Home » Eclipse Projects » Eclipse Platform » CVS versions and branches won't show
CVS versions and branches won't show [message #101017] Sun, 27 July 2003 21:42 Go to next message
Jimisola Laursen is currently offline Jimisola LaursenFriend
Hi!
We (our development group of three) are having problems with CVS under Eclipse -
it does not show our versions and branches.
Actually, it shows in Eclipse for the person who created the version and
bransch, but nothing shows for the rest of us.
Our CVS repository is on a Linux machine and we use Eclipse
2.1/2.1.1/3.0M1/3.0M2 under Linux and Win.
I've tried "Refresh Branches" without any luck. Any suggestions?
Jimisola
Re: CVS versions and branches won't show [message #101041 is a reply to message #101017] Mon, 28 July 2003 00:48 Go to previous messageGo to next message
Originally posted by: mxlehma.NO-SPAM.qwest.com
You have to do "Configure Branches and Versions" and select files from
which eclipse can derive the branch tags.
Jimisola Laursen wrote:
> Hi!
> Jimisola
Michael Lehmann
mxlehma@NO-SPAM.qwest.com
Re: CVS versions and branches won't show [message #101329 is a reply to message #101041] Mon, 28 July 2003 08:46 Go to previous messageGo to next message
And where do I do this?
I started following the instructions in the help. The "Configure Branches and
Versions" should be available from a pop-up menu.
However, I can seem to find it. Would appreciate if you pinpointed be, I've been
checking pretty much every menu I known of.
Kind regards,
Jimisola
"Michael Lehmann" <mxlehma@NO-SPAM.qwest.com> wrote in message
news:bg1rs6$199$1@eclipse.org...
Re: CVS versions and branches won't show [message #101345 is a reply to message #101329] Mon, 28 July 2003 08:50 Go to previous message
I resolved it. The Eclipse Platform Help says that one should expand the HEAD
and select the root folder whose tags are to be discovered.
The context menu does not show if you do this, you have to select folder under
the Versions tree.
Thanks.
Jimisola
"Jimisola Laursen" <public@jimisola.com> wrote in message
news:bg2nsv$osb$1@eclipse.org...
been
> Kind regards,
> Jimisola
Previous Topic:mark editor as dirty
Next Topic:BufferedDocumentScanner should not be in JDT
Current Time: Sat Nov 09 03:17:19 GMT 2024
Powered by FUDForum. Page generated in 0.03691 seconds
