Re: [ATL]Newbie question: programmatically executing ATL from a Java application [message #101896 is a reply to message #101829] |
Mon, 16 March 2009 10:46 |
Tristan Faure Messages: 460 Registered: July 2009 |
first put [ATL] in your subject there is other M2M technologies
second : if you use ATL 3.O you can do File > New > Example > ATL and
you will have an example
if you use an older version you should check code in Topcased
(http://www.topcased.org/) there is atl transformations performed in Java
regards
Tristan FAURE
Derek Palma a écrit :
> I am trying to find Java code examples where .atl files are
> promatically executed. I looked at the web site
> (http://www.eclipse.org/m2m/atl) and did not run into anything like
> this. I see that the tutorials/docs talk about using launch
> configurations in eclipse or ant tasks. Basically, I want to execute
> transforms from my Java application. Is ATL intended to be used this way?
> Thanks in advance!
> Derek
FUDForum. Page generated in 0.03471 seconds
