Home » Eclipse Projects » Subversive » How to retrieve log infos.
How to retrieve log infos. [message #9179] Tue, 09 October 2007 05:39 Go to next message
Originally posted by: firstname.name.gmail.com
I would like to fetch history information of a sub-versioned resource. Its
intended to be used for a plugin, so I don't want get related views: only log
information.
I looked at the org.tigris.subversion.subclipse.ui.history, and how the
FetchAllLogEntriesJob deals with it.
I am wondering what is the simplest way to make a call of such methods. Is there
any "simple" api to retrieve the logs information.
entries = getLogEntries(myURIResource);
thanks in advance.
F. Lagarde
Re: How to retrieve log infos. [message #9199 is a reply to message #9179] Tue, 09 October 2007 07:56 Go to previous messageGo to next message
In the last post, on 10/09 about 11h, "François" (François Lagarde) wrote:
François> [...]Is there any "simple" api to retrieve the logs
François> information.
I was a little bit lazy. I think that I have a piece of a solution with:
org.tigris.subversion.svnclientadapter.samples
Btw: the way of the subversion plugins are packaged is confusing. Why
org.tigris.subversion.svnclientadapter is not a plugin?
F. Lagarde
Re: How to retrieve log infos. [message #9219 is a reply to message #9199] Wed, 10 October 2007 08:18 Go to previous messageGo to next message
In the last post, on 10/09 about 01h, "François" (François Lagarde) wrote:
François> I was a little bit lazy. I think that I have a piece of a
François> solution with:
hello,
I am still lost. I read again source of the plugins. I think that I was
wrong, and think that the better is to use SVNClientManager. So far, I have:
SVNProviderPlugin plugin = SVNProviderPlugin.getPlugin();
SVNClientManager svnClientManager = plugin.getSVNClientManager();
ISVNClientAdapter svnClient = svnClientManager.createSVNClient();
but, eclipse rises as error that the method createSVNClient doesn't exist. This
is odd, because both sources/classes of the subversion plugin have this method.
any idea...
F. Lagarde
Re: How to retrieve log infos. [message #9735 is a reply to message #9219] Fri, 12 October 2007 09:57 Go to previous message
François,
This newsgroup is associated with the Subversive Eclipse SVN client.
From a previous post, it looks like you are using the Subclipse Eclipse
SVN client. You should probably try and find the appropriate forum/list
to post your question on the Tigris site since they provide and support
Subclipse.
Michael
> hello,
> any idea...
Previous Topic:Are Subclipse still involved?
Next Topic:How do I obtain working copy information?
Current Time: Thu Nov 06 14:52:53 EST 2025
Powered by FUDForum. Page generated in 0.05334 seconds
