Home » Archived » BIRT » Disabling chart wizard preview
Disabling chart wizard preview [message #101646] Thu, 22 December 2005 15:00 Go to next message
Mark Evertz is currently offline Mark EvertzFriend
Hello developers,
a Chart-Wizard related question:
I'm using scripted data sources to retrieve data from external systems.
Using the new chart wizards leads to error messages about invalid java
script statements in data sets fetch clause (the same scripts worked
correct in earlier versions this way). Because my external Java classes
are some kind of "mock objects", they never return real data (actually I'm
not using the report editors preview function at all). Changes to external
classes make it necessary to copy them in the birt viewer lib folder and
restart eclipse all the time, which isn't very comfortable.
In my case it would be of great help if the chart wizards preview (not the
"main" preview of course)could be disabled (maybe a birt property in
eclipse birt prefs?) or to "hide" these error messages.
Re: Disabling chart wizard preview [message #101862 is a reply to message #101646] Thu, 22 December 2005 22:48 Go to previous messageGo to next message
David Michonneau is currently offline David MichonneauFriend
Please file a bug in bugzilla. I am not sure this can make it to 2.0 though,
we are very close to the release.
David
"mark" <m@rk-evertz.de> wrote in message
news:3765248b15fab7e9a1fe6760637d5ed8$1@www.eclipse.org...
> Hello developers,
> restart eclipse all the time, which isn't very comfortable. In my case it
> would be of great help if the chart wizards preview (not the "main"
> preview of course)could be disabled (maybe a birt property in eclipse birt
Re: Disabling chart wizard preview [message #102019 is a reply to message #101862] Fri, 23 December 2005 08:42 Go to previous message
Ok, I will do!
Just one more note>
The same effect appears if I try to add a chart to the
ScriptedDataSourceExample.
The example without the chart works fine (the 'normal' preview, too).
Previous Topic:getting problem to open the BIRT report from servlet
Next Topic:BIRT & Oracle AS
Current Time: Tue Jan 14 14:41:34 GMT 2025
Powered by FUDForum. Page generated in 0.02735 seconds
