[QVTO] Blackboxing: how to set context? [message #100517] |
Mon, 23 February 2009 06:58  |
Hi all,
I try to add a blackbox operation to a qvto transformation as follows.
----------------------> blackbox library <----------------------
import mymodel.MyModel;
import mymodel.MymodelFactory;
public class BlackBox {
public static class Metainfo {
public static String[] ggg(String self) {
return new String[]{
"oclstdlib::String", "MyModel"
//// An exception is thrown if I enable the next 5 lines.
// public static String[] glub(MyModel self) {
// return new String[]{
// "mymodel::MyModel", "String"
public MyModel fff(String self) {
MyModel m = MymodelFactory.eINSTANCE.createMyModel();
m.setAnAttribute("blub");
return m;
public String glu(MyModel self) {
return self.getAnAttribute();
----------------------> qvto transformation <----------------------
modeltype mymodel uses mymodel('http://mymodel');
transformation blackboxtest();
import library BlackBox;
main() {
var x : MyModel := ''.fff();
log(x.anAttribute); -- works just fine and prints: blub
-- x.glu(); -- does not work
An exception is thrown as soon as I uncomment all lines in the library and start the runtime workbench. I debugged it and found out that the context of the ocl statement in QvtLibraryOperation produces the error. The statements looks like that:
"context mymodel::MyModel def: glu():String=let r:String=null in r"
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.RangeCheck(ArrayList.java:546)
at java.util.ArrayList.get(ArrayList.java:321)
at org.eclipse.m2m.internal.qvt.oml.ast.env.QvtLibraryOperation .parseConstraintUnvalidated(QvtLibraryOperation.java:125)
at org.eclipse.m2m.internal.qvt.oml.ast.env.QvtLibraryOperation . <init>(QvtLibraryOperation.java:58)
Does anyone have a hint on how to correctly set the context for an operation in the blackbox library?
Patrick
Re: [QVTO] Blackboxing: how to set context? [message #100536 is a reply to message #100517] |
Mon, 23 February 2009 07:47  |
Nevermind.. I figured it out.
I was missing the inMetamodel/outMetamodel in the plugin.xml:
<library class="mymodel.test.BlackBox" id="BlackBox">
<inMetamodel uri="http://mymodel"/>
<outMetamodel uri="http://mymodel"/>
</library>
Have a nice day everyone!
On 23-02-2009 12:58, Patrick Könemann wrote:
> Hi all,
> return m;
> main() {
> at
> at
> Patrick
FUDForum. Page generated in 0.05399 seconds
