Home » Archived » M2M (model-to-model transformation) » [ATL] Run an ATL query
[ATL] Run an ATL query [message #101815] Sat, 14 March 2009 12:34 Go to next message
My question is about the current available way to run an ATL query:
Is it simply with a Run configuration (if so, I tried it and it does not
generate any output text file, not even errors) or with an AM3 ANT script
just like this example
http://wiki.eclipse.org/index.php/AM3_Ant_Tasks#Examples_2 ?
PS: I am using eclipse 3.4.1 and ATL 2.0.2.
Thank you in advance.
Hayfa.
Re: [ATL] Run an ATL query [message #101845 is a reply to message #101815] Sun, 15 March 2009 14:58 Go to previous messageGo to next message
> Is it simply with a Run configuration or with an AM3 ANT
> script
yes, you can launch an ATL query by using a Run configuration or an AM3
task. In both case you should:
1. print the result in the console
or
2. save the result into a file
You can print the query result using the keyword debug, like that:
query test = 1.debug('result');
You can save the result into a file as follows:
** Run configuration
query test = 1.writeTo('result.txt');
** AM3 task
<am3.query body="1" property="result">
<inModel />
</am3.query>
<echo message="${result}" file="result.txt"/>
Kelly Garces - Phd. student
AtlanMod & AsCoLa research teams
École des Mines de Nantes
4, rue Alfred Kastler
44307 Nantes Cedex 3 - France
Re: [ATL] Run an ATL query [message #102002 is a reply to message #101845] Mon, 16 March 2009 12:10 Go to previous message
Hi Kelly,
Thank you for your answer.
Actually, I have a problem with running an ATL query using a Run
configuration. It does not generate anything, not even in the console.
Normally , I can execute an m2m atl transformation without problem.
In fact, I am trying to execute an already existing example
(XML2ExcelText.atl) to generate an xml file.
Thank you.
Hayfa.
Previous Topic:[XMI] XMI parser
Next Topic:[ATL] Can not copy type of parameter
Current Time: Tue Oct 14 13:06:00 EDT 2025
Powered by FUDForum. Page generated in 0.06361 seconds
