Home » Newcomers » Newcomers » selection does not contain main type?
selection does not contain main type? [message #100501] Thu, 08 September 2005 20:12 Go to next message
Originally posted by: wizumwalt.gmail.com
If I right-click on the main class in the 'Packages Explorer' view, then
click 'Run'->'Java Application' ... I get a dialog saying launch failed.
"The selection does not contain a main type. Yet I have a main method
there and my program works fine.
Any ideas?
Re: selection does not contain main type? [message #100645 is a reply to message #100501] Fri, 09 September 2005 07:17 Go to previous message
Frederic Fusier is currently offline Frederic FusierFriend
Sounds like a problem. Please fill a bug report specifying build ID
you're using and a detailed test case with steps to reproduce.
> Any ideas?
Previous Topic:launch file in internal web browser from ant build?
Next Topic:Adding Javadoc with Format
Current Time: Thu Jan 02 16:59:19 GMT 2025
Powered by FUDForum. Page generated in 0.05131 seconds
