Home » Eclipse Projects » Eclipse Platform » ctrl space does not launch code assist
ctrl space does not launch code assist [message #9120] Thu, 24 April 2003 10:44 Go to next message
Originally posted by: jmwap.users.sourceforge.net
Since I installed 2.1 (Version: 2.1.0 Build id: 200303272130) I cannot
invoke code assist with ctrl-space, just via menus, thats really annoying.
In the prefs->editor->keys->commnads, after Window, there is what is seems
a nameless entry, and its assgned key sequence has:
\"Global Standar Ctrl+space [conflict]\"
The Add, Remove, buttons are inactive.
Any hints? I looked in the bug system but did not find anything
TIA
ps: win xp sp1, jdk1.4.1
Re: ctrl space does not launch code assist [message #10422 is a reply to message #9120] Thu, 24 April 2003 14:07 Go to previous messageGo to next message
Darin Swanson is currently offline Darin SwansonFriend
Have you installed any plugins other than the standard set of Eclipse
plugins?
See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=33161
HTH
Darins
"jmjmwap" <jmwap@users.sourceforge.net> wrote in message
news:b88f5j$o21$1@rogue.oti.com...
> TIA
Re: ctrl space does not launch code assist [message #11969 is a reply to message #9120] Thu, 24 April 2003 16:08 Go to previous messageGo to next message
Originally posted by: Kevin.clark.accessbc.com.nospam
The X-Men XML plug-in is causing this problem. Delete it and your
CTRL+Space Content Assist should start working again.
See bugs:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=35874
https://bugs.eclipse.org/bugs/show_bug.cgi?id=36267
jmjmwap wrote:
> TIA
Re: ctrl space does not launch code assist [message #11996 is a reply to message #11969] Thu, 24 April 2003 16:26 Go to previous messageGo to next message
Thanks!
I have not tried it yet, but I have xmen installed so...
Re: ctrl space does not launch code assist [message #15547 is a reply to message #9120] Fri, 25 April 2003 15:33 Go to previous message
Originally posted by: bob.objfac.com
If my memory serves there was just a thread on this, in either eclipse.tools
or eclipse.tools.jdt, that gave the proper incantation to make this work
again. But darned if I can find it.
Bob
> TIA
Previous Topic:How to make a library of JARS
Next Topic:Sudden problems with Eclipse
Current Time: Sat Nov 09 00:26:03 GMT 2024
Powered by FUDForum. Page generated in 0.03477 seconds
