO+7u+5nd93np05oAw7zwFpr2F9p2nx2llpt48dxJYi0VoDc RvGyPsBA2MI1
V06MAMFDuLSaD4PTRdRtr1HsY2jiuY3gsNPW1hJlMHKqCSMC3GdxYkseQAFG xDruj3EtzFDq
tjJJayrBcIlwhMUjNsVGAPysW+UA8k8daz4fG/huWe/ibWbGH7D5bSPNdRqr RukbrKp3cxnz
kUNwC3HpkAw9N+GltpkUUMEmmwpbvbCGW20tIp5Ehnil/fybiZHPkqNy7Blm YqflC6Fx4Htp
/Fj62F01jNcRXMjz6akt0rxqiqIpmOETEa8bCQS5DKSCu5Druj3EVzLDqtjJ HaxLPcOlwhEU
bLvV2IPyqV+YE8Ec9KrzeLPDdvZ215N4g0qO1ut32eZ72MJLtOG2sThsHg46 UAY7+Bd2maDa
jUcSaNp6WsUhgyJJEktpEdl3fd3Wq5UHJDEBgRmo9V8CNrd7Hf6lLo11ePbr bXEs2jrKFRXd
lMCySMInxI2S3mAlVO3AIPQWXiHTb7W9R0aK5jGoWDgS27Ou8qUjfeq5zs/e KuSByCPrh3Xx
H0ez0fWNRktr4/2XdyWr2wRPOn2MytJEu75o/wB3Kd3HEMn9w0AdJqWl2mrW 6w3aSEI4eN4p
XikjbBGUdCGU4JBIIyGI6EiubudD8Sp4h0y4tNXgmW3tLuJr2/s1kbEj2zKj JE8QLExuQygA
KoBBPzHoH13R47y6s5NVsUurSIz3MLXCB4YwAS7rnKrgg5PHIqv/AMJZ4b/s 7+0f+Eg0r7D5
vkfaftsfl+Zjds3ZxuxzjrigDLsvA8OnaDc6Va30mxri0uLaSWMMY2to7dYw 4BG8FrZS2NuQ
xAx1qNfCesW+sDWrbWrFdTl8/wC1NLpzvC/mLboNiCYMmFtY+rtkljxwBsXH inRLT95d6pY2
9q0UMsd1NdxLHKJd+zaS2eRGxBxgjoThsSXniXQdPt7W4vdb022gu0320k10 iLMuAcoScMMM
Dkeo9aAObsfhrYabqdpPbfYZIYPsx82706Oa8BgjjjQJOeEUiJMjYTkuVKkg rqXfhC21fUrO
7177JqyWqXaJDdWaMuJpUdMA5AMaRhM4y2SeOQekrDPivTZrdJNLMmrSSuyw RWO1vP2gF2R2
KoUXcAX3bQ3yZ3kKQCO58MfaItXAvNsl9qEGoRMYsiKSFYAgYZ+dd1upIBUk MQCD81Z6+E9Y
t9YGtW2tWK6nL5/2ppdOd4X8xbdBsQTBkwtrH1dskseOANQ+L9Bt7dJNR1O0 0uQu0bW+oTpD
JHIoBZCC2CQGU5BIIZWBKspOhJq2mw6pDpcuoWiahMm+K0aZRK688qmckfK3 IHY+lAHJ2Pw1
sNN1O0ntvsMkMH2Y+bd6dHNeAwRxxoEnPCKREmRsJyXKlSQVk07wRbX9ro11 4hsbS4nit7qW
5sbmBJkS5upUmkKk5ACMHUdThvvHGT0E3iXQbayF7PremxWhdUE73SKhZkEi jcTjJQhgO4IP
SpP7d0f+2P7I/tWx/tP/AJ8vtCed93d9zO77vPTpzQBn3Phj7RFq4F5tkvtQ g1CJjFkRSQrA
EDDPzrut1JAKkhiAQfmrPXwnrFvrA1q21qxXU5fP+1NLpzvC/mLboNiCYMmF tY+rtkljxwBc
uPG+iw68dMS+tJzFbzS3JgnEjwOkkUaxGNcsXZpcBepK4AJPFyHX1js7m81i wn0O1g25m1Ke
3VG3HH3klYDnA+bH3hjNAHP2Pw1sNN1O0ntvsMkMH2Y+bd6dHNeAwRxxoEnP CKREmRsJyXKl
SQV6D+wftOo/bNTvZ7zy5fMt7XPl28ODlf3Y/wBYwwh3SFsOu5AnQSSeJdBh eFJdb01Hmt/t
UStdIC8O0t5i88ptVjuHGAT2ofxLoMdxaW763pqz3qI9rG10gadXOEKDOWDH gEZz2oA1KKz3
13R47y6s5NVsUurSIz3MLXCB4YwAS7rnKrgg5PHIqm3i/QY9Zn0ubU7SGeK3 +0bpJ0VXUNKs
gXLZJjMD7+Pl798AG5RWfY67o+pyxxWGq2N3JJEZ0SC4SQtGGKFwAeVDArnp kY61X/4Szw3/
AGd/aP8AwkGlfYfN8j7T9tj8vzMbtm7ON2OcdcUAbFFY8PijR59cj0iO+gN1 NaRXlt+9TFzG
/mYMXOXwIiTgYAKnPPFzTdVsdXt2nsLmOdEcxyBeGicAEo6nlHGRlWAI7gUA XKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAKUv/Hw/wBR /IVMnQVDL/x8
P9R/IVMnQVQjA1X/AJDtr9f/AGRqnqDVf+Q7a/X/ANkap6Bm/UVsNsTDGP3j npj+I+w/z3PU
y1BaBRCwUDHmyHj13nPc9/8A9Q6CQJ6KKKACorobrOYYzmNhjGc8emDn8j9D UtZurX8Nva3U
cqFo0t2kncsqpFGQfmYsy8fK3Q8YPTigDSoqvbXYuHkjaGSGVAGMcm0nac4O VJHY988fSquv
a7ZeG9Gm1XUWdbSFo1kZF3FQ7qm7HUgFgTjnAOATxVRhKclGKu2BpUVzk3i0 wNDI2hak2nz3
EMEWoRy2rwuJZFjjkG2YuUYupztzg9K355ltreWdxIUjQuwjjZ2IAzwqglj7 AEntU7ALJFHM
u2SNXHPDDPUEH9CR+NNNrbtnMERznOUHOc5/9Cb/AL6PrVDRfEGn6+kz6f8A aykLlHaeymgG
4MykDzEXcQysCBnBGDitSgDjdd8MXF94qm1T/hH9A1iCSygt1XU5ijQsjzMx X9zIMMJF7j7t
GheGLix8VQ6p/wAI/oGjwR2U9uy6ZMXaZneFlLfuYxhRG3c/erorvW9OsdY0 7Sbm42X2peb9
ki2MfM8tdz8gYGAc8kZ7VYs7631CBprWTzI1lkhJ2kYeN2jcc+jKw98ccVft J8vJd27BYp61
ps18LK5tGjF5p9x9qt0lJEcjeW8ZRyASAVkcBhnacHDAFTlzWviSXUbLWf7P 0oX1tFPa/ZP7
Qk8to5TC2/zfIyGBhxt2YIbO4Ywdy91KGxutOt5VkL39wbeIqBgMIpJctz02 xsOM8kfUXKgD
h9C8EXmiHTIvtUE0NjqEVxvwVZ400wWn3cHDFxuxkjb3zxWX4a8L69bWkuhX FvaR2dve6bLJ
emZ9ztbW9mT5cZjAdC0G3dvGMtwSuD2mjeKNJ1/Z/Z8058yITxefaSwedGcf PH5irvUblyVy
BuXP3hmxq2rJpUUH+jT3Vxcy+Tb20G3fK+1nIBdlUYRHb5mH3cDJIBAODn8A azqWoQtqbWl1
EiJHcy3GoT3AvMXdtM7eQ6eXAGWB/wB2hK5dV6DNdBf+HdSmvdRSA2jWl7qd lqRleVldGhe2
DR7ApBBS3JDbhywXbgbq6yigDz/UPAd/ewxIbiAeVLfTgJNJGXMuoQ3cah1G 5MrEVLjlScgN
itDw/wCFbrTNch1OVIIt0V0J4xez3b75PsoUmWb5n+W2OThcZVQDgsewooA5 PwT4d1LwvaCx
uDaTQPb27STRytuSaO3hgKBSuGQiHdv3A/Njbxmqd34C+1aDqkTGD+07iLVI oHz+7/0mWV42
c7d25FlZQR90SygZ3HPcVGJ4WuHt1ljM6IrvGGG5VYkKSOoBKsAe+0+lAHmf jTwlr99b6ldf
8fixRX8qOt/OzyrJazxxxJaBfKVl81F3KdzbCTy5FaGp6Z4kbxLpWu/2dYtf NdxQ/ZYruRoU
jjt739483k5XJuNuNhGQvPzcegUUAcHpngrUrPxLZ6rLPaFFuPtU0aOxKsx1 BmRTtG4Br1AG
OMhGOF4FY+v6HrOjadrdpZ2keoXHiG3u7RUQT4h33FzJGd6xMgJF2AfMMago fmIyV9UooAy9
f0K28RaW1hdvIkZcPlVRxkf3kkVkcezqwBwRhlUjPk03XvtFtqjNptzqlmk1 uigvbwXEMpjZ
ieJGicNGuOZAQp6b/wB3sR6lDLrNzparJ59vbw3DsQNpWRpFUDnOcxNnjuOv avN4h0y31Qad
JPIJ96xs4gkMUbtjajyhdiOdy4VmBO9MD5lyAcu2la9p3jG01O0sbS7vL23v JbwSXDw28DN9
jRUWQROSdsA6gbiHbCj5RX0z4d3Gl3VpB5kd5aRvZStO99cwhWt4oUH+iofL kJMCsGZuCwyG
CAN6JRQBw8XhLU9P8JeH9JsvIK2FoIrq1gv5rBJZtq5lE0K7zhhJ8pADebuP Kio9F8Falpvh
UaXNPaNOL3S7jcjsV22yWayDlc5Jtnxx3XOMnHeUUAef2/gvWJF0iyunsYbX RdPFraXUUzyv
NJHLbSRPJEUUKubUFlDk/MQG/irYu7XxJqLWV3Np+lQXWm3YubeFNQkdJ90U sTKzmAGPAl3A
hXzjHGc1oQ+JLOf7FtjnH2zULjT48qOJIfO3E8/dPkPg9eV4HOJNN8Q6Zq1w 0FnPIzhDIheC
SNZkBALxMygSpyvzIWHzLz8wyAcvb+CtSia6kee033VxZXTKHYhGj1Ga8lQH byAs21WwNxXJ
C5rP/wCEX17+0PEmkRW9obTVrJ4pb2SZ1EKzXd8/yL5ZEjqk6llLJzgZw2a9 MooA838S+B9f
1y5uR58Eiv8AbNlzNqU4G2W2nijT7KEMSbPNRS6ncQhY8uRWxrvha8uItXtt IisY7XUtE/so
I7mIWuxZ/LKqqMGUmYAj5doXI3ZwOwqnq2pQ6No19qlwsjQWVvJcSLGAWKop YgZIGcD1FAHJ
674IvNbOpxfaoIYb7UJbjfgsyRvphtPu4GWDndjIG3vnijTPCF9DrVjqk0UF vJDdq8qnVLm+
do1guYxiSYD+K44QKAMMdzEgDtI54ZnmSKWN3hfZKqsCUbaGw3odrKcHsQe9 SUAcnoHh3UtD
1y5uybSaC+eYT/vWVoV+1XU8ZUbSHJFyFYErt25BbNXLHQLiTXI9e1aeA6gk Rhjis4giRxnJ
2NIR5kuCzdSqH5W8tWANdBRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAUpf+Ph/qP5Cpk6CsbU7vTrC+v77VTELa3t4jvlGQmS+cD1 O1RxyeBTZtV8
OQNZrJ9gU3rbbb5VIlOMjae46c9MkDqRlgR6r/yHbX6/+yNU9Zcqxx6+UhUJ EJ8qq8AZh3HA
+pJ/GtSmBv1FbHdExzn94465/iPuf89h0FCbxBp8OqDTv9LluN6o32eymmSN mwQHkRCiHBU4
YjAYE4BBqxqepQ6VapcTrIyPcQW4CAE7pZViU8kcbnBPtnr0qQLlFFU5NUtI ri7ty8jT2lut
zNHHE7sI2LhSAoJYkxuNq5PHTkZALlcl410GbW9N1C1HnrFdWnlebDcmLyiB IMuA6b1xJnaS
VOOR0rraKAMHQtJktUmEyXUUZVUQTXjyynBcklyzEj5+MscY7YFVPiDoF54i 8C6ho2mhWubp
4Qplkwq/vkZiSewAJwOwwB0FULjVbbTNOsZ7661EvdbY0WA3Ezu5QuQFjyei semOKvWc0F/a
pc213dvE+cE3EqkEHBUgnKsCCCCAQQQQCK1pVJUqkakd00/uE1dWMDT/AA/e 6J4asPCthoms
TR2+p2s0moXM9v5TCO6jlkdV84siEIxChc88jcST6TXOeSf+fi7/APAqT/4q jyT/AM/F3/4F
Sf8AxVKpOVSbnN3bGlbQyptBvf7Bt4LnS/t8EWt3t3dabujb7VBJLcmMYdhG 2DLDJhiMbM/e
AFcu3h26l1TU9O/4R/ztTbSk/s65/cf8SbzLm9aD5i25PLVox+53bfK+XOFz 21pNBfQtNbXd
28ayyQk/aJR86OUYcnsykfhUEd1FHBpy3N7dia8xHH/pEvzv5bSEcHA+VGPO Bx9KiwFnxJ4e
uNc1qzeNvJji0+5RLrAbyLnzrWSB9mRuw0JbHQ7MHg4PHxeGdeu9KuZNQ8O4 1K+iuDY/v4Zf
7GupLq5l87eWBXiaA74gzfuuQCqg9jHtkeVFnvgYm2NunmUE4B4JOGGCORkZ yOoIDLSaC+ha
a2u7t41lkhJ+0Sj50cow5PZlI/CiwHM6r4T1a6vitno/k6z9r1CX/hIt8S/u 5YblYF8wN5/y
ebAuNmF8vjIVSeg8C6A+ifb2WzvrK3m8sLb3f2SP5l3bnEVqojGQyjcSWbaA QAi5r3Wq22k6
HFqOpXWoiHyw0kkRuJdvy7izBMlVABySABV6zljvrVLmGbUVjfOBO88L8HHK Phh07j3osBg6
X4R8RWPhm0tjeTy37eH2063eSWOM6TO0Q3YaJRvjLRxjd8zqY1I3B2K19M8C Brmxjn0Sf+yR
qCzT2WpJYhAFtrlfM8i3UR8tJEN2Wc7RkAICet8k/wDPxd/+BUn/AMVUF0rx xKyXN2CZEX/j
5k6FwD/F6GiwHI6n4I1e4n8QyJbX01/dRagFufMtEhnjlSUQw7wv2h9oeIbJ GVFMeQcIgOh4
m8ETXOrQiytr57RLRYrM2sltm1uPMkaSZ5LhXkjZi8bGWLdIShY5YJnQ1PXL DSLqC2u59X82
f/VCCK7mDnDHaCgI3YVjjOcDOMVa1O6i0nSbzUp5r5obSB55FjuZCxVFLEDL AZwPWiwGLc+C
9RXTnl0i0g0/W7vUNUM9/EyxSGGYXfkl5E+Zl3vbtjkgqpxleI9Y8KrqNvY/ Y/Cd3pumQvP5
2l2sGmlpJmEWycxyF4SAqSLuyJBkADaTW9d3UVnc2EEk18WvZzBGVuZMBhG8 mT83TEbevJFW
/JP/AD8Xf/gVJ/8AFUWAtjSrx/CUOlG/ngvFtEha6MxmfcFAJaTCM2cEFhsY 5JBRsEc3P4fu
4tNt7GXw5aXNrb3oub2C0kR11ZTFJHudZiMy+Z5UjCVm+6pEkjCpLrVbbSdD i1HUrrURD5Ya
SSI3Eu35dxZgmSqgA5JAAq9Zyx31qlzDNqKxvnAneeF+DjlHww6dx70WA4lv Dt1Lqmp6d/wj
/nam2lJ/Z1z+4/4k3mXN60HzFtyeWrRj9zu2+V8ucLmxqfgjV7ifxDIltfTX 91FqAW58y0SG
eOVJRDDvC/aH2h4hskZUUx5BwiA9r5J/5+Lv/wACpP8A4qjyT/z8Xf8A4FSf /FUWA5rxx4Vv
7izS20bTJ5FtbSQ6bLaC1M0V2xYtJLLc/OuW8tg8TeYW8xmOdpoufBeorpzy 6RaQafrd3qGq
Ge/iZYpDDMLvyS8ifMy73t2xyQVU4yvHQzbYUDvPfEFlT5J5nOWIA4BJxk8n oBknABNUbbVr
O8n0+O2ur6RdQs3vYJRcSBTGpj65YEE+apAx65xRYCppmgLFqmpXFt4K/s2x m/swJab7eDdJ
FcyO837l2HyBo2weW2bauXekan/YmreFY7CSSDU3vCupiSMRQpcvI7b0Lb96 eYwCqpDYTLJu
bZavJoLC1e5ubu7SJMZIuJWJJOAoAOWYkgAAEkkAAk1Hp93DqUDTQS6oiq2w i5+0wNnAP3ZN
pI564x+VFgOVs9BvdUg1BtC0v+y9SOoawJNb3RxfaAz3UaJvjYynbI0TfMoA 8nIOVXNjTPAr
m5sUfS76HSxqCy3FrdvaRDattcozeVaBYyrGSJGyWZx8rKEX5uitLqK8ub+C Oa+DWU4gkLXM
mCxjSTI+bpiRfTkGrfkn/n4u/wDwKk/+KosBxXijwr4g1LVdTuLXTJ/td3Fe wSzwCzit54Gt
ZkgQvxcM24wbg5KB1JHyqhGxqfhI2usONP0CCXw6v2aWfSbZYUju3C3Sv+6Y rGWBe1cl8ZES
4JKAVu+Sf+fi7/8AAqT/AOKo8k/8/F3/AOBUn/xVFgOS0vw3LqEd1oDWv9j7 NK1SNoWVG8iO
/u3MG1Y2KnakDZUMAMqATzi546j1PWvCWoyXmlyaaml2V5cO7zRyrcObSaIL FtOdn7xm3OEP
CjZ8x2bVmry2UEj3N2XeNWY/aZOSR/vVP5J/5+Lv/wACpP8A4qiwHJah4Su7 6KU2GgT6Roxl
tzNo0C2e+cotwHcREvbtlpL
Re: Mapping model question [message #102099 is a reply to message #101882] |
Wed, 07 February 2007 10:46  |
I just noticed a interesting thing. If there is a EClass with a
EReference to another EClass defined, you can drag and drop any node
that has the corresponding type into the compartment of the node, while
you have to explicitely define a Child Reference if you want to create
the node directly inside the compartment. Wouldn´t it make sense then to
provide the opportunity to create all nodes with a EType matching the
EMF model definition inside of a compartment and handle the restrictions
on node creation by definition of suitable constraints?
> Thanks in advance
> Greetings,
> Christian
FUDForum. Page generated in 0.02600 seconds
