Removing Note attachment Connection Assistant Handle. [message #100428] |
Fri, 02 February 2007 04:53  |
Is it possible to remove Note attachment Connection Assistant Handle from
the Figure? And How I can only have incoming or Outgoing assistant Handle?
If the figure already have one connection it should not show the handle.
Sandip
Re: Removing Note attachment Connection Assistant Handle. [message #101511 is a reply to message #101376] |
Tue, 06 February 2007 10:11  |
Sandip,
You would need to install your own ConnectionHandleEditPolicy in your
editparts to override the one that gets installed there by default (that
is the
org.eclipse.gmf.runtime.diagram.ui.editpolicies.ConnectionHa ndleEditPolicy
installed in the GMF runtime code).
To learn about EditPolicies take a look at the section titled "Editing
and EditPolicies".
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. gef.doc.isv/guide/guide.html
Cherie
Sandip Sahoo wrote:
> Hi Cherie ,
> I am not getting code where I can make changes. I m using GMF2.0M2. I m not
> getting this ConnectionHandle class. I found no policy called
> ConnectionHandleEditPolicy there.Plz refer me what I can do.
> sandip
> "Cherie Revells" <crevells@ca.ibm.com> wrote in message
> news:epvnra$ng7$1@utils.eclipse.org...
>> Sandip,
>> The Modeling Assistant Service always collects the element types for the
>> connection handles from all providers so to change this behavior you
>> would need to avoid calling the Modeling Assistant Service to populate
>> the connection handle popups. You could do this by overriding
>> ConnectionHandle.createDragTracker() to provide another ConnectionTool
>> that does not use the Modeling Assistant Service and instead just uses
>> your own types. See ConnectionHandleTool.createTargetRequest().
>> In order to use your new ConnectionHandle, you would need to override
>> the ConnectionHandleEditPolicy installed on your editparts.
>> You can override ConnectionHandleEditPolicy.getHandleFigures() to change
>> the handle figures or return just one connection handle.
>> Regards,
>> Cherie
>> Sandip Sahoo wrote:
>>> Hi,
> from
> Handle?
>>> Regards,
>>> Sandip
FUDForum. Page generated in 0.05723 seconds
