Home » Newcomers » Newcomers » Java GUI desktop app
Java GUI desktop app [message #100076] Wed, 07 September 2005 13:02 Go to next message
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
Can somebody point me to an example "hello world" type java gui
application and the tools to help build one?
Right now, I use java for web applications, but am looking into using
java for a desktop application. I don't really know where to look to get
the GUI components and tools, so any suggestions or good links would be
appreciated.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: Java GUI desktop app [message #100104 is a reply to message #100076] Wed, 07 September 2005 14:14 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
David,
First you'll need to decide whether you would like to learn Swing
(standard Java) or SWT (UI toolkit Eclipse uses).
Sun has an excellent tutorial for learning Swing online:
http://java.sun.com/docs/books/tutorial/uiswing/
Information about SWT is available from SWT's homepage:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/main.html
You can use the Eclipse Visual Editor to help you visually design UIs
for both Swing and SWT:
http://www.eclipse.org/vep/
Hope this helps,
- Jeff
> appreciated.
Re: Java GUI desktop app [message #100118 is a reply to message #100104] Wed, 07 September 2005 14:36 Go to previous message
In article <dfmsll$jel$1@news.eclipse.org>, myersj@gmail.com says...
> David,
Since I'm using Eclipse for the rest of my java stuff, SWT makes a lot
more sense to me.
Great, thanks!
> Hope this helps,
> - Jeff
> > appreciated.
Previous Topic:No class def found problem after upgrading Apache to 5.5
Next Topic:Update 3.0.2 => 3.1
Current Time: Thu Dec 26 16:01:42 GMT 2024
Powered by FUDForum. Page generated in 0.05704 seconds
