Home » Newcomers » Newcomers » global search
global search [message #101853] Thu, 15 September 2005 00:40 Go to next message
Originally posted by: kevin.cs.washington.edu
How do I make a search across all open documents?
-Kevin Chiu
Re: global search [message #101910 is a reply to message #101853] Thu, 15 September 2005 07:18 Go to previous messageGo to next message
Kevin Chiu wrote:
> Hello,
> -Kevin Chiu
Re: global search [message #101928 is a reply to message #101910] Thu, 15 September 2005 07:20 Go to previous messageGo to next message
Sorry for previous post, unexpected press on Send button... :-(
What kind of search do you want to do: File/Java/Plug-in?
What do you mean by "open documents": those you're currently editing
or those which are in your workspace?
Frederic Fusier wrote:
> Kevin Chiu wrote:
>> Hello,
>> -Kevin Chiu
Re: global search [message #101966 is a reply to message #101928] Thu, 15 September 2005 06:12 Go to previous messageGo to next message
>> Kevin Chiu wrote:
>>> Hello,
>>> -Kevin Chiu
Let's say I have 2 documents open in my workspace that I am currently
editing.
I want to find all instances of the word "keyword" in both documents.
How do I do that?
Re: global search [message #102025 is a reply to message #101966] Thu, 15 September 2005 09:27 Go to previous messageGo to next message
>>> Kevin Chiu wrote:
>>>> Hello,
>>>> -Kevin Chiu
> editing.
> How do I do that?
This is currently not possible. You can either search all files (Ctrl+H)
or the inside the editor (Ctrl+F).
Dani
Re: global search [message #102475 is a reply to message #102025] Fri, 16 September 2005 10:29 Go to previous message
Originally posted by: eclipse3.rizzoweb.com
Daniel Megert wrote:
>> editing.
>> How do I do that?
One more possibility - if the files are in a Working Set you can limit
the scope of the search to just that Working Set. I use this feature a
lot to keep my search results at a reasonable length ;-)
HTH,
Eric
Previous Topic:How do I get rid of this dialog?
Next Topic:Eclipse Plugin Development
Current Time: Fri Apr 25 23:50:41 EDT 2025
Powered by FUDForum. Page generated in 0.04663 seconds
