Multiple Questions concerning compartments [message #100097] |
Thu, 01 February 2007 13:46 |
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
--------------030907000402000602070309
Content-Type: text/plain; charset=UTF-8; format=flowed
I am experimenting with compartments. I´ll use the editor to
conveniently create a special xml tree. As an example I have got 3
elements. First is the root, which acts as the diagram canvas. Then
there are 2 other elements named operator and operand. Both can be
created on the canvas. Additionally a operator can contain multiple
operands and an operand can contain one operator (meaning that an
operator acts as an operand for another operator). So theres resulting a
tree which can be as deep as desired. This example is the xml tree
corresponding to the attached screenshot:
<root>
<operator>
<operand/>
<operand>
<operator>
<operand>
<operator>
<operand/>
<operand/>
</operator>
</operand>
</operator>
</operand>
</operator>
<operand/>
</root>
What works is the creation of the desired xml tree. Operators or
operands created on the canvas can also be dragged inside the
compartment of a suitable node. So thats what works so far.
What I want to do is the following: To easy the design process the user
should not only be able to drag nodes from the canvas inside an
compartment but also the opposite direction (from compartment to the
canvas or inside another suitable comparment, see the arrows ). The
second thing is that I wasn´t able to make the nodes inside the
compartments movable (Like in the mindmap example). I found threads that
suggested altering the List Layout property to false, but that didn´t do
anything. Can anyone help me to achieve this two requirements? I´m
pretty sure it must be achievable within the GMF models.
Greetings,
Christian
Content-Type: image/jpeg;
name="compartment.JPG"
Content-Disposition: inline;
filename="compartment.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/4QAWRXhpZgAASUkqAAgAAAAAAAAAAAD/ 2wBDAAgGBgcG
BQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0aHBwgJC4nICIsIxwcKDcpLDAx NDQ0Hyc5PTgy
PC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjIyMjIy
MjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCAHaAdUDASIAAhEBAxEB/8QAHwAA AQUBAQEBAQEA
AAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQR BRIhMUEGE1Fh
ByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RF RkdISUpTVFVW
V1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ip qrKztLW2t7i5
usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEB
AQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEE BSExBhJBUQdh
cRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNE RUZHSElKU1RV
VldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaan qKmqsrO0tba3
uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMB AAIRAxEAPwD3
P+0IAxAEzbWKkrA7DIODyBjrS/b4f7lz/wCA0n/xNVGVZNMKMoZWvMEEZBH2 irf9mWH/AD5W
3/fpf8KAD7fD/cuf/AaT/wCJo+3w/wBy5/8AAaT/AOJo/syw/wCfK2/79L/h R/Zlh/z5W3/f
pf8ACgA+3w/3Ln/wGk/+Jo+3w/3Ln/wGk/8AiaP7MsP+fK2/79L/AIVDLaW0 F3ZPDbxRsZiC
UQA48t/SgCb7fD/cuf8AwGk/+Jo+3w/3Ln/wGk/+Jq3RQBU+3w/3Ln/wGk/+ Jo+3w/3Ln/wG
k/8Aiat0UAVPt8P9y5/8BpP/AImj7fD/AHLn/wABpP8A4mrdFAFT7fD/AHLn /wABpP8A4mj7
fD/cuf8AwGk/+Jq3RQBU+3w/3Ln/AMBpP/iaPt8P9y5/8BpP/iat0UAVPt8P 9y5/8BpP/iaP
t8P9y5/8BpP/AImrdFAFT7fD/cuf/AaT/wCJo+3w/wBy5/8AAaT/AOJq3RQB U+3w/wBy5/8A
AaT/AOJo+3w/3Ln/AMBpP/iat0UAVPt8P9y5/wDAaT/4mj7fD/cuf/AaT/4m rdFAFT7fD/cu
f/AaT/4mj7fD/cuf/AaT/wCJq3RQBU+3w/3Ln/wGk/8AiaPt8P8Acuf/AAGk /wDiat0UAVPt
8P8Acuf/AAGk/wDiaPt8P9y5/wDAaT/4mrdFAFT7fD/cuf8AwGk/+Jo+3w/3 Ln/wGk/+Jq3R
QBU+3w/3Ln/wGk/+Jo+3w/3Ln/wGk/8Aiat0UAVPt8P9y5/8BpP/AImj7fD/ AHLn/wABpP8A
4mrdFAFT7fD/AHLn/wABpP8A4mj7fD/cuf8AwGk/+Jq3RQBU+3w/3Ln/AMBp P/iaPt8P9y5/
8BpP/iat0UAVPt8P9y5/8BpP/iaPt8P9y5/8BpP/AImrdFAFT7fD/cuf/AaT /wCJo+3w/wBy
5/8AAaT/AOJq3RQBU+3w/wBy5/8AAaT/AOJo+3w/3Ln/AMBpP/iat0UAVFvo XlSMCUM5wu+F
1BOCepGOgNW6q3f/AB82P/Xc/wDot6tUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAZf/ADDv
+33/ANuK1Ky/+Yd/2+/+3FaLMsaF3YKqjJJOABQA+ioo5UlQMpyp6H19x7e9 S0AFVbv/AI+b
H/ruf/Rb1JFcRzoTG4bBwQOqn0I7H2NR3f8Ax82P/Xc/+i3oAtUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFAFW7/AOPmx/67n/0W9Wqq3f8Ax82P/Xc/+i3q1QAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQBl/wDMO/7ff/birVzbfaRGd21423IdoIz7g/zGD6EZqr/zDv8A t9/9uK1KAKw8
/wDd7imdx3kZ5GDgj0OccfXrTh52Uz5f323Yz9znGPf7ufxqeigClHayG5Fx Oy+bt2gRjAA9
Cerd/Qd8A0+7/wCPmx/67n/0W9Wqq3f/AB82P/Xc/wDot6ALVFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQBVu/8Aj5sf+u5/9FvVqqt3/wAfNj/13P8A6LerVABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFAGX/wAw7/t9/wDbirN28yqvlA7SfnZV3Mo9QP8A9f0Oarf8w7/t 9/8AbitSgCpF
LGIoQJGbzGKqzZyW5Jz6Hg8cYxjjpUguImKYb77tGvB5YZyP/HT+VT0UAZ1r JIZQImeW1xw8
gxj02t1YdOcHOc7j0qe7/wCPmx/67n/0W9Wqq3f/AB82P/Xc/wDot6ALVFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQBVu/8Aj5sf+u5/9FvVqqt3/wAfNj/13P8A6LerVABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFAGX/wAw7/t9/wDbirctwsAAYMzt91UXJP8AgOnJ4GRk 1RkZl0p2RN7i
7JVc43Hz+BntVa71KcERXWmwKfvKJLxFI9x3B68igDbjZ2QMy7Cf4c5x9ff/ ADzUtc0usTBY
h5ERCMSM6hHyMEYPqOf0FKNamG39xGdsjPzqEfOc8H2GeB7CgDWiv43u2s5C EulVXMW7Pytk
A59CVfGcE7TxxUl3/wAfNj/13P8A6LeuOstUeHxjqU32eJ5Dp9qpL3yE/wCs n6Hpz1wMAY6c
1tHWWmuLcywQokTlyVvImJ+VhjGR60k7lSjyu3odDRWX/btt/d/8jw//ABdH 9u2393/yPD/8
XTJNSisv+3bb+7/5Hh/+Lo/t22/u/wDkeH/4ugDUoqlHfb2hVreVBMcI5KFT wW7MewNXaACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAq3f/HzY/wDXc/8Aot6tVVu/+Pmx/wCu5/8ARb1aoAKK KKACiiigAooo
oAKKKKACiiigAooooAy/+Yd/2+/+3FWY/wDkLXH/AFwi/wDQpKrf8w7/ALff /birMf8AyFrj
/rhF/wChSUAZ6Qs1jYMs0vm3AUM7zSEfcLE4DD0qJoLvzZI42nlMbBWZWcDO Ae847EVbt/8A
jz0b/gP/AKJardp/x833/Xcf+i0oA5O5t73/AITHTQUuNx0+7I+ds48y3z/y 2+ncfQ9tj7Nf
/wDPO5/77b/4/T7r/kedK/7Bt7/6Nta26S3ZpPaPp+rMH7Nf/wDPO5/77b/4 /R9mv/8Annc/
99t/8freopmZgpBMYI52mfb5wjZC8oYfPsPPmkevrWhbJ5N/PErSFBFGwDyM +CS+epPoKh/5
h3/b7/7cVZj/AOQtcf8AXCL/ANCkoAq2/wDx56N/wH/0S1atZVv/AMeejf8A Af8A0S1atABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAVbv/j5sf+u5/wDRb1aqrdf8fNj/ANdz/wCi3q1QAUUU UAJVZry3W8+x
+fF9p2eb5O8b9mcbtvXGeM1Zqne6dZ6jCIr21guYg24JNGHXPTOCOvJ/Ok79 Bxt1LYPHXNBJ
xxWINJvrUn+zdYlVeghvE+0Io7kHKyE5/vOQMkY6YQ65PaHbqml3MGOPNtgb lCewGweZ07lA
MgjPTJexfsr/AAu5u0VVtLy3vrdJ7W4inhbO2SJwytg4OCOOoIq1TM2mnZi0 UUUAFFFFAGX/
AMw7/t9/9uKsx/8AIWuP+uEX/oUlVv8AmHf9vv8A7cVZj/5C1x/1wi/9CkoA q2//AB56N/wH
/wBEtVu0/wCPm+/67j/0WlVLf/jz0b/gP/olqt2n/Hzff9dx/wCi0oAztc/5 DHhn/sJP/wCk
lxW3XMardG41vw6UUCJNTdcl/m3fZbjjaOnB78+wrp6S3ZpPaPp+rCiqtxJJ EnmIFZFBLhm2
nHqD09eDj6jFPt5xNCsgzgjIyP8AOfqOD2pmZS/5h3/b7/7cVZj/AOQtcf8A XCL/ANCkqt/z
Dv8At9/9uKsx/wDIWuP+uEX/AKFJQBVt/wDjz0b/AID/AOiWrVrKt/8Ajz0b /gP/AKJatWgA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KAE7Un4Ubh61TvtSstOiEt7dQ28RbaHmkCLnrjJPXg/lRewKLbskXaPwrD/4 SrRnOLa8N5j7
wsonudvpu8sNtz2zjODjoaT+3LmU7rXQtSnhJ+WTbHFn1+WR1cc+qj1GRg0u ZdzT2U+qsbma
Oc1h/bPEMhJTR7NEPKia/KuB6MFiYA+uCR6E9aPsWvy/LNrVtGh6m2sikg+h d3Ufip4z0PIV
w9n3aX9eRpXXFxZf9dz/AOi3q1keornJ9ClkntEvdY1K6jMpGzzEhwdj87ol RvwzjnpVg+Fd
FYA3Gnx3bjo94TcOB6BpCxA9s45Pqad2HLTW8ia68R6NZTvb3WrWUE6Y3RyT qrDIyMgnPQg1
CfE1lIcW0N9cM33PKspSknptkKhMHs27bznOOa0rWzt7G3S3tLeKGFc7Y4lC quTk4A46kmrB
UEdBRZ9wvTXS5if2rqsnyReHrpHPRrmeJYx9SjOw/BTzjoOQuPEd0f8AmG6f t/37rf8A+i9u
P+BZz2xzt4NQyu8ULusbTMoJEaEbmPoMkDJ9yBSt5gqi6RsZJ03V3+a41+WN hxts7aNEx6kS
Bzn/AIEB046k5U1gl9K8FrLqd9chikt693LDDGRxyEZFcjBG2MfeXDFSS1ao 0271Q51pohD/
AA2Vu77PQ+Y/BkBH8JVV+YghsAjWggitoVhgjWONAFREGAoHAAA6Cly39DT2 rhs9fIydA8O2
uhCZ4lj86fb5jRRLEnGcBVUAAAs2M7m5wWOBW7RR2qkrGM5ym3KTuxaKKKZI UUUUAZf/ADDv
+33/ANuKsx/8ha4/64Rf+hSVW/5h3/b7/wC3FWY/+Qtcf9cIv/QpKAKtv/x5 6N/wH/0S1W7T
/j5vv+u4/wDRaVUt/wDjz0b/AID/AOiWq3af8fN9/wBdx/6LSgDI8VwRnTra YovmLqNgA2Oc
fa4uPce1bQt4lKYX7jtIvJ4Y5yf/AB4/nWL4rnjGnW0JdfMbUbAhc84+1xc+ w966Gl1NH8C9
X+hW+yQkr+7B2sXUNyAxOSceue/btVmoXuI43RXcKXOF3HAJ9M+vtU1MzMv/ AJh3/b7/AO3F
WY/+Qtcf9cIv/QpKrf8AMO/7ff8A24qzH/yFrj/rhF/6FJQBVt/+PPRv+A/+ iWrVrKt/+PPR
v+A/+iWrVoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiik3D1FAB9a T8KzbzXdK06Y
RXupWltIy7gksyqSPXBPTg/lVX/hKdKb/VPdTpniS2s5pkb6OiFT6cHg5HUU uZItUptXS0Nz
tRWJ/bF/LxbaDfSK33JZXiiQ56FgX3qO5+XcP7ueKPN8RT/J9k060z/y2+0v Pt/4BsTPp94Y
znnGCcyH7J9195t0HpyRWGNM1qbifXjHgfKbK0SPPru8wyZ9sY75zxhT4djl +a91DU7qTOA/
2pocD02xbFPfkjPPXAGC4ckesjbLADqPzrF/4SzQCRs1mylY/djhmDu59FVc liewAJPak/4R
XQid02lW1y+eZLlPOkb6s+WPpyeAAOgrbCgdqNQ/dru/w/zMM+I7d8La2Wp3 EpPEf2KSLPr8
0gVBx6sPQZOBS/2lrU/NtoJjwPm+3XaR59NvliTPvnHbGecbeAewoIzRbuHN HpEw9viS4O7z
dNscceX5clzn33bo8fTaemc84AdI1R/mfxHfBjyywwwKmfRQyMQPTLE+pNbu PSg5xxRyoPat
bIw/+EW0zgP9tlXukt/PIjD0ZWchge4IIPerNpoWladMZbLTrS2lZdpeKFVJ HpkDpwPyrS+p
pfpQopCdWbVm9A2j0FLRRTICiiigCrd/8fNj/wBdz/6LerVVbv8A4+bH/ruf /Rb1aoAKKKKA
CiiigAooooAKKKKACiiigAooooAy/wDmHf8Ab7/7cVZj/wCQtcf9cIv/AEKS q3/MO/7ff/bi
rMf/ACFrj/rhF/6FJQBVt/8Ajz0b/gP/AKJardp/x833/Xcf+i0qpb/8eejf 8B/9EtVu0/4+
b7/ruP8A0WlAGD4rtntvBfiERFWhfT7lmDLhgfLbnI+90HXnvk9K6EedlM+X 99t2M/c5xj3+
7n8ay/GX/IjeIP8AsG3P/opq26XU0fwL1f6FKSOeWIwkxKrlg527vlzwADxn HUnIz2Oamt4B
DCsYzgDAyf8AOPoOB2qeimZmX/zDv+33/wBuKsx/8ha4/wCuEX/oUlVv+Yd/ 2+/+3FWY/wDk
LXH/AFwi/wDQpKAKtv8A8eejf8B/9EtWrWVb/wDHno3/AAH/ANEtWrQAUUUE gd6AEoNNz6kV
lXXiPRrK4e3utVsoZ0xujknRWGRkZBOehBobQ4xlJ2SNbdS5rCPiWzbiG11O SQ/dT+z5k3E9
BudAo+rEAdyBR/auqy/JF4eukc9GuZ4kQfUo7sPwU846DkK6L9lProbtITxW LnxHcnppunhf
9+63/wDovbj/AIFnPbHLTpesS/Nca/LGw422dtGiY9SJBIc/iB046klw9mus kjcDD1FQzTxW
8LzTSrHGilndjgKBySSegrK/4RqzPM1xqckh5Z/7RmTcT1O1HCj6KAB2AFPi 8MaFBMk0Oj2E
csbBkdLdAykcgggcGi77Bamuoz/hK9EcEW+ox3TjqloDcOB6lYwxA98Y5HqK P7f84/6BpWpX
eOXPkeQF9P8AXFM9/u5xjnGRna2gdhS9BxxRZ9w5oLZfiYn23X5fmg0a2iQ9 Fub0pIPqEjdR
+DHjHQ8ANt4jk+b+0dOhzz5f2N5Nntu8xd2PXaM9cDpW5Sc0W7h7TskjDOh3 Mp23Wu6lPCT8
0e6OLPp80aK459GHocjIpf8AhFtJYET28t2v9y8uJLhAfULIzAH3xnk+prc5 9aKOVdg9rPo7
FKy02y06IxWVrDbxFtxSGMIuemcAdeB+VXMD0o/Gl7U7WM3JvVsWiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAq3f/HzY/8AXc/+i3q1VW7/AOPmx/67n/0W9WqA CiiigAooooAK
KKKACiiigAooooAKKKKAMv8A5h3/AG+/+3FWY/8AkLXH/XCL/wBCkqt/zDv+ 33/24qzH/wAh
a4/64Rf+hSUAVbf/AI89G/4D/wCiWq3af8fN9/13H/otKqW//Hno3/Af/RLU z7B9rvryT7Zd
w4lC7YZdoP7tOcY680ATxSSG6H2lnjfJ8uMDCH/gX8R68EjgZ2jGazvBtxEf A/hzDffsII14
PLCMZH/jp/Kr39i/9RPUv+//AP8AWrG8JaT5ngzQpP7R1BN2n252pNgDMa8D jpS6mi+B+q/U
3ridWVXhmkEmWVFjXduIOCCp7ZAGeMeozViAymFDMAJMc4/z+mT9T1ql/Yv/ AFE9S/7/AP8A
9aj+xf8AqJ6l/wB//wD61MzD/mHf9vv/ALcVZj/5C1x/1wi/9CkqnGnl6Uke 5m23YXcxyTif
qT61cj/5C1x/1wi/9CkoAy5LmW20zR3hs5btvlHlxMgb/VNz87KP1pTdeIJf uaZZQI/3Xlu2
dkB7sipgkd1D47Bu9WLf/jz0f/gP/olq1cUmmXGSStZMwfsWvyfLNrVtGh6t b2JSQfQs7qPx
U8Z6HkKNBeYYvtY1O5j6hPNWHB9d0Sox78E456ZAxu4oxRyoftZeX3GF/wAI ror4Nxp8d046
Pdk3DgegaQsQPbOOT6mtO0s7axt0t7S3jghXO2ONAqrk5OAOOpJq1SGhJLZE ucmrSdxcD0FL
RRTJCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAq3f8Ax82P/Xc/+i3q1VW7/wCPmx/67n/0W9WqACiiigAooooAKKKK ACiiigAooooA
KKKKAMv/AJh3/b7/AO3FWY/+Qtcf9cIv/QpKrf8AMO/7ff8A24qzH/yFrj/r hF/6FJQBVt/+
PPRv+A/+iWq3af8AHzff9dx/6LSqlv8A8eejf8B/9EtVu0/4+b7/AK7j/wBF pQBarE8Kf8ge
f/sJX/8A6VzVt1ieFP8AkDz/APYSv/8A0rmpdTRfA/VfqbdFFFMzMv8A5h3/ AG+/+3FWY/8A
kLXH/XCL/wBCkqt/zDv+33/24qzH/wAha4/64Rf+hSUAVbf/AI89G/4D/wCi WrVrKt/+PPRv
+A/+iWrVoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigCrd/8fNj/wBdz/6LerVVbv8A4+bH/ruf /Rb1aoAKKKKA
b7/ruP8A0WlAEEUcguh9pV5HyfLkByg/4D/CevJB4ONxzis7QpidX8R/upBu 1UJyOmLSDk+x
xwfcV0VYmh/8hjxN/wBhJP8A0kt6T3RpDaXp+qLk/wC+CMsE3nBmCEHYVwcZ J6bSQDjnPBwc
VYgEohQTEGTHOP8AP64H0HSp6KZmZf8AzDv+33/24qzH/wAha4/64Rf+hSVW /wCYd/2+/wDt
xVmP/kLXH/XCL/0KSgCrb/8AHno3/Af/AES1atZVv/x56N/wH/0S1atABRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAVbv8A4+bH/ruf/Rb1aqrd/wDHzY/9dz/6LerVABRRRQBBczfZ7Wabbu8t GfGcZwM0zzL/
AP59rb/wIb/4ik1P/kFXn/XB/wD0E1boAq+Zf/8APtbf+BDf/EUeZf8A/Ptb f+BDf/EVaooA
q+Zf/wDPtbf+BDf/ABFRvcXUIVpbeEIXVCVmJI3MB02j1q9VXUP+PZP+u8X/ AKMWgC1RRRQA
UUUUAZf/ADDv+33/ANuKsx/8ha4/64Rf+hSVW/5h3/b7/wC3FWY/+Qtcf9cI v/QpKAKtv/x5
6N/wH/0S1W7T/j5vv+u4/wDRaVUt/wDjz0b/AID/AOiWq3af8fN9/wBdx/6L SgBkNy9zITEF
WFGKsWbLE+m0fd6jrz2wOtUbX/kedV/7Btl/6Nuq1WgjaZZSg8xRgOODj09x 7Vh2tvEvjnUg
F+5YWki8nhjJd5P/AI8fzpPdGkNpen6o2LiSSJPMQKyKCXDNtOPUHp68HH1G KfbziaFZBnBG
Rkf5z9Rwe1N+yQkr+7B2sXUNyAxOSceue/btVmmZmX/zDv8At9/9uKsx/wDI WuP+uEX/AKFJ
Vb/mHf8Ab7/7cVZj/wCQtcf9cIv/AEKSgCrb/wDHno3/AAH/ANEtWrWVb/8A Hno3/Af/AES1
atABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAVbv/j5sf8Aruf/AEW9Wqq3f/HzY/8AXc/+i3q1 QAUUUUAVNT/5
BV5/1wf/ANBNW6qan/yCrz/rg/8A6CadczvFAXSIu2cYGePfgE/kD+XNAFmi qtvJvtxK9zHJ
ubh0wF64AHJ7+55/KpTKgzlwNrBTz0JxgfXkfnQBLVXUP+PZP+u8X/oxai+0 SR3vkCRZwW5C
j5ogefmxxj0zt4H8RqXUP+PZP+u8X/oxaALVFFFABRRRQBl/8w7/ALff/bir Mf8AyFrj/rhF
/wChSVW/5h3/AG+/+3FWY/8AkLXH/XCL/wBCkoAq2/8Ax56N/wAB/wDRLVbt P+Pm+/67j/0W
lVLf/jz0b/gP/olqkScW1zdiSOf55QylYXYEbFHUA9waALbTxrMsRceYwyEH Jx6+w96yrr/k
edK/7Bt7/wCjbWpIZktpSsSzNC7FmDWsgYH13Bfm6Drz3yelZlxen/hNdIYo +BY3wfEEmdpk
t9uBt69M/j7UnsaU9/k/yZ0j3EcboruFLnC7jgE+mfX2qasmS6aaIwkOquWD n7JI3y54ABXG
cdScjPY5qW3uYIYVjCXWAMDNvJ/8Tx9BwO1MzGf8w7/t9/8AbirMf/IWuP8A rhF/6FJVQZ/s
1SVZS12GAZSpwZ8jg+xq3H/yFrj/AK4Rf+hSUAVbf/jz0b/gP/olq1ayrf8A 489G/wCA/wDo
lq1aACiiigAooooAKKKKACiiigAooooAKKKKAE5pD70HgZzWEZLjXDm1n8jT ehlXPmXI7mNg
RsTtv5LAkrt+VyXsVGNzYhlSZS0bq6hmUlTkZBII+oIIPuKnqvDFFbwpDCix xooVEQYCgcAA
DoKn3D1FAnvoLRSZHqKMj1FAhaKTI9RRkeooAWikyPUUZHqKAFopMj1FGR6i gBaKTI9RRkeo
oAWikyPUUZHqKAFopMj1FGR6igBaKTI9RRkeooAWikyPUUZHqKAK13/x82P/ AF3P/ot6tVUu
iPtNjyP9ef8A0W9Wsj1FAC0UmR6ijI9RQBV1P/kFXn/XB/8A0E1bqpqRH9lX nP8Aywf/ANBN
TyyxwxmSV1RB1ZjgD8aAEMSHOUB3MGPHUjGD9eB+VBiQ5ygO5gx46kYwfrwP ypIJfOj3bHVe
g3qVJ98HkfjU1ADEVEGFUKMk4A7nk1BqH/Hsn/XeL/0YtKLmPzfJbckucBX4 3e69jxzx074p
NQ/49k/67xf+jFoAtUUUUAFFFFAGX/zDv+33/wBuKsx/8ha4/wCuEX/oUlVv +Yd/2+/+3FWY
/wDkLXH/AFwi/wDQpKAKtv8A8eejf8B/9EtWrWVb/wDHno3/AAH/ANEtWrQB BeRTzWrpbXH2
efgpIUDgEHOCp6qcYIBBwTgg4I5q9vrh9f8ADdjf27peR6g7GWOF/ImX7LcA OrchSc/6sncC
D95QHbdguJJ7na7iEpk+SR85HTJJ7c9sjI+8elWhKhxhwdzFRz1IzkfXg/lS auXCfLujMmuN
euZ5IrKxtrOFWKC6vZPMY4P3lhjPzKRgDdIjDJJXjDbFUrmfYiypPGoDFdjc hz/dGOd2QRxn
vwalt5XmhV3QxseSp/z/ADwfUDpQJu/QbqH/AB7J/wBd4v8A0YtJH/yFrj/r hF/6FJS6h/x7
J/13i/8ARi0kf/IWuP8ArhF/6FJTJKtv/wAeejf8B/8ARLVq1lW//Hno3/Af /RLVq0AFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAUNQtXvbCW2WURmRcEtGJFI7qyn7ynoRwS CcEHkYNnoWhS
zm1vvDumW14q79iwo6SJ/eRig3AZAPAIJGRgqW6sVTvtOtr+FY7lGIVtyskj IyHplWUhlOCR
wehI6E1LimaU6jiuW+hS/wCER8O/9APTv/AVP8KP+ER8O/8AQD07/wABU/wr QtI54bdI55zP
IuR5vlhSwzwSBxnGM4wCckADgWvpRyoHVqJ/EY3/AAiXh7/oB6d/4Cp/hR/w iXh7/oB6d/4C
p/hWzijFPlQva1O5jf8ACJeHv+gHp3/gKn+FH/CJeHv+gHp3/gKn+FbOKMUc qD2tTuY3/CJe
Hv8AoB6d/wCAqf4Uf8Il4e/6Aenf+Aqf4Vs4oxRyoPa1O5jf8Il4e/6Aenf+ Aqf4Uf8ACJeH
v+gHp3/gKn+FbOKMUcqD2tTuY3/CJeHv+gHp3/gKn+FM/wCES0BSPL0ezjYf dkihCOh9VZQC
pHYggjtW5ijFHKg9rU7mN/wi+nf89dS/8Gdx/wDHKP8AhF9O/wCeupf+DO4/ +OVs4oxRZB7W
p3Mb/hF9O/566l/4M7j/AOOUf8Ivp3/PXUv/AAZ3H/xytnFGKLIPa1O5jf8A CL6d/wA9dS/8
Gdx/8co/4RfTv+eupf8AgzuP/jlbOKMUWQe1qdzG/wCEX07/AJ66l/4M7j/4 5R/wi+nf89dS
/wDBncf/ABytnFGKLIPa1O5ztx4a09J7QCXUvnmIOdSuD/A5/wCenFWf+EX0 7/nrqX/gzuP/
AI5V+6H+k2P/AF3P/ot6tYo5UP21TuY3/CL6d/z11L/wZ3H/AMco/wCEX07/ AJ66l/4M7j/4
5WziiiyF7Wp3Odu/D1lb2U8qSX5ZI2YB9RnZcgHqC5BHseK3JoEmjCsDxyCG KkH2I5FQ6l/y
C7zp/qH/APQTVztTslsS5Sl8TuVlimVCn2gswYEOyDJXIJBxxzyM4HX2pxjl JfE2MurL8o+V
RjK/jg8+/tViigRV+z75fMnkZ8NlE6Kvpx3PTrnkZGKNQ/49k/67xf8Aoxat VV1D/j2T/rvF
/wCjFoAtUUUUAFFFFAGX/wAw7/t9/wDbirMf/IWuP+uEX/oUlVv+Yd/2+/8A txVmP/kLXH/X
CL/0KSgCC1t/tGl6f+8eNo40dWTGc7MdwR0Jqf7LN/0ELn/vmP8A+Io0z/kF Wf8A1wT/ANBF
W6AKRs5GKk31wSpyDtj4PT+57mmiwYYxeTjaxYfLFwTnJ+515P51ZaeNZliL jzGGQg5OPX2H
vU1AFBdPZWDLeTgjOCEi7nJ/g7nmpPss3/QQuf8AvmP/AOIqV7iON0V3Clzh dxwCfTPr7VNQ
BSazdyPMu53VWV9pCAEggjoueop0f/IWuP8ArhF/6FJVuqkf/IWuP+uEX/oU lAFW3/489G/4
D/6JatWsq3/489G/4D/6JatWgAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAKt3/AMfNj/13P/ot 6tVVu/8Aj5sf
+u5/9FvVqgAooooAqan/AMgq8/64P/6CaddLO0JEDAPnrnHH1wcfkf6iZlWR SrAMrDBBGQRV
f+zLD/nytv8Av0v+FADYWENuSkEytvAZX+ZskgZJycjBHOTgD2xUxmI3fupD tkVOF65xyPYZ
5Psaj/syw/58rb/v0v8AhR/Zlh/z5W3/AH6X/CgCFY5DdkwK8Ue4+YXPyv67 V69c8/Lyc/NU
+of8eyf9d4v/AEYtJ/Zlh/z5W3/fpf8AChdPslcOlnbqynIIjAIP5UAW6KKK ACiiigDL/wCY
d/2+/wDtxVmP/kLXH/XCL/0KSq3/ADDv+33/ANuKsx/8ha4/64Rf+hSUAGmf 8gqz/wCuCf8A
oIq3VTTP+QVZ/wDXBP8A0EVboApQ2z20hERVoXYswZcMD67h97oOvPfJ6VMP OymfL++27Gfu
c4x7/dz+NT0UAUpI55YjCTEquWDnbu+XPAAPGcdScjPY5qa3gEMKxjOAMDJ/ zj6DgdqnooAK
qR/8ha4/64Rf+hSVbqpH/wAha4/64Rf+hSUAVbf/AI89G/4D/wCiWrVrKt/+ PPRv+A/+iWrV
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigCrd/8fNj/wBdz/6LerVVbv8A4+bH/ruf/Rb1aoAK KKKACiiigAoo
ooAKKKKACiiigAooooAy/wDmHf8Ab7/7cVZj/wCQtcf9cIv/AEKSq3/MO/7f f/birMf/ACFr
j/rhF/6FJQAaZ/yCrP8A64J/6CKt1U0z/kFWf/XBP/QRVugDOikkN0PtLPG+ T5cYGEP/AAL+
I9eCRwM7RjNWhcRMUw333aNeDywzkf8Ajp/Kp6KAKFxOrKrwzSCTLKixru3E HBBU9sgDPGPU
ZqxAZTChmAEmOcf5/TJ+p61PRQAVUj/5C1x/1wi/9Ckq3VSP/kLXH/XCL/0K SgCrb/8AHno3
/Af/AES1atZVv/x56N/wH/0S1atABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAVbv8A4+bH/ruf /Rb1aqrd/wDH
zY/9dz/6LerVABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAGX/AMw7/t9/9uKs x/8AIWuP+uEX
/oUlVv8AmHf9vv8A7cVZj/5C1x/1wi/9CkoANM/5BVn/ANcE/wDQRVus62W/ t7WGHyLdvLRU
3eewzgYz9yp/Mv8A/n2tv/Ahv/iKAEjuBNJiKNmj6mU8Kfp3btz0x37VbrMW K6SYypbQRkkl
gtwwV89yNmM+/XjrinBL8bf3cZ2yM/Ny3Oc8H5OgzwPYUAWZpXiCssTSJ/EU 5K++O469OemA
afHKkqBlOQf84PofaqDQ3brskjR03MxU3TYbJzg/JyB0x0x1zVhTeRoES0tV VRgATkAD/vig
C5VSP/kLXH/XCL/0KSl8y/8A+fa2/wDAhv8A4im28c/2qWeZI13IiBUct0LH PIH96gCtb/8A
Hno3/Af/AES1atZVv/x56N/wH/0S1atABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAVbv8A4+bH /ruf/Rb1aqrd
/wDHzY/9dz/6LerVABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAGX/AMw7/t9/ 9uKsx/8AIWuP
+uEX/oUlVv8AmHf9vv8A7cVZj/5C1x/1wi/9CkoAt0UUUAFFZ0Ucguh9pV5H yfLkByg/4D/C
evJB4ONxzirQmJ2/upBukZOV6YzyfY44PuKAJ6KoT/vgjLBN5wZghB2FcHGS em0kA45zwcHF
WIBKIUExBkxzj/P64H0HSgCeiiigDKt/+PPRv+A/+iWrVrKt/wDjz0b/AID/ AOiWrVoAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigCrd/8AHzY/9dz/AOi3q1VW7/4+bH/ruf8A0W9WqACiiigA ooooAKKKKACi
iigAooooAKKKKAMv/mHf9vv/ALcVcmtLadg01vFIwGAXQE4/Gqf/ADDv+33/ ANuK1KAKn9mW
H/Plbf8Afpf8KP7MsP8Anytv+/S/4VbooAqf2ZYf8+Vt/wB+l/wo/syw/wCf K2/79L/hRHcC
aTEUbNH1Mp4U/Tu3bnpjv2q3QBU/syw/58rb/v0v+FH9mWH/AD5W3/fpf8Kf NK8QVliaRP4i
nJX3x3HXpz0wDT45UlQMpyD/AJwfQ+1AEP8AZlh/z5W3/fpf8KP7MsP+fK2/ 79L/AIVbooAp
3CrHNYKqhVWYgADAA8t6uVVu/wDj5sf+u5/9FvVqgAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA Kt3/AMfNj/13
P/ot6tVVu/8Aj5sf+u5/9FvVqgAooooAKKKKACiiigAooooAKKKKACiiigDL /wCYd/2+/wDt
xWpWX/zDv+33/wBuK1KACiiigCqtvGkxlQGNiSWCnCvnuR0z79eOuKeISNv7 2Q7ZGfluuc8H
2GeB7CpGZVZQWALHAGep6/0NPoAqtao42SSSOm5mKluGyc4PqB0x0x1zU6qs aBEUKqjAAGAB
SF1DhCRuIJAzyQOv8x+dSUAFFFFAFW7/AOPmx/67n/0W9Wqq3f8Ax82P/Xc/ +i3q1QAUUUUA
RQAUUUUAFFFFAFW7/wCPmx/67n/0W9Wqq3f/AB82P/Xc/wDot6tUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAZf/ADDv+33/ANuK1Ky/+Yd/2+/+3FalABRRRQBQgt5ILnc6 CYvkecT84HXB
B7cdsDJ+6OtTiSUlMw4y7K3zD5VGcN+OBx7+1WKKAKM6SXEQQ267tzYZ24TB wGGOc45GMd+R
U1vE8MKo7mRhwWP+f55PqT1qxRQAUUUUAVbv/j5sf+u5/wDRb1aqrd/8fNj/ ANdz/wCi3q1Q
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFAFW7/4+bH/AK7n/wBFvVqqt3/x82P/AF3P/ot6tUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAZf/MO/wC33/24rUrOt4BcWLxl2T/SJGDLjIIlJHXP cVN9lm/6CFz/
AN8x/wDxFAFuiqn2Wb/oIXP/AHzH/wDEUfZZv+ghc/8AfMf/AMRQBHBcST3O 13EJTJ8kj5yO
mST257ZGR949KtCVDjDg7mKjnqRnI+vB/Kq5s5GKk31wSpyDtj4PT+57mmiw YYxeTjaxYfLF
wTnJ+515P50AOuZ9iLKk8agMV2NyHP8AdGOd2QRxnvwalt5XmhV3QxseSp/z /PB9QOlQLp7K
wZbycEZwQkXc5P8AB3PNSfZZv+ghc/8AfMf/AMRQBboqp9lm/wCghc/98x// ABFH2Wb/AKCF
z/3zH/8AEUALd/8AHzY/9dz/AOi3q1VNbNhLHJJdTy+WxZVYIBnBHZR2Jq5Q AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFAFW7/4+bH/AK7n/wBFvVqqt3/x82P/AF3P/ot6tUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAVdP8A+PZ/+u8v/oxqtVV0/wD49n/67y/+jGq1QAUUUUAFFFFABRRR QAUUUUAFFFFA
UUAFFFFABRRRQAUUUUAVbv8A4+bH/ruf/Rb1aqrd/wDHzY/9dz/6LerVABRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFAFXT/wDj2f8A67y/+jGq1VXT/wDj2f8A67y/+jGq1QAU UUUAFFFFABRR
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAVbv/AI+bH/ruf/Rb1aqrd/8AHzY/ 9dz/AOi3q1QA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQBV0//AI9n/wCu8v8A6MarVVdP/wCP Z/8ArvL/AOjG
q1QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFQ xXEc6b4nDpnG
5eQfoe/4VNQAUVAlwkjuiOC6HDL3X6j+XrU9ABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
FABRRRQAUUUUAFFFFAGbbXCW6NHJHPuEsh4gdhguxHIGOhqf7fD/AHLn/wAB pP8A4mrdFAFT
7fD/AHLn/wABpP8A4mj7fD/cuf8AwGk/+Jq3RQBU+3w/3Ln/AMBpP/iaPt8P 9y5/8BpP/iat
0UAVPt8P9y5/8BpP/iaPt8P9y5/8BpP/AImrdFAFT7fD/cuf/AaT/wCJo+3w /wBy5/8AAaT/
AOJq3RQBU+3w/wBy5/8AAaT/AOJo+3w/3Ln/AMBpP/iat0UAVPt8P9y5/wDA aT/4mj7fD/cu
f/AaT/4mrdFAFT7fD/cuf/AaT/4mj7fD/cuf/AaT/wCJq3RQBU+3w/3Ln/wG k/8AiaPt8P8A
cuf/AAGk/wDiat0UAVPt8P8Acuf/AAGk/wDiaPt8P9y5/wDAaT/4mrdFAFT7 fD/cuf8AwGk/
+JqvczW91CYnW6Azni2c/oVIP4j9a06KAMxb6QR4ZXaUMORaygFcjPGDg4z3 Pb6U43/38JJ9
9dubaX7nGc/L1+9j8K0aKAMlpo5rlJpluAI2JjVLWTI+rFc84HAx6HIq39vh /uXP/gNJ/wDE
1booAqfb4f7lz/4DSf8AxNH2+H+5c/8AgNJ/8TVuigCp9vh/uXP/AIDSf/E0 fb4f7lz/AOA0
n/xNW6KAKn2+H+5c/wDgNJ/8TR9vh/uXP/gNJ/8AE1booAqfb4f7lz/4DSf/ ABNH2+H+5c/+
A0n/AMTVuigCp9vh/uXP/gNJ/wDE0fb4f7lz/wCA0n/xNW6KAKn2+H+5c/8A gNJ/8TR9vh/u
XP8A4DSf/E1booAqfb4f7lz/AOA0n/xNH2+H+5c/+A0n/wATVuigCp9vh/uX P/gNJ/8AE0fb
4f7lz/4DSf8AxNW6KAKn2+H+5c/+A0n/AMTR9vh/uXP/AIDSf/E1booAqfb4 f7lz/wCA0n/x
NH2+H+5c/wDgNJ/8TVuigDOecXNzaCOOf5JSzFoXUAbGHUgdyK0aKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAP/9k=
--------------030907000402000602070309--
Re: Multiple Questions concerning compartments [message #100140 is a reply to message #100097] |
Thu, 01 February 2007 14:51 |
Okay,
after some "playing around" with the models I managed to get the drag
and drop between Canvas/compartments working. The List Layout is pretty
cool, though, because it orders the elements pretty nicely. Is there
some way to "merge" the behaviour in a way that the initial layout is a
list, but you still can arrange the figures manually? On the other hand
I´d like to know where the "resize" behavior of the parent nodes is
defined. It would be nice if the arrange button could resize the
parentnodes so that all nodes in the comparments are visible,
additionally to the arrangement of nodes.
Greetings,
Christian
Christian Dänekas schrieb:
> Hello,
> <root>
> <operator>
> <operand/>
> <operand>
> <operator>
> <operand>
> <operator>
> <operand/>
> <operand/>
> </operator>
> </operand>
> </operator>
> </operand>
> </operator>
> <operand/>
> </root>
> Greetings,
> Christian
FUDForum. Page generated in 0.03950 seconds
